#3557 | |
Thanks
Actually decided on Tein Flex Z. It was only a bit more $ in this application and no assembly required.
#3558 | |
Drives: '13 BRZ Limited
Much appreciated!
| The Following User Says Thank You to Kordless For This Useful Post: | Racecomp Engineering (03-09-2018) |
#3559 |
Drives: 2013 Firestorm red FRS manual
I have a set of the mann engineering AST 4150 coilovers. I'm having trouble finding info on which camber plates will work with these and what i might need. Can anyone provide advice? Thanks.
#3560 |
Another question.
At what point would one need to get Adjustable Front Endlinks? Thanks,
#3561 | |
- Andrew |
#3562 | |
If so, do you require them at all ride heights or specific ride height? I'm trying to figure out exactly what I need to install these. I already have SPL Rear Lower Control Arms. Thanks,
#3563 |
Drives: Legacy GT
You would want adjustable endlinks with any coilover if you want to do a good job at corner balancing. And you really should corner balance coilovers because they create the possibility of having the corner weights way off.
On cars where the front and rear endlinks are nearly the same (like 04-07 sti), you can cheat and just buy one set and split it between the front and rear since you don't really need both endlinks to be adjustable. But on these cars it's useful to have both front endlinks adjustable when changing ride height to make sure nothing is hitting/rubbing. Last edited by jamal; 03-12-2018 at 12:42 AM. |
| The Following 2 Users Say Thank You to jamal For This Useful Post: | fatoni (03-11-2018), Racecomp Engineering (03-12-2018) |
#3564 | |
Drives: 2013 ARGENTO A/T
I've ordered rear LCAs now in hopes to bring the alignment right back to square one. I adored the handling stock. I finally realized that the "feeling" was the fine balance of oversteer and oversteer. It's so easy to to describe that feeling because it made me smile..and I don't smile anymore. I'm looking at -1 rear and 0 to -.5 front, with slight toe out front and none to slight toe in rear... basically factory spec. I'm just hoping that my modest lowering and stickier tires weren't enough to disrupt that original feeling on their own regardless of alignment. |
#3565 | |
Drives: 2014 GT86
Spacemane969: For reference factory alignment front camber 0, toe 0, rear camber -1.2, toe in 0.2.
But overall grip by much grippier tires will still be up, even if you won't up negative camber. As for "like stock", i don't know if i'd wish to pursue it. Yes, on it & primacies even at stock lack of power it was easy to loose grip with throttle, but i also didn't like it's bias to understeer. That i "cured" by more camber front then rear (opposite to stock). In your case i'd probably try camber -1.5 front, -1 rear, zero toe around, for daily driven only car, no matter what tires. Quote:
Maybe - allseasons for colder weather, proper summer tires with stiff sidewalls for .. well, summer? . And not too wide, to not to grip-tramlining.
| The Following User Says Thank You to churchx For This Useful Post: | Spacemane969 (03-20-2018) |
#3566 | |
I don't remember understeer at all when I bought it. It was used and had beautifully broken in primacies that were hard and sharp as a tack in the corners. But, what I also believe to be a huge factor is my inexperience with this type of car.. I believe I was pushing with what the tires gave me in a safe manner, but not necessarily balls to the wall at the limits. Having said that I drive at 10/10s now over the years but it's much more unnerving and much less satisfying. As for tires I'm pretty much done. This is my 3rd set after stock, including a winter setup, and I just can't justify another set, it's gotten way too expensive for me personally. The only consideration would be finding used primacies and selling the AS3s. But even then there is the cost of mounting and balancing, and seemingly endless alignments for instance trying out your recommended setup and possibly still being unsatisfied. Thanks for your input, I'm curious to see your take on if I'm being biased based on this being the first car I've driven of its kind. I will say that even through all the ups and downs, it's been life changing owning this car and learning about the driving Dynamics and characteristics that are brought to life. |
#3567 |
poor man's evora
Drives: Turbod BRZ
I'm running a turbo brz around 408whp. Suspension setup is tein flex coilovers, 17x9 rpf1 et 45, 255/40/17 indyhawk 500, spc rear lca, rear toe arms, whiteline bushings subframe and differential. I have my setup at -2.0 front and -1.0 rear camber, trying to gain as much contact in the rear. Would it would be better to add more negative or positive camber for either the front or rear? Thanks
#3568 |
Drives: 2014 GT86
malubawla: if you are ok with front grip, i'd up rear camber slightly, eg. to -1.5, but instead rather get extra grip/stability in rear under throttle more with slight toe-in, if it's currently zero. Also maybe turn rear coilovers a bit softer.
Remember, that negative camber adds more grip in turns/curves, when it compensates tire sidewall flex due side-Gs/mass transfer to get as result even contact patch. In straight line more camber won't bring more grip, rather opposite, as you are making contact patch less even/optimal w/o that sidewall flex of when turning to compensate. You can also consider moving up to grippier compound tires, if you find current grip lacking. |
#3569 |
Drives: 2015 Scion FRS
Thanks RCE! I installed a set of Tarmac 2's this winter. WOW! I came from stock dampers. I went from 35th pax last year to 9th pax ,same autox club.
THANK YOU ... LOVE THEM. Thanks to the forum for all the install help. They feel great! |
#3570 | |
- Andrew |
| Air Suspension Discussion Thread - Let's Get Nerdy | Andrew@ORT | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 174 | 02-13-2016 04:17 PM |
| RallySport Directs Everything Suspension thread!! | RallySport Direct | Brakes, Suspension, Chassis | 21 | 07-02-2014 06:31 PM |
| The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 09:15 AM |
| 2012 Team USA vs the 1992 Dream Team | ERZperformance | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 09-14-2012 07:19 PM |
| Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 11:13 AM |
