86WORX
Old 11-06-2013, 08:27 PM   #29
FiRStsc10n
Canadian FR-S Member
FiRStsc10n's Avatar
Drives: FR-S '10 Series'
Originally Posted by Starkiller View Post
I did not remove them, but I found out to make them glow only white. The blue looks a little bit too ricey for me. LOL. The white looks a lot cleaner though.
Could you explain how you did this?
FiRStsc10n is offline   Reply With Quote
Old 11-06-2013, 10:45 PM   #30
Starkiller
Drives: 2013 Scion FR-S 10 series
I de-pinned the white wire out of the plug for the emblem. The white wire controls the blue light. Now, it glows only white!
Starkiller is offline   Reply With Quote
The Following User Says Thank You to Starkiller For This Useful Post:
FiRStsc10n (11-06-2013)
Old 11-07-2013, 12:19 AM   #31
Snowblind
Scion badges are bad enough, but glowing badges are retarded. Has no one removed these, or their bumper yet to see if there is an extra hole for the wiring?
Old 11-07-2013, 03:38 PM   #32
Starkiller
Yes, there is a big hole in the center of the emblems. I am in the middle of figuring out how to control them. I want to be able to turn them on and off and even drive with them on if I want. LOL. I will have a write-up when I am finished.
I am also trying to figure out how to change the EL dash to say what I want it to say... That one has proved to be a little more difficult. LOL
The Following 3 Users Say Thank You to Starkiller For This Useful Post:
IgnitionGundam (11-07-2013), NABoxer (03-21-2016), Ris (08-22-2014)
Old 11-07-2013, 07:53 PM   #33
FiRStsc10n
FiRStsc10n's Avatar
Interested in seeing your results
Old 11-07-2013, 08:29 PM   #34
IgnitionGundam
IgnitionGundam's Avatar
Drives: Silver Ignition Gundam
Starkiller is my hero!
One of the things I wanted to do (but had no idea how) was try to rewire it so something else would glow instead... for example ..foot well lighting inside the car or something.
IgnitionGundam is offline   Reply With Quote
The Following 2 Users Say Thank You to IgnitionGundam For This Useful Post:
SilverTipp (11-07-2013), Starkiller (11-07-2013)
Old 11-08-2013, 12:14 AM   #35
Starkiller
Old 11-09-2013, 08:30 PM   #36
IgnitionGundam
thats's awesome you got it to work .. but i'm not sure about this idea! ahha
Old 11-11-2013, 11:35 AM   #37
n2oinferno
Praise Helix!
n2oinferno's Avatar
Someone needs to modify theirs to red for Christmas. Because Rudolph.
Ok, I'll let myself out.
The Following 4 Users Say Thank You to n2oinferno For This Useful Post:
Enthalpy (11-13-2013), Ris (08-22-2014), Starkiller (11-12-2013), Uplink (06-28-2017)
Old 11-13-2013, 03:21 AM   #38
Enthalpy
Drives: FR-S 10 Series/'93 RX-7
[Off Topic]
Originally Posted by DylanFRS View Post
How much other stuff comes on the Series 10? If you don't like the emblems, it seems like you should have just bought a base.
The electroluminescent panel on the passenger side dash as well.
Ignition Silver is a 10-series only color.
The 10 series is also the only way to get an FR-S with HID headlights. That's the major reason I got a 10 series - I wanted HID headlights, but I did not like the BRZ front bumper at ALL. I also did NOT want leather seats - and the FR-S only comes with cloth seats for all trims. Perfect.
But I can agree that simply adding the HIDs and the color as options to base models would have made been a logical choice.
[/Off Topic]
Back on topic - have not removed them yet, but I have preemptively disconnected them. I have to wholeheartedly disagree about them growing on me - very glad to draw attention to the car's beautiful lines and great color rather than the shitty ricer emblems that serve no useful purpose other than to use my battery, increase drag, increase weight on overhangs, and add more complexity to the wiring.
Would have gladly paid for kneepads instead.
Then again, to each their own...
Enthalpy is offline   Reply With Quote
Old 12-25-2013, 05:57 PM   #39
Siege
1570/2500
Drives: 2013 FR-S 10 Series
This was posted in another thread:
Originally Posted by IgnitionGundam View Post
I said screw it!!!
It looks like the 86 Boxer emblem used on the fenders would cover the hole. Using a Toyota emblem would require a backing underneath.
Siege is offline   Reply With Quote
Old 03-02-2014, 05:59 PM   #40
PEWPEW
PEWPEW's Avatar
Drives: 10 Series FRS
Could anybody clarify which relay to disconnect under the steering column? I removed the assessmbly from the center console but that's just for the dash. Disconnected a wire and now it only shines white. I've disconnected some relays but I just can't seem to find the one.
PEWPEW is offline   Reply With Quote
Old 04-29-2014, 12:24 PM   #41
Enders FRS
Drives: FRS MT SE 10 edition
There are some Toyota Emblems where the center is filled. Im thinking about disassembling the stock ones, replacing the scion logo with the filled toyota one, then putting that back on the LED ring, then back to the car. Should retain the blue hue around the emblem without the white lettering and enable me to get some GT86 badges on her. Im going to order one and see how it comes out.
Enders FRS is offline   Reply With Quote
Old 08-18-2014, 03:44 PM   #42
FOO-GT86
Drives: 2013 Argento FRS
Did you ever make any progress on this? Pics? I'm getting a 10-series tomorrow and this is the first thing I thought of doing
2013 Firestorm FR-S : [TOTALED] TRD Exhaust | Zeta Silicone Intake Pipe | TRD Highflow Drop-In Filter | LED DRL| SwitchBack Front Signal Lights | Custom 86 Wheel CenterCaps
2013 Argento FR-S : Quad Tip J2 Exhaust | VIS AMS CF Hood | Nitto Neogen Tires | Perrin lightweight crank pulley | Winjet taillights | 6k HIDs | SwitchBack Front Signal Lights
FOO-GT86 is offline   Reply With Quote
Search this Thread:
Advanced Search
pictures of BRZ/FRS with rear bumper removed Ben_G Cosmetic Modification (Interior/Exterior/Lighting) 20 10-20-2014 12:30 PM
SERIES 10 FR-S Fog Light Kit Ishii Motors Exterior Parts - Lighting 8 12-06-2013 03:34 AM
Torque dip removed with just a tune.... Sportsguy83 Engine, Exhaust, Transmission 43 05-13-2013 11:40 AM
