86WORX
Old 12-02-2013, 03:23 PM   #505
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
Originally Posted by PRORICAN View Post
Question for the experts. What swaybars do you recommend with the bilstein b14 pss coilovers if any? The stockers may be sufficient but wondering if it would help handling with bigger bars. Thanks
swaybars are a fine tuning device
your choice for coilover spring rate should have been fit for your intended use...
you put thicker/thinner bars on front/back depending on whether you're over/understeering at a specific track or day.
there is NO magical formula, you tune according to what what you desire the car to do.
The Following 2 Users Say Thank You to 7thgear For This Useful Post:
CSG Mike (12-02-2013), PRORICAN (12-02-2013)
Old 12-02-2013, 03:23 PM   #506
That depends. What are you trying to achieve? What do you like and dislike about your setup?
Old 12-02-2013, 03:36 PM   #507
PRORICAN
PRORICAN's Avatar
Yeah I kinda guessed these questions where coming, lol. I want to autox next season and want to prepare for it, but I'll leave it as is, autox it and figure out what the car is doing good or bad. I guess I wanted to see if anybody has experience with these and figured they needed swaybars for autox. Thanks
PRORICAN is offline   Reply With Quote
Old 12-02-2013, 03:53 PM   #508
Sways are used to tune the under/oversteer balance of the car to your preference. In an autox environment, you'll probably want a beefy front sway, since you'll likely value quick transitional speed over sustained cornering speed.
Old 12-04-2013, 02:38 PM   #509
VADER
Regional Moderator
VADER's Avatar
Drives: VADER 86
I'm at work and don't have time right now to read through 24 pages to possibly find my answer haha. So, here's my Q...
I currently rub on my rear tires. I am hoping that getting LCA's to adjust the camber will fix this as I have already slightly rolled the fenders. Will I have to also get toe arms with the LCA's? Please tag me in the answer (@vader).
Thanks in advance!
VADER is offline   Reply With Quote
Old 12-04-2013, 06:25 PM   #510
mike156
Drives: EVO
Originally Posted by Fizz
I've just installed coilovers and although the ride height was adjusted equally on the strut body, there was a difference of 5mm in actual ride height between front left and front right (driver side being 5mm lower even without driver).
If I were to readjust would you recommend doing each side equally? I mean raise one side 2.5mm and lower the other side equally. Or just adjust the difference on one side only and be done with it?
This might actually be a quality issue of the springs more than anything else. If you are using good springs (Hyperco and Swift) then you might just be seeing the weight imbalance of the car. If it's Chinese coilovers you are talking about here, it's likely just the springs are junk.
As an alternative here, you can approach this in a scientific manner. Target a natural frequency balance F/R then adjust the swaybars to get roll under control. This is where the "soft spring/big bar" approach ultimately comes from. You run a softer spring so your natural frequency is low enough to make it comfortable on the street then make up for the lack of roll stiffness with the sway bars.
I am curious about this idea that a big front bar improves response though. I recently tested out removing the sway bars all together on another light RWD platform. What I found was a car with instant turn-in and remarkable front grip. It almost felt like the car knew where to go before I even turned the steering wheel...It also over steered so greatly that it slowed the car down considerably. Putting on the front bar balanced the car back out but KILLED the turn-in response up front.
I'm now on a mission to match the no-bar turn in but keep it balanced. My wheel rates are fairly high too with a lot of front bias (580F/380R) with a 53/47 weight balance, yet the car was still crazy loose.
mike156 is offline   Reply With Quote
Old 12-04-2013, 06:39 PM   #511
autobrz
Drives: Mazda 3
i think its because the front bar is much stiffer than the rear when motion ratios are calculated. so the balance changed a lot by removing them.
autobrz is offline   Reply With Quote
Old 12-04-2013, 07:06 PM   #512
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
They're Bilstein coilovers. Anyway I didn't have time to adjust them the other day, so after driving about a few days since installing, they seem to have leveled out evenly. Only about 2-3mm difference between left to right side now. I'll leave them alone for now.
Fizz is offline   Reply With Quote
Old 12-04-2013, 07:45 PM   #513
mike156
Drives: EVO
Autobrz, as mentioned, this was not on the GT86 platform. Just another lightweight RWD. I included the wheel rates of the springs alone for comparison purposes. For reference, it was a 680lb/in spring on an 2400 pound E36 BMW setup...LOTS of spring to control roll. Wheel rates of 580/380 should tend towards understeer considering the weight balance of the car, but that wasn't the case.
It would be interesting to see how the twins responded to removing the swaybars while using high spring rates. As I said, the turn-in and front grip was phenomenal without the bars on, maybe the GT86 would respond beter with it's more advanced rear suspension?
Old 12-04-2013, 08:06 PM   #514
I currently rub on my rear tires. I am hoping that getting LCA's to adjust the camber will fix this as I have already slightly rolled the fenders. Will I have to also get toe arms with the LCA's? Please tag me in the answer @VADER).
Thanks in advance!
@VADER
If you're rubbing on the outer edges, then the LCAs MAY help. It depends on the magnitude of the rubbing.
You won't need toe arms.
VADER (12-04-2013)
Old 12-04-2013, 11:07 PM   #515
autobrz
Drives: Mazda 3
ah... that's interesting... I've always gotten more grip from springs than sways when increasing the same wheel rate. dont know much about e36 suspension though. have you read steve holschier?
Old 12-05-2013, 09:14 AM   #516
Ouhei
Ouhei's Avatar
Drives: '14 SWP BRZ Limited
May as well,
I don't have a BRZ/FRS yet but I'm doing research on them now and plan on buying in March/April. I'm looking at suspension setups and I'm getting a bit lost when it comes to camber setups. I'm coming from a s2000 which has some factory adjustment so I've never had to worry about it (my wheel setup works within factory adjustment at my ride height).
If I want to run 18x9.5 +40 w/ 255/35's all around with a decent drop (not slammed) and I want the car to perform/handle well, what kind of setup would you recommend? I've been looking at the KW v3 and Tarmac 0/2 mostly. From my understanding I'd at least need something like the whiteline camber adjustment kit for the rear.
The car will see mostly street driving with backroads twisties and I'll make it out to an autocross/track every once and a while but not terribly often.
Ouhei is offline   Reply With Quote
Old 12-05-2013, 11:41 AM   #517
Racecomp Engineering
Originally Posted by Ouhei View Post
May as well,
Some may need a camber plate up front for tire clearance, but that may not be necessary with the coilover (fitment gurus help me here). We run a "wide" 245 with coilovers and have plenty of room.
Even without camber plates you'll be able to get plenty of camber. Just the cheap factory camber bolt will get you over -2 with KW or RCE coilovers.
For the rear, rear LCAs or the WL rear camber bushing kit. I like the bushing but it's a pain to install and adjust. I'd recommend rear LCAs, maybe with the nonadjustable version of that bushing.
- Andy
Old 12-05-2013, 01:37 PM   #518
May as well,
Conveniently, I own and run a S2000.
What kind of suspension did you run on the S2000? You don't necessarily need to have additional adjustability, depending on how you set up the FRS/BRZ. We don't run ANY additional arms, links, etc. on our shop car; we simply don't need them.
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 04:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 06:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 09:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 07:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 11:13 AM
