#4033 |
Drives: '16 BRZ Limited
Currently have RaceComp Yellows mated to stock struts my by 16 BRZ. I don't plan on switching to coils anytime soon, but was considering switching whenever the time comes to replace the stock struts.
I was looking at the RCE super street OR the CSG spec Tein Flex A's. Any feedback on how both compare to the RCE Yellows on stock struts. I don't plan on lowering thr car any more than the current ~1" it's lowered either. All help is welcome, even though it's not an upgrade o plan to do soon. |
#4034 |
Drives: 2019 BRZ Sport-Tech RS
I have a 2019 BRZ PP which I'll be getting the 10mm tS springs for soon. I don't like the Sachs dampers so I was planning to upgrade to the Bilstein B6. The problem is there is a major supply issue in Canada right now. No retailer can get the rear shocks in stock.
Autocross and track season is right around the corner so I'd need something ASAP. Are there track worthy alternatives to the B6? Our should I just stick with the tS spring + PP Sachs damper and wait for Bilstein supply issues to improve? I'm a bit hesitant on the Koni yellows since I don't want to fiddle with adjustable damping rates. |
#4035 | |
- Andrew
Website
https://www.racecompengineering.com/ Instagram: https://www.instagram.com/racecompengineering https://www.instagram.com/theapexfiles <- tech articles |
#4036 |
Hi All,
My 2013 FR-S is getting its 2017+ non-PP struts mated to RCE Yellows put on this weekend. I also have camber bolts for the front but the rear will have no adjustment. The car is a DD/weekend back road warrior primarily. I'm also on OEM wheels. Can anyone recommend alignment settings given this setup? I've poked around in various threads but don't know where to start with alignment and don't want to go to an alignment shop with nothing. Thanks |
#4037 | |
Drives: 2022 GR86
| The Following User Says Thank You to timurrrr For This Useful Post: | Racecomp Engineering (04-20-2021) |
#4038 | |
- Andrew
Website
#4039 |
Drives: 2017 Toyota 86 (860 SE)
Just finally ordered the RCE Yellows/Bilstein kit I've been eyeballing for months! The rest of the suspension is stock, and I'm 100% street at the moment... Any point to camber bolts at this point, you think?
#4040 | |
Subaru part numbers bolt - 901000394 nut - 902380008 Need to get 2. - Andrew
Website
#4041 |
| The Following User Says Thank You to ninzuh For This Useful Post: | Racecomp Engineering (04-20-2021) |
#4042 | |
Drives: 17 Asphalt 86
They bring stuff in from the states which may explain how they get parts quicker than some. |
#4043 | |
I gained almost a full 1° with the lower bolt up top. |
#4044 |
Drives: 2022 GR86
#4045 |
Okay cool. So my next question I guess is how much negative camber is desirable for a street car? I mean I like taking onramps as aggressively as the next guy, but the vast majority of my mileage is just A to B commuting and errand running.
| Air Suspension Discussion Thread - Let's Get Nerdy | Andrew@ORT | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 174 | 02-13-2016 04:17 PM |
| RallySport Directs Everything Suspension thread!! | RallySport Direct | Brakes, Suspension, Chassis | 21 | 07-02-2014 06:31 PM |
| The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 09:15 AM |
| 2012 Team USA vs the 1992 Dream Team | ERZperformance | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 09-14-2012 07:19 PM |
| Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 11:13 AM |
