Old 09-07-2013, 08:22 AM   #15
StormTrooper
StormTrooper's Avatar
Drives: Pavement MT GR86
Are any of you still at stock power levels?
Seems a bit early for a cv joint.
GR86 MT premium
StormTrooper is offline   Reply With Quote
Old 09-07-2013, 09:05 AM   #16
448hpsti
In Test:Oil Fed SC
448hpsti's Avatar
Drives: Vortech Prototype Test Car
Where is a vendor that can offer an upgraded part for lowered higher powered cars?
448hpsti is offline   Reply With Quote
Old 09-07-2013, 09:56 AM   #17
Chimpo
Chimpo's Avatar
Drives: '15 STi Ltd
He mentioned he wasn't trying to warranty it because he has a supercharger on his car.
Chimpo is offline   Reply With Quote
Old 09-07-2013, 10:24 AM   #18
ZionsWrath
Thanks
ZionsWrath's Avatar
Open yours and let us have a look please. Are you on stock ride height?
Old 09-07-2013, 10:44 AM   #19
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
Stockish power levels. Just a flash and mine went.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 09-07-2013, 10:55 AM   #20
ZionsWrath
Thanks
ZionsWrath's Avatar
Are you guys tracking, drifting, or just regular DDing?
I WOT a lot and drive rather quickly but my traction control hardly ever engages (I never turn it off on regular roads). Just curious what conditions and if I'm going to see problems. I guess it helps that I am running gripless all seasons or maybe it hurts as I'll have less traction
Old 09-07-2013, 12:10 PM   #21
StormTrooper
Not sure how you drive it with stock tires and tc on.....with better tires sport mode seems to be useful for the first time otherwise it was overbearing and full tc was useless.
What about the ride height ? Slammed cars or stock?
GR86 MT premium
Old 09-07-2013, 12:17 PM   #22
ZionsWrath
Thanks
ZionsWrath's Avatar
Its 235/255 DWS tires, I don't try to get sideways and my tires squeal like a pig ans TC doesn't kick in.
Only one time it started to get sideways and I tried to put the power down and TC locked me down ended up stopped sideways on the curve. lol
Old 09-07-2013, 01:21 PM   #23
xjohnx
Grip>Slip
xjohnx's Avatar
I was on stock power when it started clicking, a couple weeks before i got the SC installed.
Old 09-07-2013, 01:39 PM   #24
ZionsWrath
Thanks
ZionsWrath's Avatar
Originally Posted by vteclol View Post
100% stock
What did dealer say for warranty?
Old 09-07-2013, 02:15 PM   #25
Carwhisperer
Drives: A lot of supercars.
Other than a CAI im stock.
Carwhisperer is offline   Reply With Quote
Old 09-07-2013, 02:23 PM   #26
meeks
slide to unlock
meeks's Avatar
Drives: 2013 FR-S Raven Black
Getting mine replaced under warranty. However, dealer said the part is back ordered and i have to wait for a month or so. Noise is getting worse.
meeks is offline   Reply With Quote
Old 09-07-2013, 02:27 PM   #27
ZionsWrath
Thanks
ZionsWrath's Avatar
The first dealer said it was normal. The second dealer re-tightened the axle nuts, which made the clicking go away for a few days (doesn't really make sense to me, but the sound did go away).
I'm about the two weeks out, and the joint seems very "loose" now. Any halfway decent acceleration and it will click. I've started to get two clicks on medium to heavy throttle changes, which might be the LSD engaging/disengaging. I'll be surprised if the dealer doesn't replace the axle on the next visit, if it isn't broken by then.
Please keep us updated, the warranty on drivetrain is 5 years/60k miles so I am very interested how this turns out on a stock car. I want FI but at the same time want to expend the factory drivetrain warranty just in case...
Old 09-07-2013, 02:30 PM   #28
lexusb3
Drives: FRS
is this clicking everything time you drive or only when you move off example from a light or dead stop???
lexusb3 is offline   Reply With Quote
DIY Request: Axle Removal/Replacement xjohnx DIY (Do-It-Yourself) Guides 10 09-22-2016 07:30 PM
DriveShaft's and Axle's Driveshaft Shop Engine, Exhaust, Transmission 34 08-21-2013 06:17 PM
axle back install abutterman NY / NJ / CT / PA 10 03-29-2013 08:38 PM
Stock brz axle back norcal_brz Engine, Exhaust, Bolt-Ons 0 01-03-2013 08:09 PM
Axle Nut Specs? cobrabyte Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 11-26-2012 09:03 PM
