86WORX
Old 09-30-2020, 03:01 AM   #3907
sftateofmind
Evening Primrose
sftateofmind's Avatar
Hey folks,
I recently dropped down an inch on Silvers coil overs. Absolute noob when it comes to suspension.
Prior to being lowered I really enjoyed how connected I felt to the road when going around corners or even on the freeway getting up to 80mph.
Now all of that has been seemingly lost. My ride is a bit twitchy when getting to higher speeds on the freeway. I feel like a paper weight when it is windy.
Going into left hand turns the back end feels like it wants to jump out. The ABS will actually cut on on corners it didn't prior. I had this similar experience on a left hand turn on the freeway going 50mph that suprised me. Normally I would just roll right through no problem.
Right hand turns are pretty similar experience as left hand turns.
The car feels a lot looser than prior to the drop, not to mention the bumpier ride. Any suggestions on how to get back to that feeling of being planted to the road? I've had two allignments done and it just doesn't feel like things are correct since the ABS still comes on.
Also will a different spring rate help with the bumpy ride?
Thanks!
sftateofmind is offline   Reply With Quote
Old 09-30-2020, 03:30 AM   #3908
churchx
churchx's Avatar
Drives: 2014 GT86
Post printout pic or numbers from those alignments.
The Following 2 Users Say Thank You to churchx For This Useful Post:
Racecomp Engineering (09-30-2020), strat61caster (09-30-2020)
Old 09-30-2020, 11:09 AM   #3909
Originally Posted by sftateofmind View Post
Hey folks,
Thanks!
Do you have an alignment printout?
What spring rates do you have now?
Ride quality is mostly down to suspension travel, spring rates, and shock valving. I don't know much about Silvers coilovers, but if the valving isn't good, different spring rates will only help a little bit. Valving is reeeeeally important.
- Andrew
Old 09-30-2020, 12:51 PM   #3910
strat61caster
strat61caster's Avatar
You bought adjustable damping coilovers, use the adjusters.
ineedyourdiddly
Old 09-30-2020, 01:55 PM   #3911
A good place to start!
- Andrew
Old 09-30-2020, 02:07 PM   #3912
ShibusaTouge
ShibusaTouge's Avatar
Drives: 2300LB FRS
My FRS weighs about 2300 lbs (fully gutted, caged, no ac). And it's about ready to go on the road. Would I need to order custom valved/dampened/spring rate coilovers due to change in weight distribution and weight overall?
ShibusaTouge is offline   Reply With Quote
Old 09-30-2020, 02:49 PM   #3913
M0nk3y
Depends on more conditions than that.
Will the car see aero? Will it be on R-Comp tires or street tires? Etc etc.
For me, going from autocross to track setup (including Aero and R7s) the only changes necessary was less bar and more bump. However I revalved my shocks during autocross to better suit my use.
My opinion, run a standard shock offering with spring rates you want to run. Get an idea of what fits your driving style with what tracks you’re going to encounter and if you’re out of adjustment range then readdress with revalve changes.
Most shock offerings can cover a wide range of conditions. Revalve should be there if/when you need it to narrow in on a specific range and make adjustments more precise
Kyle H. - #89 STX
The Following 3 Users Say Thank You to M0nk3y For This Useful Post:
Racecomp Engineering (09-30-2020), solidONE (10-01-2020), strat61caster (09-30-2020)
Old 09-30-2020, 04:00 PM   #3914
strat61caster
why did you spend a bunch of money/time gutting/caging it if you're going to not use the best of the best of the best sir, with honors?
Anything worth it's salt will have a damping adjustment that suits your needs (lighter car means stiffer effective wheel rate which means more damping necessary then the car's curb weight+suspension design would dictate, softer spring should help if damping doesn't go stiff enough provided the car is responsive enough as is) or can be revalved after you get some test time.
ineedyourdiddly
Old 10-01-2020, 09:16 AM   #3915
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
If you are going to seriously track the car you should absolutely have your coilovers custom valved. I went from a pair of off the shelf units to a custom valved set and it made a huge difference in feel and performance. Also dont skimp on corner balancing.
How did you get the weight so low? 2300lbs!? Mine is gutted the same amount with a rollbar (not a full cage), no ac and weights 2475 with a half tank. There was a forum member named Anthony here for a while that went to crazy extremes to lose weight and he got to 2280 but that didn't have a cage.
https://www.ft86club.com/forums/showthread.php?t=42284
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
Old 10-01-2020, 10:54 AM   #3916
That's super light!
Custom coilovers might be a good idea.
Is this a track day car or a competition car?
Happy to talk options with you if you like.
- Andrew
Old 10-01-2020, 04:16 PM   #3917
ShibusaTouge
Drives: 2300LB FRS
I'm actually good friends with Anthony. He inspired my build lol
Old 10-01-2020, 04:16 PM   #3918
ShibusaTouge
Drives: 2300LB FRS
Originally Posted by Racecomp Engineering View Post
That's super light!
- Andrew
It'll be primarily a wheel to wheel car.
The Following User Says Thank You to ShibusaTouge For This Useful Post:
Racecomp Engineering (10-01-2020)
Old 10-01-2020, 04:29 PM   #3919
Takumi788
JHerbert Racing
Takumi788's Avatar
Still need to know how you got down to 2300 lbs with a cage! lol. I am out of things to remove and apparently my car is still fat.
Old 10-01-2020, 04:33 PM   #3920
That's always fun. We've put together suspension systems for a couple w2w cars including at least one for this chassis. I would recommend a custom set up for your car. Would need corner weights and info on aero, geometry changes, etc.
- Andrew
Search this Thread:
Advanced Search
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 04:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 06:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 09:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 07:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 11:13 AM
