Old 10-17-2014, 02:16 PM   #2115
gramicci101
Off Topic
Originally Posted by Racecomp Engineering View Post
That is true and another good option if you're willing to go the coilover route. Our T0 do really well on track and for auto-x.
- Andy
That's my next step in my suspension journey. I just got my yellows, so I'm going to drive around on those for a while before deciding if I need more or not.
The Following User Says Thank You to gramicci101 For This Useful Post:
Racecomp Engineering (10-17-2014)
Old 10-18-2014, 08:53 AM   #2116
Fricke
Drives: Toyota GT86
I would not use 10k/7k spring rates...that is a recipe for understeer. Too soft in the rear. Yes you can add a big rear swaybar but I'd rather get the spring rates good first.
- Andy
okay got these coilovers for free, and they were pre-set with those springs then.
But if we start buying new springs for the BC racing br coilovers.
What would you recommend for spring rates, back and front.
if we think that the car will be used whit 180tw tires on the track.
Fredrik Wernboé
Fricke is offline   Reply With Quote
Old 10-20-2014, 03:15 AM   #2117
MINOCIN
MINOCIN's Avatar
Drives: Asphalt 2013 FR-S
@CSG Mike and @Racecomp Engineering et al,
I think I have a camber problem. Both my street and track tires are suffering additional wear around the corner edge of the tire. Almost like the tire is rolling over on itself.
My car is lowered by an inch on RSR Sports-i coilovers and I think that when cornering the camber is changing from negative to positive. The extra wear is occurring on both the front and rear tires, but mostly in the fronts.
Here are some pics of the tire wear from 2 track events ago at SoW,
And here are some pics from last weekend at Big Willow,
My last alignment was set for -2.2 up front and -1.5 in the rear.
I know it's not aggressive enough for the track but my street tires are also exhibiting the same type of wear. I drive enthusiastically on the streets but nowhere near as hard as I do on the track. I will be changing tires soon for both my street and track set of wheels, but I'm concerned that my new tires will suffer the same premature wear in the corners like these did. When at the track I do stiffen up the RSR coilovers, but I don't go too stiff because then the car get's too hoppy and/or twitchy on me.
So my question is, do you think that my lowered car is exhibiting positive camber under compression due to a lower roll center or do I just need go with a more aggressive alignment for both the street and track?
What do you think I should do?
1. If I have a roll center problem then should I purchase a correction kit?
http://www.whiteline.com.au/product_..._number=kca435
2. Should I raise the car up to more closely match stock height?
3. Should I get another alignment and go with -2.8 to -3 up front with -2 to -2.5 in the rear? The coilovers give me about -1.5 of camber when lowered and the crash bolts should give me about -1.75 more. In the rear I have adjustable LCAs that provide up to -2 degrees of camber.
4. Other suggestions?
Right now I really like the way the car feels. I don't really trust the car on high speed corners like turn 8 at Big Willow or Riverside at Buttonwillow, but it definitely feels better than stock. I really do like the RSR coilovers. They feel great on the street and I only track the car like 6 times a year, so I'm not looking to purchase another set of coilovers.
Thanks!
GFR - aka my build thread
"They don't think it be like it is, but it do." -Oscar Gamble
MINOCIN is offline   Reply With Quote
Old 10-20-2014, 08:02 AM   #2118
troek
troek's Avatar
Drives: 2012 Toyota 86
Looks like toe wear to me
Edit: sorry thought that was the inside edge.
Old 10-20-2014, 06:29 PM   #2119
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Eat size are those tires and what tire pressure are you running?
Old 10-20-2014, 07:04 PM   #2120
wparsons
wparsons's Avatar
How much are you lowered, and what pressures are you typically running?
flickr
Old 10-20-2014, 08:03 PM   #2121
car_roll
Drives: Nuisance BRZ
Couple questions. Are stock top hats interchangeable left to right? and does the position when reinstalling matter? IOW, does the position of the red dot on the top hats matter?
#teamnuisance
I do like, YouTube or something, IDK.
Shameless Plug
car_roll is offline   Reply With Quote
Old 10-20-2014, 09:17 PM   #2122
MINOCIN
MINOCIN's Avatar
lowered by an inch, 35 psi cold and 38 psi hot.
Old 10-20-2014, 10:06 PM   #2123
Thanks!
1. I don't think you have a roll center problem.
2. A 1 inch drop is fine.
3. More camber front and rear is a good idea.
4. What are your spring rates? Also what kind of tires are those? What pressures?
- Andy
The Following User Says Thank You to Racecomp Engineering For This Useful Post:
MINOCIN (10-21-2014)
Old 10-20-2014, 10:12 PM   #2124
gramicci101
Off Topic
4b. Nitto NT-01
Old 10-20-2014, 11:11 PM   #2125
wparsons
wparsons's Avatar
I think you need more camber and spring rate for the tires you're running.
flickr
The Following User Says Thank You to wparsons For This Useful Post:
Old 10-21-2014, 03:29 AM   #2126
MINOCIN
MINOCIN's Avatar
- Andy
According to the RSR website the spring rates are:
Front: 6.00kg/mm (336 lbs/in.)
Rear: 7.00kg/mm (392 lbs/in.)
The pictured tires are my track day tires, Nitto NT01 235/45/17 on 8" wide wheels
My daily tires, not pictured, are Hankook RS3 225/40/18 (not the v2 RS3) on 7.5" wide wheels
Both tires run at 35 psi cold temp. At the track the tire pressure for the NT01s is 38 psi when hot.
Old 10-21-2014, 03:40 AM   #2127
MINOCIN
MINOCIN's Avatar
Yeah, the suspension may be too squishy for an r-comp tire
Old 10-21-2014, 11:07 AM   #2128
dradernh
Drives: Used to Drive:Grand-Am GS #54 E36M3
Both tires run at 35 psi cold temp. At the track the tire pressure for the NT01s is 38 psi.
Are the Nittos 38 hot or 38 cold at the track?
dradernh is offline   Reply With Quote
Search this Thread:
Advanced Search
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 04:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 06:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 09:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 07:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 11:13 AM
