86WORX
Old 05-29-2014, 01:58 PM   #1821
Victor Draken
Drives: Toyota Gt86
Why Am I getting P0420 code if I have stg 2 EL?
Victor Draken is offline   Reply With Quote
Old 05-29-2014, 02:18 PM   #1822
Malt
Drives: 2015 WRX
Pretty sure shiv reenabled those codes so people could tell if they had exhaust leaks or not. I might be mistaken though.
Malt is offline   Reply With Quote
Old 05-29-2014, 02:31 PM   #1823
Victor Draken
Drives: Toyota Gt86
I think you are right
Old 05-30-2014, 04:46 PM   #1824
spdbydesign
spdbydesign's Avatar
Drives: 2010 Nissan GTR
Vishnu OFT Tune Coming Soon for the SBD Turbo Kit!
Vishnu Tuning/ Speed By Design announce upcoming OFT (Open Flash Tablet) support for the SBD FT86 Turbo Kit!
We are so excited to partner with Vishnu, who has been a staple in the import community for numerous years.
With the sales success of the OFT Tablet, via Shiv's quality tuning, we aim to enhance the already incredible value of the SBD FT86 Turbo Kit.
Today, the development vehicle is being delivered to Vishnu and development work will begin next week.
Special thanks to Neal @EQ Tuning for the quality install on the development FRS.
http://www.ft86club.com/forums/showthread.php?t=66574
http://www.ft86club.com/forums/showthread.php?t=58514
Have a great weekend everyone, stay tuned!
Chris Riggs
spdbydesign is offline   Reply With Quote
The Following 5 Users Say Thank You to spdbydesign For This Useful Post:
8686 (05-30-2014), Cross (05-30-2014), DC2R (05-30-2014), Luckrider (05-30-2014), MoogDiesel (05-31-2014)
Old 05-30-2014, 04:54 PM   #1825
phrosty
Check AFR at WOT above 5500rpm is no leaner than about 12 (assuming your N/A) most people would say tune for 12.5 or 12.7 but these motors tend to knock any leaner at higher rpm. arroud 11.8-12 is shiv's target for N/A on petrol maybe 12.2 on E85
Assuming you've scaled your MAF and have fuel trims as low as can be, what ways are people getting these values adjusted?.
On a 3rd gear pull NA with 93 gas, I'm getting 12.5-13 above 5500 with an LTFT less than 1%. I'm working on correcting that 1% but I don't think that'll be enough to bump me to 11.8-12.
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
phrosty is offline   Reply With Quote
Old 05-30-2014, 05:02 PM   #1826
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Cool! Will there be OFT only programming or a piggyback?
Old 05-30-2014, 05:05 PM   #1827
spdbydesignchris
spdbydesignchris's Avatar
Drives: 2013 BRZ Premium
The tune will be available through the download page on Vishnu's website, free of charge.
But you will need the OFT programmer, which is $499.
http://www.openflashtablet.com/produ...ads/index.html
spdbydesignchris is offline   Reply With Quote
The Following User Says Thank You to spdbydesignchris For This Useful Post:
solidONE (06-02-2014)
Old 05-30-2014, 05:30 PM   #1828
steve99
Once your lft is around 1-2 percent your AFR should follow the values in the OL Fueling table (plus the fuel trim percent), of not then you OL maf scaling is out at the top end.
The LTFT is determined by error in closed loop. Generally your not in closed loop above about 5000rpm.
VGI's utility should sort this for you if you do about 3, 2000-7000 rpm runs and input the data.
Once ol/cl maf scaling right then you can adjust the OL fuel table to your desired AFR at the higher rpm/load
Shiv tends to run his tunes on the rich side for safety and knock resistance, you really need a dyno to see if your making/losing power with your afr changes, and do your logging to see it stays knock free high rpm
There is a little bit of knock evident by chunk out of kclearned curve between 6400-6700 looks like about -0.8
Old 05-30-2014, 08:33 PM   #1829
DC2R
Drives: 2014 Scion FR-S
Chris Riggs
Awesome news! Can't believe OTS turbo tune with only the tablet !
Sent from my SM-G900T using Tapatalk
DC2R is offline   Reply With Quote
Old 05-31-2014, 10:57 AM   #1830
spdbydesign
[ame="http://vimeo.com/96965759"]Customer's first Test Drive in his new SBD Turbo Kit Powered BRZ! on Vimeo[/ame]
The Following User Says Thank You to spdbydesign For This Useful Post:
jflogerzi (05-31-2014)
Old 05-31-2014, 11:17 PM   #1831
phrosty
Is there something other than the OL fuel table affecting this?
Shiv's OTS has between 12.4-12.5 at high RPM/load in the table, which doesn't sound like the safe "rich" description I've heard people give his tune. jamesm suggests high 11's, low 12's in the same area -- that's more what I was expecting.
The stock ROM actually seems to run considerably more fuel, going as rich as 10.1.
Old 06-01-2014, 12:35 AM   #1832
steve99
As far as i know ol fueling is determined by maf , ol fuel table and the stored ltft.
If your ltft is negligable and your ol maf scaling is good the commanded afr ie value in ol fuel table for that load/rpm should match the measured afr. Assuming the 02 sensor is good.
I dont know how the stocck rom could read 10.1 afr as the stock 02 scaling does not go that low, the oft guys did adjust the o2 scaling a bit to read in the 11 afr.
I also suspect that they deliberately use the top end ie the ol part of the maf scale to make their tunes run a bit rich.
As you have now scaled your maf correctly you have removed this , so if you now want to run 12.1 afr you will need to adjust the higher rpm load area of your ol fuel table from 12.4 to 12 or whatever you want to run.
As i said before this is where you rearly need a dyno to see if you afr changes make or lose power, while checking your knock free at higher rpm
also run it past @jamesm as he is a tuner and i am not :-):-)
The Following 2 Users Say Thank You to steve99 For This Useful Post:
akyp (06-01-2014), phrosty (06-03-2014)
Old 06-01-2014, 02:22 PM   #1833
jamesm
Open loop has nothing at all to do with any O2 sensor (aside from the high ltft bucket calculated in closed loop, if it's even enabled). The stock tune really is quite rich, but remember the map is scaled past what the stock car will ever see on the load axis (out to 1.4g/rev).
Deliberately jacking up the airflow model to achieve an AFR target would be very odd, and I can't imagine why anyone would do that.
The Following User Says Thank You to jamesm For This Useful Post:
Old 06-01-2014, 03:06 PM   #1834
Td-d
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
One very specific reason to shift the entire O2 scaling around, actually, but nothing to do with open loop as mentioned.
If you want to run higher than stoich AFRs in closed loop, it is not possible within the limitation of the OEM code. 14.7 is the leanest you can reach. To achieve leaner mixtures (for fuel economy), you have to manipulate the O2 sensor scaling.
Td-d is offline   Reply With Quote
cat overtemp
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 07:35 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 02:19 PM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 01:39 PM
