86WORX
Old 06-28-2014, 01:23 PM   #1919
nelsmar
Originally Posted by ST-A View Post
does anybody know if the stock MAP sensor can also be rescaled so it can read about 1bar/15psi? stock it seems it can read up to 0.4bar
or do i need the denso/honda K20 map sensor?
You are going to need a larger sensor tha a k20 sensor for 1bar of boost.
My flickr - Canibeat
Local magazine scout
The Following User Says Thank You to nelsmar For This Useful Post:
ST-A (06-29-2014)
Old 06-29-2014, 06:53 AM   #1920
ST-A
Master Tuner
Drives: GT86 + Celica ST205 GT-4 WRC + MR2
i had a spare 2007 STI map sensor here so installed that one instead of the K20.
looking in the STI rom they state :
offset: -0.5520 bar absolute
multiplier: 0.6855 bar absolute / V
i converted it for the GT86 into:
offset: -8.006 psi absolute
multiplier: 9.942 psi absolute / V
Does that sound right?
I then also changed last colums in O/L fueling and ignition adv A & B maps to 1.6 and 2 (engine load) to have 1bar of boost in the maps
Does that sound OK ?
ST-A is offline   Reply With Quote
Old 06-29-2014, 11:20 AM   #1921
ST-A
Master Tuner
ok got the STI map sensor working, didn't start at first but i switched + and ground on the sensor, so fixed now and car starts and revs, but overfueling quite a bit, fuel trim -10% so need to rescale the maf down again.
The Following User Says Thank You to ST-A For This Useful Post:
Luckrider (06-29-2014)
Old 06-29-2014, 03:27 PM   #1922
themajesticone
themajesticone's Avatar
Drives: '13 UM86
How does this look? Just to remind everyone my set up is as follows:
Stock Header
Stock OP
HKS Dual Resonated Front Pipe
WORKS Mid Pipe (2.5")
WORKS Exhale Axle Back (2.5")
http://datazap.me/u/themajesticone/run-1?log=0&data=1
themajesticone is offline   Reply With Quote
Old 06-30-2014, 04:57 PM   #1923
Triumphrider
Triumphrider's Avatar
Drives: 2013 Scion FRS in white out
Just curious as I uploaded my stage 2 uel map today and found that when I went to look at my live data I could see the data however the words (labels) next to it were missing. Any ideas how to correct this?
2013 Scion Frs AT in Whiteout, Borla UEL header, Greddy SP Elite AxleBack. Kraftwerks C38 Supercharger tuned by Moto East and 2 kid seats in the back.
Triumphrider is offline   Reply With Quote
Old 06-30-2014, 05:13 PM   #1924
troek
troek's Avatar
Drives: 2012 Toyota 86
Sometimes just unplugging it fixes that
Old 06-30-2014, 07:19 PM   #1925
Malt
Drives: 2015 WRX
Sounds like you need to update the template file. You can download it off the same page you get the maps from.
Malt is offline   Reply With Quote
The Following User Says Thank You to Malt For This Useful Post:
Luckrider (06-30-2014)
Old 06-30-2014, 07:21 PM   #1926
Triumphrider
I'll have to look at again tonite. Overlooked something
Old 07-01-2014, 05:50 PM   #1927
Triumphrider
Hmmmm plugged in my laptop, let everything update to be sure but still getting this. Not sure where the info went?
Old 07-01-2014, 05:57 PM   #1928
Malt
Drives: 2015 WRX
You have to manually download the template file from openflashtablet.com, click upgrade within open flash manager, and select that file you downloaded. That should fix your issue.
Sent from my SCH-R970C using Tapatalk
Old 07-01-2014, 06:00 PM   #1929
Triumphrider
The thing is though I have not downloaded any files specifically, other than what auto updates when I connect to my laptop.
Old 07-01-2014, 06:07 PM   #1930
Malt
Drives: 2015 WRX
One of the auto updates changed some things and you'll need to apply the template update manually.
Shiv@Openflash (07-01-2014)
Old 07-01-2014, 06:09 PM   #1931
Triumphrider
Thanks, I'll play with this some more. I'm definatley not tech savvy when it comes to computers.
Old 07-01-2014, 06:09 PM   #1932
steve99
@Malt speaks the truth, you need to download updated template file manually it just won't do it automatically.
from here
http://openflashtablet.com/products/...ads/index.html
third link on page
cat overtemp
Search this Thread:
Advanced Search
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 07:35 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 02:19 PM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 01:39 PM
