#3921 | |
Drives: FR-S Whiteout
I myself spend countless hours devising what I would think make an existing 2 way shock work. Did all the work and then some. Threw them on the dyno.. Turns out the compression adjustment dont add anything but extra hysterisis... Wasted time and energy that I could have just avoided had I not been so obsessive about details. Edit: Rebound adjuster.. not bad not as digressive as I would have liked "Compression adjuster" response... Hmm.. the pictures are not showing?
Intent > Content
cowardice is the mother of cruelty. Last edited by solidONE; 10-02-2020 at 12:16 AM. |
| The Following User Says Thank You to solidONE For This Useful Post: | strat61caster (10-02-2020) |
#3922 |
Drives: 2300LB FRS
Cut out all the metal from the doors, tomei since it's the lightest, carbon roof, carbon trunk, mph fab hood, essex sprint bbk, "swiss-cheesed" where applicable
| The Following User Says Thank You to ShibusaTouge For This Useful Post: | strat61caster (10-02-2020) |
#3923 |
Drives: BRZ '13
Need an advice about further suspension spec. What we've got now is 2013 brz on stock shocks and Eibach sportline springs +camber bolts on front(-2 camber atm). This car is mainly used for track days and i don't care about ride comfort, only performance matters
There're still a lot of things to be done with the car for track days besides the suspension so the question is should i go for some kind of coilovers like BC racing DS series or they aren't worth it and it's better to buy new B6 for my Eibach springs and save money for other mods?
#3924 |
Drives: 2014 GT86
Alarik: more, more, MORE camber, if for track. Move up to -3 to -4 in front, depending on tires/track.
#3925 |
Drives: BRZ '13
#3926 |
Drives: 2014 GT86
You can add front camber with stock shocks if you add eg. pedders eccentric rubber topmounts and/or powerflex front lca rear bushing on top of camberbolts. Or camberplates.
#3927 | |
Because compromise ®
Drives: Red Herring
His second post in the thread details all the weight savings.
| The Following User Says Thank You to Captain Snooze For This Useful Post: | CSG Mike (10-14-2020) |
#3928 | |
Weight Weenie
Drives: 15 FR-S
https://www.ft86club.com/forums/showthread.php?t=118243 |
#3929 | |
JHerbert Racing
Drives: 2013 Scion FRS
| The Following User Says Thank You to Takumi788 For This Useful Post: | Captain Snooze (10-14-2020) |
#3930 | |
What kind of tires do you use? - Andrew
Website
https://www.racecompengineering.com/ Instagram: https://www.instagram.com/racecompengineering https://www.instagram.com/theapexfiles <- tech articles |
#3931 |
Drives: BRZ '13
atm only spec that i described +intake, if it matters. But i got plans to reduce weight a bit, headers+exhaust and dyno tune. Wheels 7.5J, tires Federal RS-RR\Rs-Pro, Hankook RS4 215 or 225 width, depends on local series regulations.
#3932 |
Sorry I meant what other choices for suspension do you have? KW maybe?
- Andrew
Website
#3933 |
Drives: BRZ '13
#3934 |
Most of those (including Tein) are much better than BC. We like KW and Bilstein a lot but they don't always come with camber plates.
- Andrew
Website
https://www.racecompengineering.com/ Instagram: https://www.instagram.com/racecompengineering https://www.instagram.com/theapexfiles <- tech articles Last edited by Racecomp Engineering; 10-05-2020 at 02:27 PM. |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | Alarik (10-06-2020) |
| Air Suspension Discussion Thread - Let's Get Nerdy | Andrew@ORT | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 174 | 02-13-2016 04:17 PM |
| RallySport Directs Everything Suspension thread!! | RallySport Direct | Brakes, Suspension, Chassis | 21 | 07-02-2014 06:31 PM |
| The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 09:15 AM |
| 2012 Team USA vs the 1992 Dream Team | ERZperformance | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 09-14-2012 07:19 PM |
| Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 11:13 AM |
