#2045 | |
also on latest template file from page below should be FRS Custoised 4.SLT http://openflashtablet.com/Automotiv...ads/index.html make sure your logged in as administrator and maybe turn off antivirius just while oft updates |
#2046 |
I am on 1.13, thats the file I have, and im an admin and antivirus is off
#2048 |
Senior Addict
Drives: 86 GT
Someone might have asked this before already, but can I still use the OFT just for data logging even if I'm on ecutek?
Logging with ecutek would require taking laptop into car yes? Whereas logging with OFT is much simpler. |
#2049 |
I think so, but Tactrix might be a cheaper route if you don't need a real-time display.
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
| The Following User Says Thank You to phrosty For This Useful Post: | Fizz (10-28-2014) |
#2050 | ||
SLO NO MO
| The Following User Says Thank You to Foobar For This Useful Post: | Fizz (10-27-2014) |
#2051 |
Senior Addict
Drives: 86 GT
#2052 | |
Tactrix or oft should work as long as the ecutek guys ut rhe info in the same ram addresses as the standard roms. logging reads a specific ram address. The ecutek guys mess round with the program a fair bit with map switching and racerom features ect but may still use same ram addresses. If you know someone with ecutek tune plug your oft in see if it will log, it will log any brz/86 will only write to married car once your on ecutek dont use oft/tactrix to write or you will write over you ecutek licience in the rom of your ecu |
| The Following User Says Thank You to steve99 For This Useful Post: | Fizz (10-28-2014) |
#2053 |
Drives: Neptune GR86
How does it look?
Any other parameters I should be logging? http://datazap.me/u/andrew025/ptunin...g=0&data=1-8-9 |
#2054 |
Erected Member
Drives: frs
hey guys , just wondering if anyone has a fix for this.
I'm still able to upload files onto the ecu with the OFT but i can do live diagnostic, everytime i try it just says "please update template" so i went on the oft site and downloaded their latest template from the download section, updated the tablet and still says the same thing. any idea?
#2055 | |
OFM should be version 1.13.0 think oft is ver 1.31 if thats all good ring the oft guys |
| The Following User Says Thank You to steve99 For This Useful Post: | shif7i7down (10-30-2014) |
#2056 |
Erected Member
Drives: frs
that might be the problem, i updated with FA20 Template 1
#2057 |
Drives: AT 2013 BRZ Limited
@vishnu
Why does the Base idle timing (above RPM threshold) table stop at 2000RPM and then continues onto numbers like 2.####E##. I was trying to add higher rpms and retarding the timing in them but after the checksum fix, the whole table goes completely out of wack. The guys over at romraider's forum were able to edit the table without any issue, is it not recommended or something?
'13 BRZ (sold)
'17 STI |
#2058 | |
STOP - you may be using wrong definition for your tune file. For V2 OFT tunes you must use defs that come with the tune download file, do not use the V1.5 defs. |
| Tags |
| cat overtemp |
| OpenFlash Tablet | Rombinhood@OpenFlash | Software Tuning | 1838 | 07-29-2023 07:35 PM |
| OpenFlash Tablet Stg 2 Tune (Dyno Progress) | Rombinhood@OpenFlash | Software Tuning | 26 | 10-24-2013 02:19 PM |
| FBM Tuning fixed my issue, FA20 and Visconti didn't work as well | whitefrs | Forced Induction | 253 | 08-19-2013 01:39 PM |
| Official MMA Thread | zigzagz94 | Off-Topic Lounge [WARNING: NO POLITICS] | 11 | 12-15-2009 11:59 PM |
