#15 |
Drives: 2013 FR-S Argento
I personally would like to see a TVS roots supercharger adapted for our motors.
#16 | |
![]() Seems like the Vortech only makes the difference between 7-7500RPMS, which I could give a crap less about since I don't use those RPM's frequently enough.Then again, it's not a totally apples-to-apples comparison as you were using E50 and a better header with the Innovate unit.
Current: 2005 Porsche 911 Carrera S 6MT Previous: 2 BRZ's, 997 C2S, C5 RS6, C4 S6, B8 S4, GDB STi, S30 240Z, FC3S RX-7 TII, AW11/SW20 MR2, E30 318is/325i, etc. |
#17 |
I've driven a few examples of both. The vortech has a little more surge up top, especially if tuned to rev to 8k rpms. They aren't far off but I feel like the innovate has more mid-range thrust/torque. So on the track I like that as in higher gears I can push the car forward with the throttle. They aren't drastically different in power/performance. I'd love to drive a 350whp vortech on E85 though, that would be a different ball game.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread) ![]() |
#18 | |
Drives: BRZ D4S 6MT L Vortech
| The Following User Says Thank You to v1ru5 For This Useful Post: | swift996 (09-04-2013) |
#19 | |
1337
Drives: 2013 BRZ WRB S/C
#20 |
Grip>Slip
#21 |
the innovate is not a good pick for 250-280whp. at least not as it is sold today and not on regular pump 91 or 93.
#22 |
I'm not looking at it as though I won't upgrade from the standard package, though. It's a question of how much headroom I have to improve. The Sprintex S/C is supposedly capable of handling up to 2bar of boost and is best paired with 1-2L engines. Exhaust/fuel/cooling/tuning upgrades should squeeze more potential out of it, but how much is what I wonder.
I'm kinda leaning more towards the Vortech because it seems a more common choice, it's readily available with an air-to-air intercooler, the unit can be upgraded to a larger one if need be, and the support network seems greater. It's just that everything I've read elsewhere tells me that a twin screw is the superior unit from a basic engineering standpoint. Oh and I know it's an incredibly stupid reason, but I like the packaging of the Vortech better; having the blower atop the intake plenum looks out of place if you ask me.
Current: 2005 Porsche 911 Carrera S 6MT Previous: 2 BRZ's, 997 C2S, C5 RS6, C4 S6, B8 S4, GDB STi, S30 240Z, FC3S RX-7 TII, AW11/SW20 MR2, E30 318is/325i, etc. Last edited by Turbowned; 09-04-2013 at 02:58 PM. |
#23 |
I think the Innovate kit is becoming more and more popular, just due to the simplicity and low cost of it. I don't think the IC is going to give tremendous results, just add a margin of safety on crappier gas. As for the coolant capacity, it's not hard to add a larger external reservoir if need be, but it adds more weight overall, and with the IC sitting above the engine like most Subarus, it will heat soak eventually.
There is a Jackson Racing S/C kit coming out shortly as well also using a centrifugal S/C, should be very similar to the Vortech in terms of performance. I've compared Innovate and Vortech plots on 93 and E85 and generally the Innovate makes more torque throughout most of the powerband, but it runs out of steam around 6500 RPM where the Vortech will keep up all the way to redline. That's why it makes more HP than the Innovate, but it's at the very top end. For a daily driver I'd take the Innovate all day long. 300whp though is going to be a struggle with it, like completely maxed out. I think both will require E85 to hit 300whp but the Vortech is going to get there much easier. Turbo is always going to give the best results as far as torque and HP, the units people are putting on these cars are good for 20psi and they are being run at 8-10psi. Turbos like the GT28 and PT55 P&L is using aren't really laggy either on this car. |
#24 |
Here is a guide for you:
Stock Car with Vortech 301HP+ (Sustained Usage, requires clutch, Fuel Injectors, pump, pulley) 300HP E85 (Smaller Pulley, Fuel Injectors Pump)(Clutch wear will be heavy) 270HP 93 Octane (Change Fuel Pump/Injectors) 250HP 93 Octane (No fuel system or other changes) 220HP 91/92 Octane (No Fuel System or Other Changes) Stock Car with Innovate Non-Intercooled 300HP+ (Not Possible without intercooler if at all) 280HP E85 Octane (In Future)(Pulley Change Fuel Pump/Injectors/Meth Injection)(Clutch Wear Heavy) 250HP E85 Octane (Fuel Pump, Injectors)(Consider Meth Injection) 220HP E85 (No Fuel System or Other Changes) 205HP 93 Octane (No other changes) 190HP 91 Octane (No changes)
#25 |
Moto-East hit 220whp (dynojet) on 93 octane with the stock Innovate pulley and 250whp on E85.
They are at the end of this video: [ame="https://www.youtube.com/watch?v=IxC2iNj1j9g"]Moto-East BRZ/FR-S Innovate/Sprintex Supercharger on the Dyno & Street - 250whp - YouTube[/ame] |
#26 | |
Secondly Moto-East posts about as much detail about his testing and tuning as Innovate does. They are both good at talking about dyno numbers that's about it. I would love to see the same results replicated more than 2-3 pulls with the hood closed back to back after the kit heat soaks.
#27 | |
Grip>Slip
fixed your post. if you're going to insult the man, don't try to church it up. |
#28 |
I'd like to see the Sprintex/Innovate unit with intercooler, smaller pulley, 93 octane, full exhaust and upgraded pump/injectors. That would help me make up my mind.
Side note: I really wish the nearest E85 retailer wasn't 30 miles away
Current: 2005 Porsche 911 Carrera S 6MT Previous: 2 BRZ's, 997 C2S, C5 RS6, C4 S6, B8 S4, GDB STi, S30 240Z, FC3S RX-7 TII, AW11/SW20 MR2, E30 318is/325i, etc. Last edited by Turbowned; 09-04-2013 at 03:51 PM. |
| Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 01:44 PM |
| N/A power output potential as race setup? | rice_classic | Engine, Exhaust, Transmission | 67 | 12-17-2013 08:03 PM |
| Abbey Motorpsort GT86 Sprintex installation | Mark@Abbey m/s | Forced Induction | 18 | 09-07-2013 05:11 AM |
| WA Next meet Sun 30th June - Sprintex Test Drive AND A One Audio display plus special | invisage | Australian Meets & Events | 2 | 07-22-2013 04:20 AM |
| Sprintex Supercharger Sneak Peak!!! | invisage | Forced Induction | 52 | 03-03-2013 07:11 AM |
