#1807 |
Dismember
Drives: 2013 Red Scion FR-S
Ah. I thought those were more a matter of clever settings.
#1808 |
Dismember
i bet vishnu tuning can set you up. they already managed it with the vortech. may as well get the whole setup from them since you have the oft already. As far as I can tell, the only actually bad setup is fa20club.
#1809 |
Drives: Whiteout FR-S
#1810 |
My Other Ride's a Jeep
Drives: 2013 BRZ Limited
What, you don't like running ~stoich under full boost?
| The Following User Says Thank You to Luckrider For This Useful Post: | Td-d (05-28-2014) |
#1811 |
Drives: 2014 FR-S 6MT Whiteout
So I think I know the answer to this question from sporadic reading of this thread but I'll ask it here anyway in hopes one of you wonderful smart people will confirm...I have an OFT coming later this week. Do I need to have my dealer flash my (Aug 2013 build-date) 2014 to whatever the latest USDM ROM is before I install the OFT, or does the OFT not care? I believe the answer is, it doesn't care. Thanks!
#1812 | |
| The Following User Says Thank You to steve99 For This Useful Post: | phobos512 (05-28-2014) |
#1813 |
Ok perfect that is what I thought. Thanks!
#1814 |
Dismember
Full boost? It's much better to run lean, ya know.
#1816 | |
Drives: 2013 Asphalt 6spd
I want to use the 93 tune with it comes out, but I wonder about the quality of our (local) 93. What should I look for in the log (eg. afr?, knock correction?) to make sure our gas is compatibale with the 93 tune? |
#1817 | |
If your IAM stays at 1 its a good start Then check for knock both flkc and fbkc, you may have to put up with max of about -0.7 occasionally in 2000-3500 rpm area but outside that rpm range should be clear of knock. see here http://www.ft86club.com/forums/showthread.php?t=61820 |
| The Following User Says Thank You to steve99 For This Useful Post: | Target70 (05-28-2014) |
#1818 | |
Dismember
#1819 |
Drives: Neptune GR86
Is it normal for AFRs to be hitting up to 20?
Been seeing it on the stage 1 as well as the stage 2 UEL tunes. I'm on 92 octane. http://datazap.me/u/andrew025/stage-2-uel http://datazap.me/u/andrew025/4-12-2...8?log=0&data=1
#1820 |
you should only see 20's under deceleration, not partial or wide open throttle
How ya gonna keep 'em down on the farm once they've seen Karl Hungus? |
| Tags |
| cat overtemp |
| OpenFlash Tablet | Rombinhood@OpenFlash | Software Tuning | 1838 | 07-29-2023 07:35 PM |
| OpenFlash Tablet Stg 2 Tune (Dyno Progress) | Rombinhood@OpenFlash | Software Tuning | 26 | 10-24-2013 02:19 PM |
| FBM Tuning fixed my issue, FA20 and Visconti didn't work as well | whitefrs | Forced Induction | 253 | 08-19-2013 01:39 PM |
| Official MMA Thread | zigzagz94 | Off-Topic Lounge [WARNING: NO POLITICS] | 11 | 12-15-2009 11:59 PM |
