Old 09-04-2013, 04:45 PM   #43
Turbowned
Turbowned's Avatar
Originally Posted by xjohnx View Post
Nope. Another poster here (on the right coast). I'm sure he'll chime in with dyno's shortly.
Boy let's hope! This is exciting stuff. Seems like we're right on the cusp of seeing a lot of improvement with both blowers; perhaps it would be prudent to wait a month or two and make a decision then.
Seems like raising the factory redline is 100% necessary to enjoy the added power from the Vortech.
Old 09-04-2013, 04:48 PM   #44
sw20kosh
Drives: 2013 Black FR-S
Originally Posted by Dezoris View Post
Here is a guide for you:
Stock Car with Vortech
301HP+ (Sustained Usage, requires clutch, Fuel Injectors, pump, pulley)
300HP E85 (Smaller Pulley, Fuel Injectors Pump)(Clutch wear will be heavy)
270HP 93 Octane (Change Fuel Pump/Injectors)
250HP 93 Octane (No fuel system or other changes)
220HP 91/92 Octane (No Fuel System or Other Changes)
Stock Car with Innovate Non-Intercooled
300HP+ (Not Possible without intercooler if at all)
280HP E85 Octane (In Future)(Pulley Change Fuel Pump/Injectors/Meth Injection)(Clutch Wear Heavy)
250HP E85 Octane (Fuel Pump, Injectors)(Consider Meth Injection)
220HP E85 (No Fuel System or Other Changes)
205HP 93 Octane (No other changes)
190HP 91 Octane (No changes)
This is incredibly messy Dezoris what are you doing.
I am starting to think you are getting very biased...
You don't need E85 to reach 220 whp on the twin screw. I almost reached that with 91 octane (216) with just a cat back.
93 octane to reach 205 whp?
Moto-mike tuned a vortech to 275 whp on 92 octane. I guess he is "in bed" with vortech too...
The Following 2 Users Say Thank You to sw20kosh For This Useful Post:
mxsled (09-04-2013), xjohnx (09-04-2013)
Old 09-04-2013, 04:49 PM   #45
xjohnx
Grip>Slip
xjohnx's Avatar
Might be. I don't think you can really go wrong with either kit though. Both look to have great potential. It all boils down to personal preference in the end.
Old 09-04-2013, 04:54 PM   #46
jamesm
Originally Posted by fenton View Post
Nothing i said is incorrect. Running the smaller pulley increases drag on the engine(more parasitic drag). The charger is ran harder(more rpm), the gearbox is ran harder(more rpm).
I didnt say it would heat up the charge or make less power.
that's only half right. it is true that the supercharger is spinning faster, and wasting some energy (not to mention wear and tear) just moving air from one side of the engine bay to the other. that is incredibly stupid, i agree.
what is not correct is the idea that doing so increases parasitic drag substantially. it does not. you're still asking the supercharger to compress the air to the same pressure ratio, which is where the vast majority of the parasitic drag comes from, that effort to compress air. moving the extra (wasted) bit around is far less a factor. this is pretty much exactly how BPV's inside of blowers work, except they vent to the vacuum side of the blower rather than the atmosphere.
i'm not in any was suggesting it's a good idea.
Old 09-04-2013, 04:56 PM   #47
Adeets
OEDC
Adeets's Avatar
Drives: Vortech 8.5psi 274WHP 2013 BRZ
I in no way agree with that, if you look in the FI dyno thread or my build you can see there's plenty of meat to my tune above 4k.
My BRZ FI Build
Visconti is like a Tick that sucks as much blood(money) as he can before you figure out he's there.
please make sure to leave your experiences with visconti on his feedback thread located here: Visconti feedback
Adeets is offline   Reply With Quote
Old 09-04-2013, 05:09 PM   #48
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Don't get turbowned @Turbowned . You know what the right answer is.
The Following User Says Thank You to King Tut For This Useful Post:
fenton (09-04-2013)
Old 09-04-2013, 05:13 PM   #49
Turbowned
Turbowned's Avatar
Right but if you look at the plot on that Visconti video the power increases dramatically above 7k rpm; it would be a waste not to tap into that potential.
If you're implying that a turbo is the right answer, I'm afraid I'll have to politely disagree
Old 09-04-2013, 05:14 PM   #50
Adeets
OEDC
Adeets's Avatar
Get v-tuned?
My BRZ FI Build
Old 09-04-2013, 05:15 PM   #51
Adeets
OEDC
Adeets's Avatar
Read your post again and realize what you just said.
My BRZ FI Build
Old 09-04-2013, 05:16 PM   #52
Adeets
OEDC
Adeets's Avatar
Besides visconti do you know of any other "tuner" (I use that word loosely in this statement) that raises the max rpm?
290hp with only 200tq is just over spinning the motor.
My BRZ FI Build
The Following User Says Thank You to Adeets For This Useful Post:
448hpsti (09-04-2013)
Old 09-04-2013, 05:18 PM   #53
Robftss
Drives: VW
Here is the math:
Power to drive a compressor = CFM x PSI/229
By bleeding off a portion of the increased CFM's air to maintain pressure requires more drive power.
I hope Centri guys try it, it will raise TQ output in the lower/mid rpm range but sacrifice efficiency (parasitic) during bleed.
Robftss is offline   Reply With Quote
The Following User Says Thank You to Robftss For This Useful Post:
Adeets (09-04-2013)
Old 09-04-2013, 05:20 PM   #54
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Toni has my rev limiter at 8000 RPM on my FA20club tune just like Visconti did. I have been running to 8000 RPM for 15,000 miles now.
Old 09-04-2013, 05:21 PM   #55
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Move to a real state that doesn't do emissions testing.
swift996 (09-04-2013)
Old 09-04-2013, 05:23 PM   #56
Adeets
OEDC
Adeets's Avatar
Originally Posted by Robftss View Post
Here is the math:
Any chance can I get you to break down that formula into designations, mainly I don't know why you divide psi by 229.
My BRZ FI Build
Vortech Owner Thread & Setup Questions reyruiz191 Forced Induction 340 05-17-2022 01:44 PM
N/A power output potential as race setup? rice_classic Engine, Exhaust, Transmission 67 12-17-2013 08:03 PM
Abbey Motorpsort GT86 Sprintex installation Mark@Abbey m/s Forced Induction 18 09-07-2013 05:11 AM
WA Next meet Sun 30th June - Sprintex Test Drive AND A One Audio display plus special invisage Australian Meets & Events 2 07-22-2013 04:20 AM
Sprintex Supercharger Sneak Peak!!! invisage Forced Induction 52 03-03-2013 07:11 AM
