#1891 |
Newb
Drives: 2014 BRZ SWP
Fair enough, is 50 miles enough to get a good log? Not trying to be difficult, just truly don't know how the ecu learns and how fast.
#1892 | |
Drives: 2015 WRX
EDIT: Also you can change what you log. It probably would be helpful to log FLKC and knock correction instead of VVT intake and VVT exhaust. If you are seeing some knock correction or FLKC then that would explain why your IAM is below 1. |
| The Following User Says Thank You to Malt For This Useful Post: | YEAHdams (07-29-2014) |
#1893 |
Newb
For the sake of science, I took another log after 40 miles total on the tune this time logging FLKC and KC. The adv multiplier is now at .72. So we're headed in the right direction. Thanks Malt for the advice, I'll log again at 75 and then 100 miles.
http://datazap.me/u/netrunner/2nd-lo...1432&mark=1257 |
| The Following User Says Thank You to Netrunner For This Useful Post: | YEAHdams (07-29-2014) |
#1894 | |
To speed up learning do about 3 easy steady partial throttle (not wide open) runs in 2nd or 3rd gear from about 2000 rpm to 5000 RPM and your IAM will get to one. the knock looks pretty minimal, but with your driving below 2500 rpm steady throttle then just going WOT to the higher rpm the ecu is not getting to learn, it learns much faster in "closed loop mode " ie steady throttle driving/cruising (non wide open throttle) but you just need to up the rpm a bit while your cruising. |
#1895 |
Newb
Steve is smart
![]() http://datazap.me/u/netrunner/third?...1-2-10&solo=10 Does everything else look ok now? Thanks |
#1896 | |
there is a very small amount of knock about 6400-6500 and a bit about 6700 rpm see the chompy bits out of the kc learned curve. The FLKC logging is still not working but you can work it out from kc learned. Looks like is only about -0.7 degrees so it probably ok and the fine learning knock control will probably sort that after a bit more time if it keeps happening. http://datazap.me/u/netrunner/third?...zoom=1269-1383 Did a thread on knock control here http://www.ft86club.com/forums/showt...ock+australian |
#1897 |
Drives: BRZZZ
Is it normal for my ltft to be around 15 at idle? Im on my second tank of e85 and noticed that my ltft rose compared to my first tank which stabilized to lower than 10 which Ive read would be safe. Should I reflash and start again?
#1898 |
Drives: 2015 WRX
That's not normal. Do you have an aftermarket intake? LTFT's should be +- 5%
#1899 |
Drives: too soon junior
Just picked up my OFT today. So I'm using the B01C map, can I upload the A01C map with LC, FFS, and the rest? OFT won't even let me put the A01C map on the device itself?
#1900 |
Drives: 2015 WRX
| The Following User Says Thank You to Malt For This Useful Post: | BolognaWalrus (06-22-2014) |
#1901 |
Drives: BRZZZ
#1902 |
Drives: 2015 WRX
#1903 | |
Drives: BRZZZ
Sent from my LG-E980 using Tapatalk |
#1904 | |
Drives: 2015 WRX
Sent from my SCH-R970C using Tapatalk |
| Tags |
| cat overtemp |
| OpenFlash Tablet | Rombinhood@OpenFlash | Software Tuning | 1838 | 07-29-2023 07:35 PM |
| OpenFlash Tablet Stg 2 Tune (Dyno Progress) | Rombinhood@OpenFlash | Software Tuning | 26 | 10-24-2013 02:19 PM |
| FBM Tuning fixed my issue, FA20 and Visconti didn't work as well | whitefrs | Forced Induction | 253 | 08-19-2013 01:39 PM |
| Official MMA Thread | zigzagz94 | Off-Topic Lounge [WARNING: NO POLITICS] | 11 | 12-15-2009 11:59 PM |
