#1303 |
Drives: 2013 GBS BRZ Limited
Malt
We met at the shop getting alignments about the same time, and I have gone the same route as far as rear adjustment. I also want a little more eat camber adjustment, though my desired numbers are different. I am installing rear subframe solid bushings that are 20mms risers as well. Depending on the exact amount of adjustment, and car itself, I think you might be able to get what you're looking for that way. Depending on the intended use of the car, because going that route will effect how the car is classed. What were your before numbers on the alignment (post lowering, pre alignment)? What class are you planning to run, or do you not plan on tracking ? |
#1304 | ||
Drives: 2015 WRX
I'd like -2 all around with some toe in on the rear. It looks like toe arms just may solve the issue. As for class concerns, no plans on autocross at this time (or probably ever for this car), but definite plans for several HPDE's a year. I had hoped to get out to VIR in April but my upcoming trip to California put a nix on that one. |
#1305 | |
- Andy
Website
https://www.racecompengineering.com/ Instagram: https://www.instagram.com/racecompengineering https://www.instagram.com/theapexfiles <- tech articles |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | Kostamojen (04-23-2014) |
#1306 | |
#1307 |
Drives: 2014 BRZ SWP
I have a quick question, hopefully you guys can help!
I just ordered a set of FA 500's and I am looking into doing a basic suspension bushing upgrade as now, with stiffer coilovers, I imagine much of the force will xfer over to the next weakest link. This car is mainly a DD, sees quite a few mountain roads, a few track days and I'm not afraid of the stiff. What would be a few things that you would recommend to upgrade in the suspension bushing department that isn't overkill, but would be sort of, 'necessary' or 'should haves'. This car will also be running 245's on all four corners with fairly sticky street tires. Thanks in advance! |
#1308 |
Drives: 1993 Impreza w/ WRX Swap + FWD!
#1309 |
Drives: 13 10 series FRS
My question, what are the negatives of dropping your car with lowering springs and not using lower control arms? How long do you think the stock shocks would last with a spring that drops ~30-35mm? Are bushings a definite necessary mod when lowering the car?
#1310 | |
Drives: 2015 WRX
You'll need something to get your camber and toe back to reasonable levels with a 1"+ drop. Bushings are not necessary but obviously have the upsides and downsides. Be prepared to spend $$$ if those bushings need to be pressed in and out if you don't have a means to do it yourself. |
| The Following User Says Thank You to Malt For This Useful Post: | fz6r (04-28-2014) |
#1311 |
Looks like we're only selling them as a pair at the moment with the front bar. I thought we had an "extra" rear but no luck.
![]() Go with Whiteline or Perrin. ![]() - Andy
Website
#1312 |
#1313 |
There are now 2 carseats!
Drives: 2013 DGM BRZ
![]() Just to verify...the bushings on the left (diff mount) go on top of the stock bushings (as in, they dont replace them but lock them down)? |
#1314 |
Off Topic
Correct. They basically fill the voids in the OEM bushings with polyurethane to minimize flex. Whiteline also makes replacement bushings (KDT924), but those are more expensive and would require you to drop the diff cradle and press them in.
#1315 |
Any opinions on the best way to get more negative camber up front on stock struts? I already have whiteline bolts in the top holes maxed out, but I still need some more. I haven't had it properly aligned yet, but the wear onto the shoulders is pretty even left/right, and it wasn't pushing excessively. I was running 38psi cold on a cool day, didn't check temps after a run at all though.
I know I can slot the upper holes, run whiteline bolts in the bottom hole as well, etc. How well do those hold settings compared to camber plates? Any concerns with the offset bolts and slotted upper holes? I'm trying to avoid camber plates because I drive a lot (60k km's on the car in less than two years) and don't want to be replacing bearings too often, but if there are plates that will survive Canadian winters and last more than a year with how much I drive then I'll gladly consider them too.
#1316 | |
Drives: 2015 WRX
| Air Suspension Discussion Thread - Let's Get Nerdy | Andrew@ORT | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 174 | 02-13-2016 04:17 PM |
| RallySport Directs Everything Suspension thread!! | RallySport Direct | Brakes, Suspension, Chassis | 21 | 07-02-2014 06:31 PM |
| The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 09:15 AM |
| 2012 Team USA vs the 1992 Dream Team | ERZperformance | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 09-14-2012 07:19 PM |
| Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 11:13 AM |
