#4187 |
Drives: 2013 FRS
Higher rate rear springs
Hi, I have the Tarmac 2s and would like to stiffen the rear slightly. Currently has the 70-170 blue springs. 400# I think. What can I get and where?
WIFE: "How can there be anything left to buy?"
#4188 |
Drives: 2020 BRZ Sport Tech RS
The 80-170 spring kit from ST suspensions would be one step up from the stock 70-170's.
#4189 |
Dismember
Drives: 2013 Red Scion FR-S
Say I want to handle a rough road at fun speeds on semi-custom coilovers, Ohlins DFV with a choice of valving. Stock height or slightly higher.
Road has dips. Bumps. Speed bumps. Mid corner road catastrophes. Single wheel bumps. Double wheel bumps. Which way do I go? Springs can be stockish, stiffer, or much stiffer. Damping can be stockish, stiffer, or much stiffer - adjustable in Ohlins range. Antiroll bars can be stock, stiffer, or much stiffer - probably adjustable. I'm thinking stockish spring rates, stiffer damping, and stiffer antiroll bars would mean the car would be on bump stops less, handle bumps better, and not sacrifice ride quality. Might even be better ride quality with better damper quality. If shocks Ohlins DFV curves are designed for springs of x stiffness, would stiffer antiroll bars recommend getting stiffer damping curves as well, or would the range of adjustment easily handle the transients of stiffer antiroll bars? Would I be better off with KW V3? Knowing I want stock height or even slightly higher, this seems not as good an option, but the double adjustability might be useful, especially if I want to change spring rates if the first one doesn't work out. I'm thinking that something like the Ohlins RT off the shelf would be too stiff on spring rate and too stiff on damping, so I'd pay with a brutal ride and maybe even skipping over the bigger bumps, all to get grip on the track I won't ever visit. Thoughts?
#4190 | |
| The Following User Says Thank You to Tatsu333 For This Useful Post: | EAGLE5 (06-29-2022) |
#4191 | |
Drives: 2018 BRZ
Final thought - it sounds like you might as well just try stiffer bars and leave the stock suspension as is (or at most replace with 2017+ suspension). Would be much cheaper and you won't be paying money for coilovers that you don't really use. At the very least you could start from stiff bars and see how that works for you before going with coilovers. |
| The Following User Says Thank You to Ohio Enthusiast For This Useful Post: | EAGLE5 (06-29-2022) |
#4192 | |
Drives: Toyota 86
Going higher with spacers is possible, without problems, using longer springs is also possible but keep in mind that you're going outside of the recommended range, raising it 10mm is ok but no more otherwise shock could be damaged, they're designed to run lower. Spring range (as per Kw) is 40-70nm on both axles, going softer or harder is possible but not recommended, dampers cannot be revalved but low speed compression adjustment helps and rebound damping range is wide enough for those springs. They will work. Ohlins R&T can be used at stock height no problem, even higher. They can be fully customized form gas pressure to damping, monotube design is also stronger and better. Downside is lack of travel here, soft rates aren't ideal for Ohlins, especially in the rear. That said, the balance YOU WANT is the KEY and you can achieve that on both soft or stiff setups, having pros and cons on both. You have to try different setups and then decide. Personally after MANY tries my advice is to keep everything under 50nm for road usage, stiffer springs could work with premium and well dialed dampers but then tire choice will be limited + going over 2Hz is just too much for a road car, 1.5-1.8Hz is a good compromise IMO. I prefer stock sways for road usage, stiffer front for track. |
| The Following 3 Users Say Thank You to marco_mc22 For This Useful Post: |
#4193 |
Dismember
I really wish suspension were more straight forward.
At least on the track, things are more figured out for the platform.
#4194 |
Drives: 2023 BRZ
I've found the best way to learn about it is through first-hand experience. Go drive as many setups as you can, in as many different environments as you can. It will become more clear to you which is the best for your priorities. Reading about suspension on the Internet is often an exercise in frustration, theory, and inexperienced opinions. Nothing beats real-world experience.
Director of Rocky Mountain 86CUP
| The Following 7 Users Say Thank You to Pat For This Useful Post: | CSG Mike (06-30-2022), EAGLE5 (06-29-2022), marco_mc22 (06-29-2022), Racecomp Engineering (07-01-2022), Scargod (06-30-2022), strat61caster (06-30-2022), timurrrr (07-02-2022) |
#4195 | |
Drives: Toyota 86
Also, suggest you to invest in a good pyrometer, that’s really helpful. |
#4196 | |
| The Following User Says Thank You to Tatsu333 For This Useful Post: | marco_mc22 (06-30-2022) |
#4197 |
Agree with Pat.
I've driven and setup; Bilstein B14/B16, custom Bilstein, custom Megan, KW V3 Driven briefly; Ohlins, Tein, and Godspeed. Ridden; JRZ, MCS For a 99% street car with 1% sporty/track with a focus on backroads comfort, of what I've driven; KW. I want to try Koni Yellows on otherwise stock suspension, but time and money have not permitted it. I think twin tubes at softer settings are great street shocks that soak up most road imperfections, the KW V3's turn up enough to be fun on track/autox when needed. The Ohlins stuff I've driven/ridden with is a bit weird, too stiff for the road, too soft for hard driving, but they may not have been setup well for their applications and I may not have experienced best of breed. Enough people swear by them that I won't advise against going for Ohlins, but at $2k buy in plus another ~$1k for a revalve I'd be looking at MCS instead. For setting up anything; spring rates drive compliance, full stop. A 400#/7k kit is too stiff for backroads on this chassis imho, my progressive spring Bilsteins were right on the limit I think, I wouldn't want to go any stiffer in the rear. Yes damping matters, but the spring is the driving force in how the car will absorb the road. 3k-6k linear rate springs would be my range, and softer the better imho, which is why I want to try stock springs on Koni Yellows. Dampers should be compliant, I gave up on trying to be a curve guru, find someone who knows their shit and trust them (presuming they've done what you want before, if you're an R&D case be prepared to have it not come out perfect) or just take what's off the shelf. |
| The Following User Says Thank You to strat61caster For This Useful Post: | Lucky21 (06-30-2022) |
#4198 | |
The 8kg upcoming CSG damper rides overall even smoother than the 6kg square CSG Spec Flex A, which rides smoother than stock. |
#4199 | |
Track Day Junkie
Drives: 2022 BRZ Limited
It's hard to imagine that "The 8kg upcoming CSG damper rides overall even smoother than the 6kg square CSG Spec Flex A, which rides smoother than stock." is realistic.
Try this Jalapeno son! It ain't hot...
Scargo on IWSTI (Journal of STI track car) Scargod on NASIOC. Track Day Videos |
#4200 | |
Drives: Toyota 86
It’s realistic but it’s not the point, using 8kg springs (>2Hz) on a car driven 99% of the time in the streets/backroads/canyons with street tires or even winter ones depending on the season doesn’t make any sense IMO. The same great damper we’re talking about would control softer springs without problems, taking care of the backroads/canyon part simply stiffening the damping and allowing you to use a wider range of tires. |
| The Following User Says Thank You to marco_mc22 For This Useful Post: | Racecomp Engineering (07-01-2022) |
| Air Suspension Discussion Thread - Let's Get Nerdy | Andrew@ORT | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 174 | 02-13-2016 04:17 PM |
| RallySport Directs Everything Suspension thread!! | RallySport Direct | Brakes, Suspension, Chassis | 21 | 07-02-2014 06:31 PM |
| The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 09:15 AM |
| 2012 Team USA vs the 1992 Dream Team | ERZperformance | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 09-14-2012 07:19 PM |
| Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 11:13 AM |
