#2059 | |
- Andy
Website
https://www.racecompengineering.com/ Instagram: https://www.instagram.com/racecompengineering https://www.instagram.com/theapexfiles <- tech articles |
#2060 | |
For toe arms off the top of my head you generally won't need them unless you're slammed or want a ton of camber for some reason. - Andy
Website
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | yomny (10-01-2014) |
#2061 | |
- Andy
Website
#2062 |
driving smoother faster
Drives: Sold
^ That, love Ohlins on street and track
#2063 |
Drives: WRB JR BRZED
Anyone try ohlins with upgraded springs? Worth the upgrade?
#2064 |
We ran 450 lbs/in hyperco springs. It worked well, but it's hard to lower the car much.
- Andy
Website
#2065 |
#2066 |
Drives: 2013 FRS Whiteout
CSG and RCE tag-team suspension Q&A thread! Ask us anything!
@CSG David @Racecomp Engineering
I'm a bit perplexed with coilover height adjustment. Do you adjust height measuring a fixed point in the coilover body and making sure both rears are the same as well as both front struts or do you go adjusting each side separately based on fender to ground measurements. Must you remove end links into the front and on the rear along with rear lca or could the adjustment be made with suspension components fully installed.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
#2067 |
Drives: 2013 FR-S Matte Orange
I need a quick sanity check before dropping the car off for an alignment today. In my last 2 track days the car has been slower through the corners so I'm going back to my old settings but there are some other things that changed too so if you guys could take a look and recommend anything I'm all ears.
Last night I softened the compression and rebound on the fronts. It was at 2 clicks from full stiff on the compression (12 clicks available) and 1 turn from full stiff on the rebound (3 rotations available). Current settings are below. I also raised the car back up by 3/8" all around so hopefully the corner balance is still "mostly right". Here is where things are set now and what I want to align it to: Lowered 1 3/4" in the Front and 1 5/8" in the rear. Front: Camber -3.00 Front Caster =+7 (Go for as much as they can get out of it) Front Toe = 0 Rear Camber = -2.4 Rear Toe = 1/16" Total Toe In Perrin Front Sway 22mm set on softest Perrin Rear Sway 19mm set on medium Koni 8611 Race Fronts set at 5 clicks back from firm on the compression (1-12 settings on the bottom of strut) and about 1/2 way between soft/firm on the rebound. Rears are Koni 30 series and they are set wherever GC set them when they sent them to me. Tires are Michelin Pilot Super Sports Thanks in advance for any tips on getting this setup to corner correctly.
#2068 |
Drives: VW MK6 GTI | 13 Mustang GT
I have been reading up on Sam Strano's AutoX setup on this forum and he uses a relatively simple setup of summer tires, Strano front sway, and Koni Sport shocks.
What I want to know is how important are shocks in this setup? Are they necessary to control additional body roll or to tune out undesired body dive? Would Bilstein B6's work better or would it be better to use RCE Tarmac Zero's? I am looking for simple AutoX, Track, and spirited driving setups. I don't really care about lowering as well. And Sam's setup looks to be the most simple and best bang for the buck.
#2069 |
Off Topic
What class does he run in? If it's CS, there's a reason his setup is that simple. If it's STX, there's no reason he couldn't do more.
What class are you looking to run in? Class requirements determine build limitations. Bilstein's B6 is a strut; RCE Tarmac Zeros are coilovers. If you were to pair the B6 with RCE's Tarmac springs, you'd be similar to their Tarmac Zero, minus height adjustability. |
| The Following User Says Thank You to gramicci101 For This Useful Post: | Racecomp Engineering (10-03-2014) |
#2070 |
I can't remember exactly where we ended up, but it may have been just a bit less than an inch.
- Andy
Website
#2071 | |
You should be able to adjust without removing endlinks. - Andy
Website
#2072 | |
- Andy
Website
| Air Suspension Discussion Thread - Let's Get Nerdy | Andrew@ORT | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 174 | 02-13-2016 04:17 PM |
| RallySport Directs Everything Suspension thread!! | RallySport Direct | Brakes, Suspension, Chassis | 21 | 07-02-2014 06:31 PM |
| The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 09:15 AM |
| 2012 Team USA vs the 1992 Dream Team | ERZperformance | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 09-14-2012 07:19 PM |
| Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 11:13 AM |
