#1009 | |
Drives: '13 BRZ Ltd
In theory if you increase spring rates proportionately* at both ends this wouldn't affect lateral load transfer distribution or total load transfer (and understeer/oversteer balance wouldn't change), but there would be less suspension movement and it would settle faster. *not just spring rates but spring rates -> wheel rates -> frequency |
| The Following 3 Users Say Thank You to Wepeel For This Useful Post: |
#1010 | |
Coffee Snob
Drives: '14 SWP BRZ Limited
I do want the car to handle as it should, as I love taking her out for a drive in the twisties every so often, and the road conditions are not always the best (lumpy, banked, etc). Currently, I am on stock tires, but I am planning to swap to 17x9 +35 RPF1's with 245/40/17 Hankook V12's...
#1011 | |
#1012 | |
i'm sorry, what?
Drives: Canada
you can increase force by increasing speed, but you cannot increase (or decrease) the weight of the car
#1013 |
#1014 | |
Weight is actually a force. You can't create MASS, but you can change weight. Sorry for interrupting the good discussion. |
| The Following 4 Users Say Thank You to jvincent For This Useful Post: |
#1015 |
i'm sorry, what?
Drives: Canada
but that force becomes lateral, does it not?
#1016 | |
Unless you're generating downforce, you can't increase the weight of the car on the springs. You can shift it around, but not increase it.
| The Following User Says Thank You to wparsons For This Useful Post: | leicaboss (03-17-2014) |
#1017 | |
Coffee Snob
Do you mean to say -2 front and -1 rear? It seems most opt for more camber up front on their FR-S, I wonder if I need to adapt this since the BRZ does have a tighter front?
#1018 | |
#1019 |
Drives: FR-S Whiteout
Question for Andy @Racecomp Engineering :
I noticed that RCE like to run squared spring rates, so effectively they are much stiffer out front. Does this not produce a very under steering prone set up? Was this the goal? What was the reasoning behind these rates? |
#1020 |
My guess is that the lateral component probably increases significantly more than the downward one.
Stating the obvious, but rounding a corner at any kind of significant speed is a pretty complex problem from a weight distribution point of view when you factor in braking forces, etc. To address one of the earlier comments, I'd guess that in very few instances is the force on the spring perfectly along its axis of compression. Whether that affects its performance or not is a question for the suspension designers. |
#1021 |
You said anything...
How do the RCE Yellows pair with Koni Sport inserts from a ride/handling trade off stand point? |
#1022 | ||
| Air Suspension Discussion Thread - Let's Get Nerdy | Andrew@ORT | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 174 | 02-13-2016 04:17 PM |
| RallySport Directs Everything Suspension thread!! | RallySport Direct | Brakes, Suspension, Chassis | 21 | 07-02-2014 06:31 PM |
| The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 09:15 AM |
| 2012 Team USA vs the 1992 Dream Team | ERZperformance | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 09-14-2012 07:19 PM |
| Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 11:13 AM |
