#3459 |
Drives: accord
So I’m finally done with my suspension spec out for my 13brz. Looking for some advise
Bilstine B6, OE BRZ front spring 2.7k, OE FRS rear spring 3.8K, OE front sway 18mm (+1 if require), 15mm rear sway, Enkei rpf1 17x8, +45mm, on 225x45x17. Plus whiteline rear subframe blushing insert. Total parts cost w/o tires is under 2K. I’m hoping to achieve minimal drop, little more grip (stock engine), better balance towards oversteer. It’s mostly for DD, but eventually like to do track. Thanks. Last edited by wu_dot_com; 01-30-2018 at 05:41 PM. |
| The Following User Says Thank You to wu_dot_com For This Useful Post: | bhmax (01-30-2018) |
#3460 | |
- Andrew |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | wu_dot_com (01-30-2018) |
#3461 |
Drives: accord
#3462 | |
- Andrew |
#3463 | |
Drives: accord
![]() Perfect, this is exactly what I’m looking for, -2 to -1.5 for the front camber. Since I’m planning to use OE top hat, can this adjustment be done with $50 camber bolts? Please advise. |
#3464 | |
https://www.amazon.com/Specialty-Pro...ords=81260+spc |
| The Following 2 Users Say Thank You to strat61caster For This Useful Post: | Racecomp Engineering (01-31-2018), wu_dot_com (01-31-2018) |
#3465 |
And just be sure you take it to a good competent alignment shop.
- Andrew |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | strat61caster (01-31-2018) |
#3466 |
Undisputed El Presidente
Drives: Zenki 37J ZN6
^THAT
#3467 |
Drives: 2017 Series Yellow BRZ
#3468 |
A Nobody
Drives: FRS
hey guys, new to the forum and modding but ive had stock long enough and want to change. i have a 2014 frs with 95,000 km and was looking at lowering springs but after reading they have a chance to blow and not to blow but since i have many miles on it should i get the new 2017 shocks to go with some springs(rsr/eibach/tein 1.2-1.4") or just buy aftermarket shocks? thanks
#3469 | |
Drives: 2015 BRZ
#3470 |
A Nobody
Drives: FRS
is also upgrading to 2017 shocks a viable option? just asking cause since they would be cheaper? not for permanent cause eventually i do wanna get bilstein
#3471 |
Drives: 2015 BRZ
The 2017 are still OEM and were not exactly designed for aftermarket springs unless you get the Sachs dampers from the BRZ PPs. Using 2017 dampers is most likely not going to be any different than using dampers from 2013-2016. Also, the RCE Yellows are a good option as they were designed for OEM shocks and struts and they only lower the car 20mm
#3472 | |
A Nobody
Drives: FRS
| Air Suspension Discussion Thread - Let's Get Nerdy | Andrew@ORT | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 174 | 02-13-2016 04:17 PM |
| RallySport Directs Everything Suspension thread!! | RallySport Direct | Brakes, Suspension, Chassis | 21 | 07-02-2014 06:31 PM |
| The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 09:15 AM |
| 2012 Team USA vs the 1992 Dream Team | ERZperformance | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 09-14-2012 07:19 PM |
| Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 11:13 AM |
