Old 11-12-2014, 06:02 PM   #2157
SubiePig
Drives: -'02 PSM WRX, '94 Miata, '13 BRZ
Originally Posted by ja1217 View Post
2900 lbs includes me in the drivers seat and 70lbs of ballast in the rear. Minimum weight for the car in TTD is 2885, which I can get to with only about 1/2 a tank of gas.
I'd consider doing sway bars, but those cost points in NASA's TT system, so I'm just going to stick with the stock ones. I can swap out my current springs without taking any additional points.
I forget the base weight is 2885, I took my last bit of points for weight and was at 2835. Trying to keep the car TTD fast and STX legal was getting to hard so I just went to TTC. :/
Sponsered by:Chasebays/Corr Performance Tuning/KartBoy/Bad Panda Motorsports/Racer-X Fabrication
STX Build thread 14th/67 SCCA Nationals (2014)
SubiePig is offline   Reply With Quote
Old 11-12-2014, 06:30 PM   #2158
kster1
kster1's Avatar
Just got off the phone with Ohlins USA and they said they usually charge about $120 a corner for revalve/service, which sounds quite reasonable to me, so I think I will be sending mine in soon as they said they end up getting pretty busy with professional race teams over the winter.
Now all that I need to do is buy the springs. Any suggestions on brand?
FWIW, I'm running Eibach race springs with my R&T coilovers (spring rate of 350F/425R). And they fit fine.
kster1 is offline   Reply With Quote
The Following User Says Thank You to kster1 For This Useful Post:
ja1217 (11-12-2014)
Old 11-12-2014, 06:35 PM   #2159
ja1217
Drives: 2004 Toyota RAV-4 5M
Yeah, I will probably move up to TTC eventually, but for now I'm going to try to max out my setup in TTD. Next year is going to be interesting as I am most likely going to be reducing tire grip by moving to the Maxxis tires, but hopefully increasing grip in the rest of the car by going to stiffer springs and a clutch LSD, all while adding more power by doing full exhaust and intake. Could be faster, could be a recipe for disaster. All I know is I lose more time on the straights to those dang E36 M3s than I can make up in the corners.
ja1217 is offline   Reply With Quote
Old 11-12-2014, 06:48 PM   #2160
SubiePig
I set the TTD Record at MSR Houston this year on 255 RS3's, Kw's, full exhaust, stock tune, 22mm front swaybar, and HC800 pads. It can be done!
The Following User Says Thank You to SubiePig For This Useful Post:
Racecomp Engineering (11-12-2014)
Old 11-12-2014, 07:35 PM   #2161
I'll need to look through the rule book again. I know a lot of the bushings can be free, but some aren't. Swaybars definitely take points though and are a no-go for me.
Also, would your springrate recommendations change much for the Maxxis RC-1 tires (slightly more grip than NT01's, I think)?
Here is the section of the TT rules regarding suspension bushings:
This sounds like I'd be able to do the Whiteline polyurethane crossmember mount bushings, but I'm afraid the other bushings around sway bars, control arms, etc will cost points.
Gotcha. Yeah go without the swaybars for sure.
Spring rates should be good with either of those tires, might want a little more camber though.
Hyperco, Swift, Eibach.
- Andy
The Following User Says Thank You to Racecomp Engineering For This Useful Post:
ja1217 (11-12-2014)
Old 11-12-2014, 11:53 PM   #2162
FRS Johnny
FRS Johnny's Avatar
Drives: 2013 FR-S Whiteout MT
Originally Posted by Racecomp Engineering View Post
FA coilovers use separate ride height and preload adjustments, so if you're using the lower mount to adjust height you won't be adding any bump travel back when raising the car.
Do you mostly feel it over dips? How stiff do you have your dampers set?
- Andy
I believe the dampers are less than 10 clicks from full stop. Should I try to stiffen them and try that out?
When in doubt, throttle out!
FRS Johnny is offline   Reply With Quote
Old 11-13-2014, 11:56 AM   #2163
If you feel it more over dips and just after the wheel should be extending, try softening them a few clicks. I'm thinking the rebound is too firm and the wheel isn't able to extend, aka it's "packing down."
Just a thought from a few thousand miles away.
- Andy
FRS Johnny (11-14-2014)
Old 11-17-2014, 09:46 AM   #2164
normancw
normancw's Avatar
Drives: 128i
I have RCE Tarmac 2 coilovers - is it OK to put it up on jack stands for the winter (3-4 months)?
I plan on doing a few mods over the winter and it would be easier to just leave it on stands.
normancw is offline   Reply With Quote
The Following User Says Thank You to normancw For This Useful Post:
CSG Mike (11-17-2014)
Old 11-17-2014, 09:54 AM   #2165
That's fine.
- Andy
The Following 2 Users Say Thank You to Racecomp Engineering For This Useful Post:
CSG Mike (11-17-2014), normancw (11-17-2014)
Old 11-17-2014, 01:55 PM   #2166
enivid
enivid's Avatar
Drives: WRB JR BRZED
I'm currently at - 2 camber in the rear using the whiteline rear camber bushing kit. I'm lowered about an inch. Do you think I'll be able to get - 2.5 out of it?
enivid is offline   Reply With Quote
Old 11-17-2014, 02:46 PM   #2167
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Im on RCE yellows dropped an inch and I maxed out around 3 degrees in the rear with the WL camber bushings so you should be able to I'd imagine. But as always YMMV.
Old 11-17-2014, 03:04 PM   #2168
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
Are the sports-i coil overs from rs-r really that much better than the competitor like fortune auto, bc racing or any other kit around the $1800 tag? If so what makes it bette, valving?
@CSG Mike @Racecomp Engineering
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline   Reply With Quote
Old 11-17-2014, 05:01 PM   #2169
They're "better" in that the valving curve better suits the springs the coilover is paired with.
yomny (11-17-2014)
Old 11-17-2014, 09:17 PM   #2170
PNW FRS
PNW FRS's Avatar
Troubleshooting front-end noise - Part Deux
Background: Added struts/coilovers (Speed by Design Pro Street). Asked a question earlier in this post re: spring bind (wind) and ended up buying some Torrington Bearings (Fortune-Auto) for the front... and no more spring bind(wind). Huzzah!
However, the Torrington Bearings haven't eliminated some erratic occurrences -- coming from front-right (best as I can discern...) -- that sounds almost like a metal-on-metal "crunching" noise. I've gone through the setup and best as I can tell, everything on the strut is buttoned down.... top nut, lock rings, bolts tight, etc. Just got back from a 60 mile drive that I knew would provide a good mix of smooth asphalt, mild to medium bumpy asphalt, to "Oh yeah.. that's rough..." asphalt.
The good news... at speed (e.g., 50+ on smooth asphalt or cement), everything runs nice... nothing odd sounding. If I throw in some quick right-left-right-left etc. maneuvers.. there will be a slight crunching sound (very mild... as if the weight shift is making something move)
Then... straight-line path... transitioning to mild-to-medium or rough pavement... the first sound of the "crunch" comes through loud and clear... and most times, is followed by continuous "crunching" until the car comes to a stop. Same in a parking lot...driving slow... smooth asphalt... no noise.. but go over a speed bump (slowly) and the compression and release of that brings on the "crunch."
And far as I can tell, it is only coming from the front-right of the car. (I know that noise can emanating elsewhere, but it's pretty loud and clear from the front-right.
Pretty sure that spring pre-load is where it should be. All four corners are set the same... there is no noise coming from the other 3 corners.
Looking for suggestion for where to start the next round of troubleshooting... go back to the alignment shop and see if maybe "something" didn't get buttoned down after the alignment (cuz it kind of sounds like "knuckle-crunching" when it's at its worst. Or.. is the culprit likely the strut itself (which if so... how best to phrase the question to the vendor since the strut is still under warranty.
Thanks in advance for any additional insights....
2013 Asphalt / MT
Olympia, Washington
PNW FRS is offline   Reply With Quote
The Following User Says Thank You to PNW FRS For This Useful Post:
CSG Mike (11-18-2014)
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 04:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 06:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 09:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 07:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 11:13 AM
