Old 02-19-2014, 10:50 AM   #771
FRS-HHH
igotthatpurp
FRS-HHH's Avatar
about to order the bilstein b14s coilovers do you recommend upgrading to Whiteline camber bolts and camber adjustable rear bushings ?? if yes why and if no why? kinda new to the whole suspension thing thanks
FRS-HHH is offline   Reply With Quote
Old 02-19-2014, 01:44 PM   #772
Racecomp Engineering
Originally Posted by FastWhite View Post
I am running stock wheels and 225/45/17 rivals.
Budget is open al the up to the Ohlins. Checked on JRZ's the other day, and ya I'll put them off until I win the lottery. Lol
I consider the MCS just for the fact that I would be able to stay in street classes.
But for the price point and what you get, Ohlins are point or two ahead.
I'm just going to HAVE to find people with various set ups, try them( passenger seat) and pay for lunch.
Trying, sorta, to avoid being bitten by the bug. Sorta. Lol
We really need to have a meet with a bunch of suspension systems to ride on. Maybe this spring!
- Andy
The Following User Says Thank You to Racecomp Engineering For This Useful Post:
FastWhite (02-19-2014)
Old 02-19-2014, 01:46 PM   #773
FastWhite
Drives: Subaru BRZ Limited M/T
I WILL be there.
FastWhite is offline   Reply With Quote
The Following User Says Thank You to FastWhite For This Useful Post:
Racecomp Engineering (02-19-2014)
Old 02-19-2014, 01:47 PM   #774
How much camber do you want? The bolts from the dealer may be fine.
For the rear most people go with a set of LCAs instead of the camber bushings. I like the bushings but they are a pain to install and adjust.
- Andy
Old 02-19-2014, 02:12 PM   #775
Stevo22
Stevo22's Avatar
Drives: GR86
What is the typical lifespan and how do you tell when a rebuild is needed for a coilover(e.g. is just based on feel or is their a recommended mileage)? I assume this varies with street vs. track mileage? I also assume this varies between the quality of the product, so you can keep it your wheel house Tarmacs for @Racecomp Engineering and SRCs for @CSG Mike and expand if you have experience with other brands. Additionally, does a twin tube or monotube typically last longer?
Stevo22 is offline   Reply With Quote
Old 02-19-2014, 05:22 PM   #776
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
What are you guy's thoughts on increasing roll stiffness via sway bar on our Mac strut front suspension? I understand going to stiff will cause too much understeer and a lot more likely to push under trail braking. But, with just enough it should maintain better contact between tire and road under cornering speeds by virtue of decreasing body roll, thus camber loss when mashing it though turns.
Thoughts? Better yet, data?
Every macstrut equipped car I've driven, read about, heard about have had marked increase in cornering speed including the much touted cayman s. If sway bars are only good for 'adjusting balance' then why do these supposedly near perfect balance of an out of the box cayman benefit so greatly from a stiffened sway bar? Riddle me that?
Old 02-19-2014, 06:06 PM   #777
solidONE
solidONE's Avatar
Originally Posted by Racecomp Engineering View Post
Oh yeah, this!
I swore we posted our shock dynos a long time ago in our own thread here, but it turns out we never did.
This is T2s on soft, 9 clicks comp and rebound, and hard with T0 in there as well.
- Andy
The green and black lines are the T0's?
Old 02-19-2014, 06:34 PM   #778
Yes, greenish black lines are T0 (NA for non-adjustable).
- andy
Old 02-19-2014, 06:40 PM   #779
Because swaybars do more than just adjust balance.
IMO sways are a simple device that is often misunderstood in this world.
I commonly see people say that larger swaybars just remove grip to adjust balance and that's simply not true.
It's an easy and cheap way to reduce roll AND adjust balance.
There are advantages and disadvantages of the big swaybar and soft springs approach vs. the small swaybar and stiff spring approach. I've written a little about them somewhere here I think. I gotta run, but I'll see if I can dig some of it up later.
Also, I'm not saying "32mm SWAYBARS FOR ALL!!!"
Swaybars are simply one piece of the puzzle to choose carefully to fit into your system. Design for a goal and build the system accordingly.
- Andy
solidONE (02-19-2014)
Old 02-19-2014, 08:52 PM   #780
ja1217
Drives: 2004 Toyota RAV-4 5M
Ohlins are just amazing shocks. I think Myles in the office finally felt like our car was about perfect when we put a custom sprung version on our car. Yes it's only a 1 way but it is so damn good. Put them on, dial them in, and enjoy on the road and track as the name suggests.
- Andy
What spring rate would you recommend for the Ohlins on a more track oriented car that will be running stickier tires (Hoosier R6)?
ja1217 is offline   Reply With Quote
Old 02-19-2014, 10:14 PM   #781
SRCs are recommended for inspection at 30k mile intervals. You shouldn't need a rebuild for a long, long time, unless you're doing something really... egregious with them.
Anthonytpt (02-26-2014), Stevo22 (02-19-2014)
Old 02-19-2014, 10:16 PM   #782
The R&T is still a 1 way damper; you don't really get much compression damping change, so you shouldn't deviate too much from the springs that come with them. You need a 2 way damper to really have the ability to swap springs to your liking.
What are the track surfaces like where you run? That's what will really determine how stiff you can go.
Old 02-19-2014, 10:42 PM   #783
ja1217
Main tracks I will be going to are VIR and Summit Point which are pretty smooth other than curb hopping in places. Definitely no where near as rough as buttonwillow.
Old 02-19-2014, 10:48 PM   #784
Superstar
Drives: Honda
Are the custom valved CSG spec'd SRCs still in development?
Superstar is offline   Reply With Quote
Search this Thread:
Advanced Search
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 04:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 06:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 09:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 07:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 11:13 AM
