#2087 | |
Drives: JAWS
What tune and mods are you running? |
#2088 |
Drives: Celica 04
#2089 |
Drives: JAWS
Are you running a 91 or 93 tune? Stage 2? That seems like a lot of knock at high rpm, high load. Maybe you need to find different gas if you're on 100 getting that much knock.
| The Following 2 Users Say Thank You to JB86'd For This Useful Post: | AL008 (11-23-2014), Shiv@Openflash (11-23-2014) |
#2090 | |
Drives: Celica 04
There is also no more 100 octane in Australia, United petrol is shutting that division ..Looks like back to 98. Should I reduce my timing to 91 tune? Cheers. |
#2091 | |
Drives: JAWS
I think you should definitely try the 91 tune. Keeping the knock to a minimum will keep your IAM at 1 hopefully. So although you lose a bit of power with the 91 vs 93 tune you may actually end up with more power and a safer tune on 91 if your timing isn't being pulled due to knock
| The Following User Says Thank You to JB86'd For This Useful Post: | AL008 (11-24-2014) |
#2092 | |
other option is to blend 6 litres on e85 preferably united e85 to 50 litres of 98 (ie full tank) this will effectivly make the old United P100
| The Following User Says Thank You to steve99 For This Useful Post: | AL008 (11-24-2014) |
#2093 |
if you pm me you email i can send you my uel header map for aussie fuel -4 degrees correction is not good.
#2094 |
Drives: 2013
Has anyone use stage 2 map on stock header, catless front pipe and catback exhaust?
#2095 |
Senior Addict
Drives: 86 GT
| The Following User Says Thank You to Fizz For This Useful Post: | chickencornsoup (11-26-2014) |
#2096 |
Drives: 2012 Toyota 86
I dont think its recommended as the stock cat restricts too much exhaust flow for the more aggressive valve timing.
| The Following User Says Thank You to troek For This Useful Post: | chickencornsoup (11-26-2014) |
#2097 |
Drives: 2013
In this case the only map I can use is stage1 91 rom, except e85 .
#2099 |
#2100 |
Drives: GT86
| Tags |
| cat overtemp |
| OpenFlash Tablet | Rombinhood@OpenFlash | Software Tuning | 1838 | 07-29-2023 07:35 PM |
| OpenFlash Tablet Stg 2 Tune (Dyno Progress) | Rombinhood@OpenFlash | Software Tuning | 26 | 10-24-2013 02:19 PM |
| FBM Tuning fixed my issue, FA20 and Visconti didn't work as well | whitefrs | Forced Induction | 253 | 08-19-2013 01:39 PM |
| Official MMA Thread | zigzagz94 | Off-Topic Lounge [WARNING: NO POLITICS] | 11 | 12-15-2009 11:59 PM |
