Old 04-21-2014, 02:25 PM   #1275
Kostamojen
Drives: 1993 Impreza w/ WRX Swap + FWD!
Hopefully there will be more factory style dampeners in the near future, that is something i'm interested in eventually... (I had the "SPT" setup on my GC8 for awhile, the AGX struts sold from Subaru plus the SPT springs and Group-N tophats, loved that suspension)
Time to look into rear swaybars (already have the Strano FSB)
Kostamojen is offline   Reply With Quote
Old 04-21-2014, 02:33 PM   #1276
Racecomp Engineering
Ahhh there we go. Yes, just running the front swaybar will cause some understeer (and it's more noticeable with our springs). Good for front end response but yes match it with a rear bar! Our springs + front and rear bars = goodness.
And yeah, I'm hoping some Bilstein reviews pop up soon. I know a bunch of people have gone with the HDs and Sports recently and I'm looking forward to hearing some feedback.
- Andy
Old 04-21-2014, 02:55 PM   #1277
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
My alignment specs are -2.5 degrees of camber on the front and -2.0 degrees of camber on the rear with about -0.05 toe all around, I am competing in STX and will do 2 lapping days this year with 20000+km of street driving. Any alignment change recommendations?
BRZZZZZZZZZZ is offline   Reply With Quote
Old 04-21-2014, 03:09 PM   #1278
FR-S Matt
Could go lower in the rear to about -1.5, slight toe in maybe? That's great camber up front at 0 toe. Only minor adjustment I would make but with STX, the extra rear camber may be beneficial.
Old 04-21-2014, 03:17 PM   #1279
wparsons
wparsons's Avatar
With the stock alignment on mine it was very obvious that the front needed more camber added than the rear. I was pretty far onto the shoulders of the fronts but just fine in the back. I would bet that -1.5 in the rear is plenty until your tire wear (or pyrometer readings) tell you otherwise.
flickr
Old 04-21-2014, 03:22 PM   #1280
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
- Andy
Would you reccomend this setup for an STX car? Its my first year and will only be local even in the long run. I just have Potenza S04s and RCE yellows now. I have Konis but need to get one replaced (i bought them used and one was blown) and have been trying to decide if the Konis or sways will be my next mod. I cant seem to find too many high prep stx cars running front and rear sways so am curious.
Old 04-21-2014, 03:35 PM   #1281
Yes, there's a bunch of people autocrossing RCE Yellows with Konis. It's a good set up that you can do well with locally. I think there's a thread here someone was updating, but I can't find it at the moment.
High prep STX cars may not run front and rear sways, but those cars are running pretty firm coilovers anyway. With a softer spring set up you will benefit more from adding swaybars than they would.
That said I might get your Konis taken care of first.
- Andy
The Following User Says Thank You to Racecomp Engineering For This Useful Post:
finch1750 (04-21-2014)
Old 04-21-2014, 03:36 PM   #1282
What's the rest of your set-up? Spring rates, tires, etc.
- Andy
Old 04-21-2014, 03:38 PM   #1283
BRZZZZZZZZZZ
Car Nut
- Andy
RCE Yellows, Bilstein Sport Series shocks, Raceseng camber plates, Eibach front and rear sway bars front set to stiff rear set to soft, 16x7 Volk TE37s with 225/50/16 Hankook RS-3s and second set is Bridgestone RE-11s.
Old 04-21-2014, 04:13 PM   #1284
finch1750
finch1750's Avatar
- Andy
Yeah, i was following the thread. I think they swapped to tarmac springs and havent really updated since. Might have to go track it down and tag them to get an update. Thanks for the info and the reminder. May be calling soon to get that Koni taken care of.
Racecomp Engineering (04-21-2014)
Old 04-21-2014, 04:15 PM   #1285
Kostamojen
The FSB + stock springs + camber bolts was fantastic BTW
Not really much of any understeer with that setup, and would still rotate with the stock tires or even some 225 semi-performance summer tires. Its what the guys in C-stock run.
I'm thinking 17mm rear, maybe 18mm???
Old 04-21-2014, 04:57 PM   #1286
Sounds like a lot of fun.
I'd say your alignment is pretty good, but you'd like a little more front camber at the track or auto-x. Of course you'll increase treadwear with more front camber so there's a compromise.
I think your rear camber is good. I'd prefer zero toe in the rear but that varies driver to driver.
- Andy
Old 04-21-2014, 05:04 PM   #1287
Yes, the Yellows are happier with front AND rear swaybars while stock benefits a great deal with just the front bar. That's by design....we wanted the springs to be good with stock swaybars (rather than really need a front bar or stiffer front rates like every other spring). When adding bars then you need to do both.
Did you get the replacement bumpstops with your used Yellows?
16mm is the common size for a rear bar for this car. Get an adjustable and find a setting you like (probably stiff). Whiteline is good. They do make an 18mm rear but it's pretty big...
- Andy
Old 04-21-2014, 05:16 PM   #1288
BRZZZZZZZZZZ
Car Nut
- Andy
Lots of fun, but the rear is pretty snappy with the sway bar set to stiff so I brought it back down to soft. I will try to reduce the toe to 0 in the rear. Really need wider tires to take advantage of the suspension now but I don't want to go up to 17" wheels.
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 04:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 06:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 09:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 07:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 11:13 AM
