86WORX
Old 12-05-2013, 09:59 PM   #519
Ouhei
Ouhei's Avatar
Drives: '14 SWP BRZ Limited
Originally Posted by Racecomp Engineering View Post
Some may need a camber plate up front for tire clearance, but that may not be necessary with the coilover (fitment gurus help me here). We run a "wide" 245 with coilovers and have plenty of room.
Even without camber plates you'll be able to get plenty of camber. Just the cheap factory camber bolt will get you over -2 with KW or RCE coilovers.
For the rear, rear LCAs or the WL rear camber bushing kit. I like the bushing but it's a pain to install and adjust. I'd recommend rear LCAs, maybe with the nonadjustable version of that bushing.
- Andy
Thanks for the info! Nice to know those wheels aren't too hard to fit on these cars.
Conveniently, I own and run a S2000.
What kind of suspension did you run on the S2000? You don't necessarily need to have additional adjustability, depending on how you set up the FRS/BRZ. We don't run ANY additional arms, links, etc. on our shop car; we simply don't need them.
I'm currently running TEIN RS's (precursor to the SRC) because I got a really good deal on them when I was looking to replace my D2's I had grown to hate for being too bouncy. They ride really nice but I don't adjust them ever (well I tweaked them a bit at first to soften the ride up as the guy that had them before me only tracked his car).
I want to lower the car to about a finger gap all around and run no more than -3 camber (prefer to be at or under -2). Plan is to run 255/35/18 Dunlop Z2's or Hankook RS3's, which tend to run on the wider side of 255's.
Ouhei is offline   Reply With Quote
Old 12-05-2013, 10:55 PM   #520
fatoni
whats the minimum amount of prep these cars need in order to keep them happy at the track
Old 12-06-2013, 12:08 AM   #521
If you like the RS, perhaps you should consider the SRC. We run SRCs without any additional suspension pieces.
Old 12-06-2013, 01:29 AM   #522
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
An F20C in the engine bay....
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following 3 Users Say Thank You to Dave-ROR For This Useful Post:
CSG Mike (12-06-2013), juliog (12-06-2013), SubieNate (01-01-2014)
Old 12-06-2013, 04:54 AM   #523
the.big.kahoona
the.big.kahoona's Avatar
Drives: 2013 Raven 86
What are your thoughts on running a higher spring rate in the front? 9k front 7k back. What adjustments/mods would you recommend I make/install to make the best out of such a setup for the track?
Sent from my SM-N9005 using Tapatalk
the.big.kahoona is offline   Reply With Quote
Old 12-06-2013, 09:56 AM   #524
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
a cool head
The Following User Says Thank You to 7thgear For This Useful Post:
fatoni (12-06-2013)
Old 12-06-2013, 11:30 AM   #525
Brake pads and fluid.
Originally Posted by 7thgear View Post
a cool head
Tape your wallet to the dashboard. That helps.
- Andy
Old 12-06-2013, 11:34 AM   #526
It can work, but we generally do even or rear biased rates.
What kind of tires?
- Andy
Old 12-06-2013, 12:38 PM   #527
the.big.kahoona
What kind of tires?
- Andy
225 pzeros
Old 12-06-2013, 12:44 PM   #528
It will result in the car that understeers virtually everywhere, unless you're running a really beefy sway (which is a band-aid fix) or a heavily, heavily staggered tire setup (much bigger rear tires than fronts).
What is your goal?
If you're running 225 square, it'll almost drive like a FWD, but if/when the rear snaps, it'll be REALLY sudden.
Old 12-06-2013, 02:01 PM   #529
fatoni
haha. i dont regret the brz decision but its tough when you find something like this
http://www.trackhq.com/forums/f310/f...7k-miles-6803/
a month later and its actually reasonably priced and in my area.
- Andy
really? i just imagine its at least more cost effective to get things for a decent alignment. i imagine i would go through tires with the stock settings.
Old 12-06-2013, 02:13 PM   #530
Hah I know that car... I've coached Matt a bit over the last year and half or so. He's gotten pretty quick.
I didn't know you were on the flat out forum. Whats your handle?
Old 12-06-2013, 02:16 PM   #531
I definitely recommend an alignment, at the very least with the factory camber bolts. Hell I'd do that off the showroom floor. But for the bare minimum for safety it's just brake pads and fluid IMO.
- Andy
Old 12-06-2013, 02:18 PM   #532
225 pzeros
I don't think it's as bad as CSG says, but it's still not something I'd do. Any reason you want to go that direction?
A couple auto-x guys do that sort of set-up and it works for them.
- Andy
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 04:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 06:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 09:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 07:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 11:13 AM
