Old 10-20-2020, 05:21 PM   #3949
Racecomp Engineering
Originally Posted by FLYFISHR View Post
I was looking to upgrade my 2014 BRZ with lightly use 2018 OEM SACHS PP SHOCKS and springs. What else should I consider other than a straight swap? I already have camber bolts installed. This is for a daily driver.
Nothing else "needed", just have a look at the rest of your car (bushings, etc) to see if everything is in good shape.
The 15mm swaybar from later model years would be a good cheap upgrade too if you want to keep things mostly factory.
- Andrew
The Following User Says Thank You to Racecomp Engineering For This Useful Post:
FLYFISHR (10-20-2020)
Old 10-20-2020, 06:02 PM   #3950
Alignment, and replace any worn bushings, if any.
Old 10-20-2020, 09:30 PM   #3951
strat61caster
strat61caster's Avatar
Have you guys come across any bushings prone to wear out?
Seems like this car is fairly solid in that respect even with hard track miles we're coming up on 10 years without any common cracking or crumbling like say Honda's compliance bushing in the FLCA.
ineedyourdiddly
e1_griego (10-21-2020)
Old 10-21-2020, 12:59 AM   #3952
I've seen some crack/tear even at the 5 year mark. It's usually not how you drive it, but where you live and store the car.
Old 10-21-2020, 02:47 AM   #3953
FLYFISHR
FLYFISHR's Avatar
Drives: 2014 BR"ZED" Sport-tech DGM MT
Which bushings should I check for wear
Old enough to know better but young enough to do it again
FLYFISHR is offline   Reply With Quote
Old 10-21-2020, 09:33 AM   #3954
Grady
Grady's Avatar
All of them. You are going to have your car up on jacks and taken apart. No better time to do a good inspection of everything.
The Following User Says Thank You to Grady For This Useful Post:
FLYFISHR (10-21-2020)
Old 10-27-2020, 05:14 AM   #3955
sftateofmind
Evening Primrose
sftateofmind's Avatar
Originally Posted by Racecomp Engineering View Post
Try softening the dampers a couple clicks and see if it improves.
- Andrew
I did 3 clicks to the soft side all around and my ride has improved greatly. Going over bumps, potholes, ect. is much better and handling feels better on the highway.
Thanks!
sftateofmind is offline   Reply With Quote
The Following User Says Thank You to sftateofmind For This Useful Post:
Racecomp Engineering (10-27-2020)
Old 10-27-2020, 09:56 PM   #3956
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Pulled my summer wheels off to swap for winters and noticed my driver side tires were pretty mangled on the inner shoulders. Passenger side was more or less fine.
I ran the car at calabogie motorsports park in August for two 30 minute sessions. I did the west track that day which is known to be hard on the driverside tires.
-1.4° camber front with 0 toe
-2.3° camber rear with 0.16 degree toe in.
Somewhat normal wear? I've never seen an inner shoulder wear on one side only.
Photos shown top to bottom
Left front, left rear, right front
Old 10-27-2020, 11:49 PM   #3957
bmacfrs
bmacfrs's Avatar
Drives: 2013 FRS
I'd suggest you get the alignment checked. I doubt it's set to what you think it is. That's a sign the toe is off or something is bent. While you're at it get the camber corrected.
Sent from my SM-G960U using Tapatalk
WIFE: "How can there be anything left to buy?"
bmacfrs is offline   Reply With Quote
Old 10-28-2020, 12:26 AM   #3958
Drifter X
Drifter X's Avatar
Drives: 2019 Toyota 86 TRD SE
Yeah I agree. That’s gotta be toe wear. Get you’re alignment checked. I don’t think your toe is at 0°
Drifter X is online now   Reply With Quote
Old 10-28-2020, 06:43 AM   #3959
RToyo86
RToyo86's Avatar
Thanks. I already booked an appointment to have the alignment checked.
The alignment was near perfect for two years after checking it and now I've had two alignments done in 6 months and it appears to be off again.
One in may, another in August.
Old 10-28-2020, 08:28 AM   #3960
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
I ran the specs below all of 2020 but recently purchased some caster plates. The pyrometer suggested I could use a little more front camber with A052s. I am planning on bumping the camber up to -4.0 in light of that.
What is a good caster setting for a track car on the sticky 200tw tires? Some people say as much as you can get, others say on the upper side of the OEM specs.
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
Old 10-28-2020, 09:51 AM   #3961
churchx
churchx's Avatar
Drives: 2014 GT86
"sticky 200tw tires" too generalized. Even within same tire class optimal camber may differ between different manufacturer different tires. But you wrote you have pyrometer - wonderful, that's the tool to be used to find THE right camber you need. Or don't bother if you want to limit spendings/further mods, -3 already is much better then stock 0, and even if you may benefit from a bit more, as you wrote, i guess it will near diminishing returns. And also will make a bit less universal (eg. in wet, less camber is more optimal, due less side-Gs and less tire deformation to be compensated with negative camber).
Old 10-28-2020, 10:32 AM   #3962
What was going off in your recent alignments?
- Andrew
Search this Thread:
Advanced Search
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 04:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 06:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 09:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 07:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 11:13 AM
