#2129 |
Drives: Asphalt 2013 FR-S
oh, 38 psi hot. I'll update my post to make it more clear.
#2130 | |
- Andy
Website
https://www.racecompengineering.com/ Instagram: https://www.instagram.com/racecompengineering https://www.instagram.com/theapexfiles <- tech articles |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | MINOCIN (10-21-2014) |
#2131 |
Thanks guys. I'll start off with a more aggressive alignment then and see how things go from there. Based off of @solidONE suggestion I think I'll go with -2.8 front and -2.4 rear.
I already have my next set of tires lined up. Track day tires: Hankook Ventus Z214 http://www.tirerack.com/tires/tires....1OLD&tab=Sizes These tires are a bit big for my 18x7.5 wheels but I couldn't resist the price. Daily tires: BFGoodrich g-Force Rival http://www.tirerack.com/tires/tires....7GFR&tab=Sizes I think these should fit well on my 17x8 wheels. As soon as I get the tires on I'll get a new alignment.
#2132 | |
Drives: FR-S Whiteout
#2133 | |
Basically, my track wheels will now become my dailys and the daily wheels will become my track shoes.
#2134 |
IC IC... Nice setup BTW.
| The Following User Says Thank You to solidONE For This Useful Post: | MINOCIN (10-22-2014) |
#2135 |
Drives: Nuisance BRZ
Anyone?
#2136 | |
Drives: Strangely.
I rode in a Miata the other day with bilstein coils, spring rates 500lb/350lb. What is that in metric? It rode much better than I expected.
My FR-S has a build thread!
(It's mostly full of Nissans) |
#2137 | |
500 lbs/in is about 9 kg/mm, 350 lbs/in is about 6.25 kg/mm. Remember though to compare across different cars you need the wheel rates. So you need to multiply by the square of the Miata's motion ratios, which are 0.69 front and 0.77 rear. So 9 kg/mm * 0.69^2 = 4.3 kg/mm up front. Firm for a light car, but different than 9 kg/mm on a FRS/BRZ. A better comparison would be suspension frequencies, but I'm not doing that right now. In comparison the front motion ratio for an FRS/BRZ is close to 1, so there's a BIG difference when comparing spring rates between cars. You have to look at the wheel rates. - Andy
Website
#2138 | |
Drives: Strangely.
Ah, a 2005 MINI: I see the issue. Stock shocks rode so much nicer on that year than the pre-2005s. Most of my admiration TBH is reserved for the newer cars. But with some firmer control arm bushing the R53 can be good too, as you may have noticed. Cool. Also I read that only the heaviest MINI wheels have '-lite' in their names. Go figure.
| The Following User Says Thank You to NissanGuy For This Useful Post: | Racecomp Engineering (10-22-2014) |
#2139 |
Off Topic
Installed my RCE Yellows and Whiteline camber bolts, then got an alignment. How does this look for a daily driver?
#2140 |
Drives: 2012 Toyota 86
I wish my rear camber was that even
| The Following User Says Thank You to troek For This Useful Post: | fstlane (10-26-2014) |
#2141 |
Drives: BRZ Limited
#2142 |
Off Topic
Firestone on N. Durango in the top left corner of the city. Ask for Alex. He's apparently the guy that does the alignments for the exotic racing experience at LVMS, and he's very comfortable aligning to given specifications instead of OEM spec. Since I got the lifetime alignment package, he said come in before an event, he'll tweak it for that event, then come in afterwards and he'll reset it back to daily driver spec.
| The Following User Says Thank You to gramicci101 For This Useful Post: | fstlane (10-26-2014) |
| Air Suspension Discussion Thread - Let's Get Nerdy | Andrew@ORT | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 174 | 02-13-2016 04:17 PM |
| RallySport Directs Everything Suspension thread!! | RallySport Direct | Brakes, Suspension, Chassis | 21 | 07-02-2014 06:31 PM |
| The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 09:15 AM |
| 2012 Team USA vs the 1992 Dream Team | ERZperformance | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 09-14-2012 07:19 PM |
| Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 11:13 AM |
