#2031 |
Drives: 2012 Toyota 86
ahh my mistake. you may have already, but i would make sure swapping a control arm will be legal for your class before i dropped money on one.
#2032 |
Serial Cone Killer
Drives: '14 BRZ - WRB Premium 6MT
I did, I am allowed one form of additional camber adjustment beyond factory for the front and the same for the rear. The "go to" parts seem to be LCA for the rear and top hats (and bolts, which don't count towards the limit).
| The Following User Says Thank You to Turkish For This Useful Post: | troek (09-14-2014) |
#2033 |
Drives: 86 GTS
Thoughts on this setup @CSG Mike @Racecomp Engineering :
Bilstein B6 Raceseng Camber tops STI Pink Springs Hardrace rear LCAs Alignment to suit (I have this sorted) |
#2034 | |
| The Following User Says Thank You to CSG Mike For This Useful Post: | Panman (09-18-2014) |
#2035 | |
Drives: 86 GTS
Unfortunately by the time I get SPLs here (Australia) they're horrendously expensive, Hardrace has local support, and are well regarded here I know a few people who track them and they are very happy with them. With the Aussie Peso diving against the US dollar any parts out of the US are increasing in price every day. |
| The Following User Says Thank You to Panman For This Useful Post: | CSG Mike (09-18-2014) |
#2036 | |
- Andy
Website
https://www.racecompengineering.com/ Instagram: https://www.instagram.com/racecompengineering https://www.instagram.com/theapexfiles <- tech articles |
#2037 | |
Drives: -'02 PSM WRX, '94 Miata, '13 BRZ
I was in the same dilemma a few months back. I ended up getting the Racer-x Fab arms instead of the Whitelines as I needed them in time for testing and nationals. They are great and I have had no issues with them. If money weren't a problem I would get the MSI arms, I plan to upgrade to those down the line.
![]() Sponsered by:Chasebays/Corr Performance Tuning/KartBoy/Bad Panda Motorsports/Racer-X Fabrication STX Build thread 14th/67 SCCA Nationals (2014) |
#2038 | |
Drives: 2015 FR-S
#2039 | |
Thanks
#2040 |
Off Topic
SPL changes the mounting point from a bushing to a heim joint, which isn't allowed per SCCA/STX rules. I think only Whiteline and SPC keep a bushing design, unless you get RacerX or someone to knock out a custom set for you.
| The Following 2 Users Say Thank You to gramicci101 For This Useful Post: | SubiePig (09-18-2014), ZionsWrath (09-18-2014) |
#2041 |
Racer-x offers them in both heim joint or poly.
#2042 | |
You could easily run 500 or 600 lbs/in springs especially if you're sticking with stock swaybars. With r-comps you'll be set up nicely...a 500/550 would work well. Spring rates that are too high and don't "match" the tire used can lead to a car that's tricky to drive...you can quickly/easily overload the tire and ultimately lose grip. You can certainly run a coilover without upgrading swaybars. Swaybars for a track car are generally used more to easily adjust the balance of the car rather than be the primary means of roll resistance. So stock bars are fine for you and you'll just hopefully get the balance dialed in with alignment, spring rates, and damper tuning (for entry/exit). If you like, give us a call or PM and we talk about your set-up in detail. ![]() - Andy
Website
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | JustDoItMikey (09-18-2014) |
#2043 |
Coilover Question
I've done a search of this thread... so hopefully this isn't a duplicate.
I've got some Speed by Design Pro-street coilovers installed. Overall, liking the ride quality... drop is about 1.25". Initially there was some clanking noises and "spring wind"(?) noises. Went back in... tightened some loose collars and such... and all was great. Then, about two weeks ago (after 2 months of no issues), there is a minor "spring winding" ("sproing...") noise when the car is moving slowly... when steering rack is at full (as in parking...) -- from the front. I went back.. jacked it up.. took off wheels and checked all collars, etc. and everything is buttoned down tight. I've got the springs setup for 6" (all corners) - drop is about 1.25". The endlinks to sway bar (that came with the coilovers) are at default length (i.e., shortest length). Any thoughts on 1) what is causing the "sproing" noise when doing low-speed maneuvering (e.g., parking) or is this simply a "usual artifact" of putting "street" coilovers on a 86?
2013 Asphalt / MT
Olympia, Washington |
#2044 | |
Drives: 2013 Cayenne turbo
Chris
Track, Autocross & Daily Driver build thread - SOLD Another A&DD for my VW GTI - SOLD And finally, my YouTube channel |
| Air Suspension Discussion Thread - Let's Get Nerdy | Andrew@ORT | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 174 | 02-13-2016 04:17 PM |
| RallySport Directs Everything Suspension thread!! | RallySport Direct | Brakes, Suspension, Chassis | 21 | 07-02-2014 06:31 PM |
| The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 09:15 AM |
| 2012 Team USA vs the 1992 Dream Team | ERZperformance | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 09-14-2012 07:19 PM |
| Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 11:13 AM |
