#43 |
Junior
Drives: a car
An option is to get the B14 then revalve them to stock spec, or slightly fermer to offset the height difference. The progressive rates are the best for comfort. Not nessecarily the best for performance though.
#44 | |
Drives: FRS
#45 | |
Time Traveller
I set mine to the settings in boldface below from @Moto-P
Out of the box the coils are usually set to 50% from full soft/hard on both the fronts and rears (even the ones that are supposed to be set to "Moto-spec"). Both mine and my buddies @WRB5titch came this way. @Moto-P explains in this post how to properly set them up for road and track http://www.ft86club.com/forums/showp...2&postcount=11 Quote:
#46 | |
Drives: FRS
#47 | |
Time Traveller
I think you might actually have preferred something sprung softer like STs which are sprung at 5k front /6k rear IIRC. |
| The Following User Says Thank You to DAEMANO For This Useful Post: | Moto-P (04-26-2015) |
#48 |
how low are you? are you sure you are not experiencing bump steer?
#49 |
Drives: FRS
20mm lower. -2.3 front -1.5 rear. Corner balanced.
#50 |
Time Traveller
#51 |
Drives: 1993 Impreza w/ WRX Swap + FWD!
#52 |
Have you considered getting the dampers properly adjusted by a professional?
#53 |
Drives: FRS
#54 |
Drives: FRS
#55 |
Drives: FRS
No idea where to go for that. I suppose you would offer that service to me but you are on the other side of the state. Corner balance and alignment were done professionally. PM me what, if anything, you can do.
| The Following User Says Thank You to wootwoot For This Useful Post: | cdrazic93 (04-26-2015) |
#56 |
Time Traveller
That's about perfect for DD. I don't know what to tell you in regards to the back end getting loose on fast corners. Mine feels practically glued, even on So Cal's horrible highways. Last question would be what tires are you running? Like @CSG_Mike suggested, I would definitely take it to a pro that is familiar with your coils. If it's not setup properly than the only thing I can think of is that there is a chance that you got something defective.
| Coilover Review: FEAL SUSPENSION 441 coilover kit | mr. slim | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 39 | 11-28-2019 07:30 AM |
| What coilover should i get | ric342 | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 06-18-2013 01:36 AM |
| Coilover Help | Legacy | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 05-18-2013 04:30 PM |
| Lowering gear, AND keeping comfortable | MarkMash | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 07-17-2012 03:12 PM |
