#1219 | |
It would be awesome though. - andy
Website
https://www.racecompengineering.com/ Instagram: https://www.instagram.com/racecompengineering https://www.instagram.com/theapexfiles <- tech articles |
#1220 |
Just the tip
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
I'm guessing the only difference between the RCE yellow and RCE tarmac springs is the spring rate? The website lists yellow at 250lbs/in and the tarmac at 5kg. Could you fix it so they are in the same unit of measure so I and others have a better point of reference? I currently have the yellows mated to the Koni yellows and love them. I got them before the tarmac springs came out however so not sure if I'd like the tarmacs even more.
Current: 2013 Lightning Red Subaru BRZ Limited
Past (sold): Click here to see previous cars and bikes ![]() |
#1221 | |
Serial Cone Killer
Drives: '14 BRZ - WRB Premium 6MT
#1222 | |
And yes it's 280 lbs/in for the Tarmacs, same drop. ![]() - Andy
Website
#1223 |
Serial Cone Killer
So I am exchanging the koni yellows for bilstein b8's to be paired up with RCE Tarmac springs. Should I expect to need to have the shocks revalved or will they be good to go for autox and daily driving out of the box?
#1224 |
Off Topic
You might as well put both measurements on there. People will want to compare them to other companies' springs and every company does it differently.
| The Following 3 Users Say Thank You to gramicci101 For This Useful Post: |
#1225 | |
- Andy
Website
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | Turkish (04-12-2014) |
#1226 |
Drives: 86 GTS
Recommended "fast road" alignment
I'm looking for input on recommended "fast road" alignment for my car, effectively stock suspension, happy to add camber bolts either the Subaru Crash bolts or the Whiteline ones.
Would @Racecomp Engineering or @CSG Mike have any suggestions. Last edited by Panman; 04-15-2014 at 09:53 PM. |
#1227 | |
#1228 | |
Drives: 86 GTS
Not unhappy with current setup particularly, but looking to optimize turn in a little more. Tyres are currently Federal 595 RS-R in 225/40/18, going to Nitto Invo or NT05 on 17" when new wheels arrive. (225/45/17). Driving: Occasional track, lots of canyon carving (Twisty hill driving), HPDE. Currently on STI Pink springs (15mm Drop) on std Shocks, whiteline front tower bar, will be adding either Subaru or Whiteline camber bolts to the front. |
#1229 | |
You won't have any adjustment except toe in the rear. -Mike |
#1230 | |
You won't have too much front camber, especially if you use the subaru camber bolt. It will help turn-in and front/overall grip. - Andy
Website
#1231 | |
![]() He's right though, if you can, try zero toe in the rear and see what you think. - Andy
Website
#1232 |
Drives: FR-S Whiteout
| Air Suspension Discussion Thread - Let's Get Nerdy | Andrew@ORT | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 174 | 02-13-2016 04:17 PM |
| RallySport Directs Everything Suspension thread!! | RallySport Direct | Brakes, Suspension, Chassis | 21 | 07-02-2014 06:31 PM |
| The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 09:15 AM |
| 2012 Team USA vs the 1992 Dream Team | ERZperformance | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 09-14-2012 07:19 PM |
| Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 11:13 AM |
