#30 |
Drives: FRS
ohh lol then i think i hear mine hahah but i mean i been beating the hell outa mine tho! and you guys see the power i make on my sig. Mine only happens when i move off just for like a second or like a click or 2
#31 |
Drives: A lot of supercars.
#32 | |
Shipping to Hawaii?...
Drives: '13 Asphalt FR-S
~Matt
Efimia (asphalt FRS) |
#33 |
Just the tip
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
i'm having trouble finding the torque numbers for the various rear axle related bolts. Could you provide them? I'm having the click/tick noise when starting from a stop and sometimes when changing gears and would like to try tightening them first before I drop $$ on a new axle.
Current: 2013 Lightning Red Subaru BRZ Limited
Past (sold): Click here to see previous cars and bikes ![]() |
#34 | |
Senior Addict
Drives: 86 GT
If you're referring to the 4 rear hub/bearing bolts, I think that's 50 ft-lbs. |
| The Following 2 Users Say Thank You to Fizz For This Useful Post: | DAEMANO (09-08-2014), stockysnail (06-02-2014) |
#35 |
#36 |
Drives: 2013 Subaru BRZ
So any aftermarket axles out there that are better?
My car is mostly stock and I'd rather not put another set of stock axles on if the cv is just gonna blow out again in another 20k
Build Thread:
http://www.ft86club.com/forums/showthread.php?t=43355 |
#37 |
I Love custom Turbo kits
Drives: Limited BRZ
Driveshaft Shop
#38 | |
Drives: Scion FR-S
Here is how I've been doing it: 1) I have a bearing splitter that I got from Harbor Freight (to pull the bearing off of the pinion gear). I put that around the end of the axle that is solid (black). Do not put it around the dust cover (silver). ![]() 2) I then use a pry bar between the diff and the bearing splitter and wiggle it furiously until it unseats the axle from the diff. Then it just slides off. To put it back into the diff, I just hit the edge of that black piece on the axle until it seats back into the diff. You should replace the circlips if you follow the factory service manual recommendation (I'm betting the new axles come with them). |
#39 | |
Just the tip
#40 |
Drives: Olive Drab/Army FRS
I've broken two axles, stock and Driveshaft Shop. It boils down to the car being lowered mostly. Whenever you lower the car the axle geometry gets completely messed up. It puts too great of an angle on the inner CV joint which causes the cradle holding all the ball bearings to break. Best way to remedy this if you want to be low is to buy the PBM Subframe and Diff Risers. I went thru hell and back though to use these with my DSS axles.
When the DSS axles "broke" they froze/seized at the outer joint. Not sure the reasoning behind this but thats what happened. I have a full write up on my adventures into solving the infamous clicking noise here.
QUALITY OVER QUANTITY Last edited by ShutterSpeed; 12-26-2014 at 12:58 PM. |
#41 |
Drives: Scion FR-S
I was removing the diff, so I unbolted the diff and was able to detach the axles to remove it. But if you are removing the axle for replacement, I imagine you'd leave the diff bolted up and remove the hub components to get the axle out.
| The Following User Says Thank You to kodyo For This Useful Post: | stockysnail (12-26-2014) |
#42 | |
Drives: brz
1. Jack up car and support with jack stands. 2. Remove the wheel on the side you will be replacing the axle on. Pull the ebrake and remove the axle nut, you need a 32mm socket. 3. Jack up the lower control arm in till your shocks start compressing and the whole car raises just slightly. This puts the axle in a angle and makes it easier to remove. 4. I use a harbor freight 24in tire iron and rubber mallet to pull the axle from the differential, super easy you just need one good hit. (Axle won't come off completely you only need to pull it 2 or 3 inches) 5. Now you need to support the differential with a jack and unbolt the 5 bolts that holds it in place, 2 on the side and 3 on the rear. Impact gun makes the job easy. 6. Start lowering the differential in till you have enough angle for the axle to pop off. Make sure diffrential doesn't tilt to the side or it will leak oil. 7. To remove the other side of the axle you just give it a small tap where you remove the 32mm nut and pull it out of the hub assembly. To reinstall new axle just follow instructions in reverse order. |
| The Following 5 Users Say Thank You to ysr50guy For This Useful Post: | ChrisD (04-29-2015), DAEMANO (01-01-2016), DocWalt (01-05-2016), stockysnail (03-02-2015), Sypher (10-18-2018) |
| DIY Request: Axle Removal/Replacement | xjohnx | DIY (Do-It-Yourself) Guides | 10 | 09-22-2016 07:30 PM |
| DriveShaft's and Axle's | Driveshaft Shop | Engine, Exhaust, Transmission | 34 | 08-21-2013 06:17 PM |
| axle back install | abutterman | NY / NJ / CT / PA | 10 | 03-29-2013 08:38 PM |
| Stock brz axle back | norcal_brz | Engine, Exhaust, Bolt-Ons | 0 | 01-03-2013 08:09 PM |
| Axle Nut Specs? | cobrabyte | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 0 | 11-26-2012 09:03 PM |
