#2003 | |
Drives: 2014 White BRZ
Once I get my OFT I will experiment with Stage 1 tune and different fuels. What are the Stage 1 tune options, 91 and 93? Is there a 94 tune or just use 94 with the 93 tune? |
#2004 | |
E85 fuels have some additives that generally supress crickets Always run a fuel of equal or higher octane rating than the tune is designed for. 91 tune for 91 and higher octane (slightly reduced power compared to 93 tune maybe 3-4 hp due 1 degree less ignition advance top end) 93 tune for 93 octane and higher fuels E85 tunes for E85 fuels only. |
#2005 | |
Hicas Thread Basher
Drives: Subaru BRZ 13, Hyundai Genesis 15
#2006 | |
Drives: FRS
For stage 1, Shell 91. I plan to test stage 2 with Shell no corn juice 91 with 1 gal. of race gas per tank to bring it up to 94 and see wha hoppen. ![]() CERBERUS Last edited by RFB; 09-24-2014 at 02:06 PM. |
| The Following User Says Thank You to RFB For This Useful Post: | Triumphrider (09-24-2014) |
#2007 |
Drives: Toyota GT86. N/A for life
Quick question,
I have downloaded the bin files for my car with the correct calid (from the OFT web site, OTS v2.061 [Stg1 A00G]). Where do I look to see if they are 91 or 93 oct tunes. I am from Australia and I believe we should be using the 91 oct tune for our fabulous 98 we have here. I cannot seem to find. What am I missing ![]() And are people still using TunerPro or have you all gone to RomRaider Cheers, Jeff |
#2008 |
Sorry, think I have just answered my own question.
#2009 | |
| The Following User Says Thank You to steve99 For This Useful Post: | Stumpygt86 (09-25-2014) |
#2010 |
Drives: 2013 Scion Frs(Scarlet)
i have some quick questions. I have ecutek on my car already, been thinking about getting an open flash tablet so that i can do my own tunes and learn and i don't have to wait for a tune update when i do mods. Quick questions, does open flash support flex fuel yet? Do i have to have ecutek erased from my ecu to use open flash? or does the ecu just need to be reverted back to stock rom?
#2011 | |
OFT does not have flex fuel option yet. to run E85 (tune copes with 60% to 90% E blends.) you have to flash E85 tune, to revert to petrol flash petrol tune. unfortunately no tune switching yet either. You will have to flash back your "stock "ecutek" rom to the ecu so its not locked or encrypted and no longer contains a "multiswitchable race rom tune". Unfortunatly Ecutek "stock" tunes are not 100% stock they contain some licience info embedded in the rom. this is not a problem for the OFT, but its possible you may loose your ecutek licience. if you write over this information in the rom. however the OFT does store a copy of the "stock rom" when you marry up oft to your car so theroeticly when you unmarry the OFT your stock ecutek rom will be reritten to car and you can use ecuteck again. Just flash your "stock" ecutek rom back to car and you should be all good. read the OFT Tips link below. also confirm what I have said with the OFT guys they are very helpful. |
#2012 | |
Drives: UK GT86
.: Stealth 86 :.
#2013 |
thanx guys for the info. Any i have ecutek but i hate waiting for a tuner to have to update my car when i put new mods on it. And it can be costly going with a different tuner. i just rather learn and tune myself. Thanx for the info guys
| The Following User Says Thank You to brichard0625 For This Useful Post: | Triumphrider (09-28-2014) |
#2014 |
Drives: UK GT86
Why not DIY on ECUtek? If you have a cable you have all you need....
.: Stealth 86 :.
#2015 | |
#2016 |
| Tags |
| cat overtemp |
| OpenFlash Tablet | Rombinhood@OpenFlash | Software Tuning | 1838 | 07-29-2023 07:35 PM |
| OpenFlash Tablet Stg 2 Tune (Dyno Progress) | Rombinhood@OpenFlash | Software Tuning | 26 | 10-24-2013 02:19 PM |
| FBM Tuning fixed my issue, FA20 and Visconti didn't work as well | whitefrs | Forced Induction | 253 | 08-19-2013 01:39 PM |
| Official MMA Thread | zigzagz94 | Off-Topic Lounge [WARNING: NO POLITICS] | 11 | 12-15-2009 11:59 PM |
