#1947 | |
Super 86
Drives: Red 86 GTS
We'll see, either way more options are better. The only info i was able to extract on date is "soon" some bugs to work out and the car sounds pretty rough at the moment.
230rwhp/184ftlb on 98RON/93AKI
Build thread Red 86 GTS MT | Sprintex Intercooled Twin Screw SC | Invidia N1 | Mocal 10 row | Invidia Front Pipe | Motiv Overpipe| Enkei RPF01 with Bridgestone RE002s | MCA Blue Coilovers | Radium Catch Can |
#1948 | |
Agreed with the rest.
#1949 |
Master Tuner
Drives: GT86 + Celica ST205 GT-4 WRC + MR2
we are almost ready with our basemapping for the KW kit, car runs very good allready and has some big grunt lolz, but we need the upgrade map sensor to go any further as it it now leaning out over about 400grams of boost.
we are using romraider + OFT KW supercharger system SARD equal length decat manifold SARD catpipe Milltek catback Mishimoto low temp thermostat Does anybody have the Honda part number for the upgrade denso map sensor? |
#1950 | |
Honda #: 37830-PK-A01 =)
When I grow up, I wanna be God. My flickr - Canibeat Local magazine scout Old Setup: Vortech Supercharged 360WHP/262WTQ @ 11.5psi My build thread - WTF happened to nelsmar's car thread |
| The Following User Says Thank You to nelsmar For This Useful Post: | ST-A (07-14-2014) |
#1951 | |
Drives: 2013 FRS
| The Following User Says Thank You to Shiv@Openflash For This Useful Post: | ST-A (07-14-2014) |
#1952 |
I have a 2013 Limited BRZ and was wondering if any of you guys w/ push to start have problems starting your car after the flash? I'm just running the stage one flash
#1953 | |
Master Tuner
does that sound about right? |
#1954 |
Drives: 2013 FRS
#1955 |
Master Tuner
have to check to be sure but it looks like it. the KW pipe is same size as throttle body
#1956 | |
Follow direction on OFT (or flash software) after flash is completed turn car completely off. Then turn on (don't touch accelerator),wait about 20 sec, should start straight up, let it idle for a minute or two (no throttle), then your good to go. see here http://www.ft86club.com/forums/showthread.php?t=68328 if your LTFT are large it might be worth scaling MAF, shortens up fuel trim learning process after flash or reset also get smoother drive and AFR closer to those set in OL Fuel tables. http://www.ft86club.com/forums/showthread.php?t=64790 |
| The Following User Says Thank You to steve99 For This Useful Post: | lookchris (07-15-2014) |
#1957 | |
My cars been flashed for awhile. It just started out of no where recently. My guess is it might just be my switch
#1958 | |
aeiou
Drives: WRB BRZ
So will there ever be a BPB, E85, UEL/EH tune in the works? Or do you guys just run the stage 2 map?
#1959 | |
BPB move the powerband lower in the rpm range and E85 produces its best power above the rpm range where BPB work best, so it was counter productive. Same deal for BPB and forced induction eg electric SC |
#1960 |
just flashed my 13 limited brz with the stage 1 rom. drove the car easy for a few miles to get the car to learn a bit. gave it a good 3rd gear pull and the power is very smooth. it may just be me or the car hasnt fully learned but it doesnt seem like the vvl doesnt kick in as hard. ill try to get some logs today. what exacly needs to be logged? thanks
| Tags |
| cat overtemp |
| OpenFlash Tablet | Rombinhood@OpenFlash | Software Tuning | 1838 | 07-29-2023 07:35 PM |
| OpenFlash Tablet Stg 2 Tune (Dyno Progress) | Rombinhood@OpenFlash | Software Tuning | 26 | 10-24-2013 02:19 PM |
| FBM Tuning fixed my issue, FA20 and Visconti didn't work as well | whitefrs | Forced Induction | 253 | 08-19-2013 01:39 PM |
| Official MMA Thread | zigzagz94 | Off-Topic Lounge [WARNING: NO POLITICS] | 11 | 12-15-2009 11:59 PM |
