#1961 | |
These can upset MAF scaling and cause high fuel trims. If you fuel trims were low their is little to learn Log STFT LTFT FBKC (Knock correction) IAM FLKC RPM MAF V Engine load throttle position IAT AFR Commanded AFR |
| The Following User Says Thank You to steve99 For This Useful Post: | lucid215 (07-21-2014) |
#1962 |
Drives: Asphalt MT FR-S
Switched to E85 for the first time today. Followed the exact procedure @steve99 has in his thread. Drove 30 miles easy, then started testing WOT. Everything felt ok (coming from 1.34 91oct), but my LTFT at WOT is 11.73. At idle, LTFT is 3.5%. Mods in sig. Had my fiancé watching the OFT, and she said my AFR at WOT looked right, tapering to 11.8 at 7k rpms. We continued down a back road pushing it with no issues.
Then, I turned on my AC as we went through town slowly. Car started acting crazy, and threw a U0073 code, and went into limp mode. Pulled over right away to clear it. Now, am paranoid with a full tank of E85. Given the information I provided, should I even risk capturing a WOT log? Thanks for any input
//Asphalt//6 MT//OpenFlash Tablet//E85+93oct//TRD CAI//TRD Exhaust//TRD Shift Knob//5:AD Spoiler//35% Tint//Clear Bra//BeSpoke//Valentine One//
#1963 | |
Drives: 2013 Argento FR-S
| The Following User Says Thank You to Terrapin77 For This Useful Post: | evox2frs (07-19-2014) |
#1964 | |
Yeah, I kept trying to rig mount the OFT on the dash, and it lost communication a couple of times. After some research, I see that code is related to that, appreciate the confirm. The car definitely pulls harder top end. Running 3rd-5th has never felt like this. I miss the v1.34 Stage 1 kick at 4k rpms though. I want to go out and make some logs, but nervous about the LTFT's at this point. 11.96% at WOT doesn't sound good, right?? I saw Shiv post a dyno with OFT and TRD intake and all was good and made over 200whp. I don't want to have to scale my maf if I don't have to.
#1965 |
Agree with above post U0073 is loss of contact with Body control module. possibly hangover from when you flashed or as a result of data traffic on buss due OFT monitoring.
Their are 4 bands of air flow rates where ECU stores learned long term fuel trim. so the LTFT will changes as RPM hence Air flow changes across rpm /flow rate ranges. If the AFR is 11.8 at WOT that seems ok , actually on the rich side. It sometimes takes a while for the ECU to "learn" the higher end as it only learns on Closed loop mode ie steady throttle, and most people don't go steady throttle over 4000rpm they just nail it. So to set those trims quicker drive in second or third at partial steady throttle and hold rpm around 3500-4500 up a slight incline is useful. If you want to scale MAF your going to need to go back to petrol as the fuel trims will vary widely due varying ethanol content of E85. |
| The Following User Says Thank You to steve99 For This Useful Post: | evox2frs (07-19-2014) |
#1966 |
Man, you are extremely helpful on this forum, thanks @steve99. I'll take your advise on all measures, and see how she's running with some more miles on the tune.
#1967 | |
The first tank of "e85" will always have the left over petrol mixed in so LTFT trims can be a bit further "off" then usual. |
#1968 |
@steve99 last week as I pulled up to 5k in first gear I got a cel p0465?? Ithas something to do with fuel level sensor circuit high? I erased the code filled e85, I was at 1 quarter of the tank and no codes sense then, I have been data logging I might have a exhaust leak so im getting all new gaskets first off with header and overpipe, u think it was some bug in the system or something to worry about??
#1969 | |
don't think that code will be caused by exhaust gasket leak. |
#1970 | |
#1971 | |
Yes Shiv said E85 and BPB were not a good mix, BPB shifted peak power lower in rpm range but E85 did its best work at a higher RPM than where BPB were efficient so it was counter-productive. |
#1972 |
Yeahh good thing I didnt buy it a month ago like I planned too.
#1974 | |
| The Following User Says Thank You to steve99 For This Useful Post: | OmarYasin (07-19-2014) |
| Tags |
| cat overtemp |
| OpenFlash Tablet | Rombinhood@OpenFlash | Software Tuning | 1838 | 07-29-2023 07:35 PM |
| OpenFlash Tablet Stg 2 Tune (Dyno Progress) | Rombinhood@OpenFlash | Software Tuning | 26 | 10-24-2013 02:19 PM |
| FBM Tuning fixed my issue, FA20 and Visconti didn't work as well | whitefrs | Forced Induction | 253 | 08-19-2013 01:39 PM |
| Official MMA Thread | zigzagz94 | Off-Topic Lounge [WARNING: NO POLITICS] | 11 | 12-15-2009 11:59 PM |
