Old 09-04-2013, 05:24 PM   #57
Adeets
OEDC
Adeets's Avatar
Drives: Vortech 8.5psi 274WHP 2013 BRZ
Toni has my rev limiter at 8000 RPM on my FA20club tune just like Visconti did. I have been running to 8000 RPM for 15,000 miles now.
Why though? Your torque peak was at 5700 ish I thought.
I really hate YouTube Dynos, you have an updated one by chance?
My BRZ FI Build
Visconti is like a Tick that sucks as much blood(money) as he can before you figure out he's there.
please make sure to leave your experiences with visconti on his feedback thread located here: Visconti feedback
Adeets is offline   Reply With Quote
Old 09-04-2013, 05:28 PM   #58
phloozy
phloozy's Avatar
Drives: Scion FR-S
I think the first step is to forget this numbers game. Both kits will be a great match for this car. The car was designed to take corners like a champ not to be an outlet for dyno readings and **** waving. Want big numbers, go turbo. Don't want to be checking under your hood every other week or worry about your clutch and tire grip, go for the SC that works for you financially.
I have trouble keeping my wheels on the ground with e85 and stock exhaust on the innovate kit. Add a smaller pulley to the equation and I will be left where this car was never supposed to go, too much power to have fun flinging around local roads.
phloozy is offline   Reply With Quote
The Following User Says Thank You to phloozy For This Useful Post:
Turbowned (09-04-2013)
Old 09-04-2013, 05:29 PM   #59
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Area under the curve and how many revs are dropped during a shift. When I shift at 8000 RPM I generally fall down to around 5800 RPM I believe. That lets me utilize the largest hump of my horsepower curve. My dynos aren't on YouTube. They are images I made in Dynojet's WinPEP software:
The Following User Says Thank You to King Tut For This Useful Post:
Adeets (09-04-2013)
Old 09-04-2013, 05:31 PM   #60
Turbowned
Turbowned's Avatar
Read your post again and realize what you just said.
OK, should have said "continues to climb in a linear fashion"? Upon further inspection it doesn't increase that much after 7400rpm, but it does increase.
Old 09-04-2013, 05:31 PM   #61
Adeets
OEDC
Adeets's Avatar
Completely disagree, even with bigger stickier tires I still can drift a corner at 20mph. It's just now I can pass cars on a dotted back country road.
My BRZ FI Build
Old 09-04-2013, 05:33 PM   #62
phloozy
phloozy's Avatar
Drives: Scion FR-S
Oh my problem is im always drifting now lol
Old 09-04-2013, 05:37 PM   #63
Adeets
OEDC
Adeets's Avatar
No I was more of hinting you were recommending some visconti has done as a good idea.
King tuts answer is so far the only reason that I think is suitable at this point, higher rev shift drops him into his power band, so I'd take that on a case by case basis.
My BRZ FI Build
Old 09-04-2013, 05:40 PM   #64
Adeets
OEDC
Adeets's Avatar
You need to update your signature my friend, I followed it to your build post, which lead me to a YouTube dyno, with no actual dyno on it.
Also why did you part ways with visconti?
My BRZ FI Build
Old 09-04-2013, 05:43 PM   #65
Robftss
Drives: VW
Any chance can I get you to break down that formula into designations, mainly I don't know why you divide psi by 229.
It's derived to give result Power in Horsepower units, I'd have to dig out my fluid dynamic text.
Actually its (CFM x PSI)/229. sorry. so either variable has equal effect.
Robftss is offline   Reply With Quote
The Following User Says Thank You to Robftss For This Useful Post:
Adeets (09-04-2013)
Old 09-04-2013, 05:46 PM   #66
Adeets
OEDC
Adeets's Avatar
You know what course an electrical engineer doesn't have to take... Going back for my masters so maybe I'll dip into the mechanical side of the house, I think it would be helpful in my gear wrenching.
My BRZ FI Build
The Following User Says Thank You to Adeets For This Useful Post:
Robftss (09-04-2013)
Old 09-04-2013, 08:51 PM   #67
Dezoris
Dezoris's Avatar
Originally Posted by sw20kosh View Post
This is incredibly messy Dezoris what are you doing.
I am starting to think you are getting very biased...
You don't need E85 to reach 220 whp on the twin screw. I almost reached that with 91 octane (216) with just a cat back.
93 octane to reach 205 whp?
Moto-mike tuned a vortech to 275 whp on 92 octane. I guess he is "in bed" with vortech too...
You are kind of right, its turned into bias. And partly because I have spoken to tuners, shops, Innovate and owners. On top of that having Ecutek straight up say the Innovate kit basically should not have been released non intercooled.
This thread was about what kit to get. And what I am trying to say is Moto Mike posts his highest dyno plots, when asked obvious questions like how repeatable are those results or providing more technical detail it does not happen. Its misleading, same crap from innovate. They straight up told me "dont worry about heat, its not an issue." What it comes down to is these guys are doing one thing, banking on the low buy in price. They dont want to answer real questions.
Thats why I refuse to test it. Was even offered the kit by 3 people now for half off.
This kit has some of the worst transparency and facts. On top that the guys making the most power all are running E85 and meth to keep the car stable for anything more than street driving.
E85 is great but it kills MPG and there are zero long term studies on how it effects the fuel system on this car it was not tested to run on.
It will be a different story when they release the kit as it was intended by Sprintex/Bullet.
Old 09-04-2013, 09:38 PM   #68
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Originally Posted by Dezoris View Post
Not knocking it but Moto-East is in bed with Innovate.
Secondly Moto-East posts about as much detail about his testing and tuning as Innovate does. They are both good at talking about dyno numbers that's about it.
I would love to see the same results replicated more than 2-3 pulls with the hood closed back to back after the kit heat soaks.
Ok, this is rather comical. You've obviously not met myself nor really seen what we do in its entirety.
There's a whole thread that is completely open about everything, and we have dyno numbers good and bad, and I've never been shy to post up a crooked vortech graph nor a wobbly innovate graph. You can see both get better with time as I have made clear that tunes get better with time. Several owners will attest to this. As for this hood shutting business, it is absolutely ridiculous to do this on a dyno. AEM markets this in the CAI development, but we're not developing a CAI, we're testing blowers. From an engineering perspective, unless you have an 80 MPH windtunnel to simulate the correct pressure gradients that are generated at highway or track speeds, then all you're simulating is being on a hot dyno. We want the dyno to simulate the road, not the other way round. And for the record the AEM one is only 40 MPH. Still crap.
I normally wouldn't waste time replying to this kind of stuff, but you've been well intentioned with your skepticism which I enjoy, so I will assume you just don't know how we operate. If we were in bed with vendors you'd see way more products in our store, and frankly that's the lat image I'd want to leave anyone with. It is almost as bad as RMAs.
Now back on topic, the innovate kit will be maxed as is at 285 - 300whp. A 70mm will go above the 15000 redline by 7500 rpm. This is on e85. Add an intercooler and you're only adding restriction when it comes to e85, so your ultimate HP will be slightly less. On pump, you'll maybe hit 275 intercooled with meth. My theory.
Vortech will hit 300+ with the right supporting mods, and do it every day on a racetrack....as long as the pipes don't get eaten away by belts and whatnot. The blowers will take it. The IC is certainly big enough. Add e85 and 330+
Now for people talking about the track, how many put in the requisite $10k in gearing, driveshafts, suspension, cooling, and brakes to handle 300 track hp? Safety equipment? Lots of folks get out a time or two, but after a season when faced with a 4k brake kit, 250/tire that lasts 3 track days, gearboxes every year, axles, safety equipment....at that point it will be very few. Look at Grand-Am, world challenge teams...they spend 20k to prep a car with 200hp. And still have failures. Frankly with 300whp and a driver who is motivated, it won't make it past 20 minutes no matter the kit, unless you do the aforementioned.
For street use the innovate vs vortech kit is not that hard. Up top take vortech, midrange take innovate. Don't mind waiting a second or two for power down low? Turbo. The end.
Xero-Limit is offline   Reply With Quote
The Following 16 Users Say Thank You to Xero-Limit For This Useful Post:
Adeets (09-04-2013), civicdrivr (09-05-2013), diss7 (09-07-2013), fenton (09-04-2013), jamesm (09-05-2013), Mikem53 (09-05-2013), mxsled (09-04-2013), Ndgreely (09-10-2013), phloozy (09-04-2013), R2 (09-05-2013), Sonolin (09-06-2013), sw20kosh (09-04-2013), Toyota86.ir (02-15-2016), Turbowned (09-04-2013), whataboutbob (09-05-2013), Zach3794 (09-04-2013)
Old 09-04-2013, 10:00 PM   #69
Turbowned
Turbowned's Avatar
Thank you suh! I think that sets the record straight, but I still can't make up my mind...
Sounds like the Innovate kit can make the power I want even if it's a lofty goal, and it seems that the Vortech, although not as robust in the midrange as the twinscrew, should be a lot of fun especially in the top end. I'll probably start putting together supporting mods and decide on a charger in the next month or two.
Old 09-04-2013, 10:24 PM   #70
swift996
swift996's Avatar
Stop y'all whining...
[ame]http://youtu.be/o1aQICnesCI[/ame]
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
The Following 4 Users Say Thank You to swift996 For This Useful Post:
1010110 (09-04-2013), mxsled (09-04-2013), Ndgreely (09-10-2013), sw20kosh (09-04-2013)
Vortech Owner Thread & Setup Questions reyruiz191 Forced Induction 340 05-17-2022 01:44 PM
N/A power output potential as race setup? rice_classic Engine, Exhaust, Transmission 67 12-17-2013 08:03 PM
Abbey Motorpsort GT86 Sprintex installation Mark@Abbey m/s Forced Induction 18 09-07-2013 05:11 AM
WA Next meet Sun 30th June - Sprintex Test Drive AND A One Audio display plus special invisage Australian Meets & Events 2 07-22-2013 04:20 AM
Sprintex Supercharger Sneak Peak!!! invisage Forced Induction 52 03-03-2013 07:11 AM
