86WORX
Old 09-13-2014, 05:46 PM   #2017
Originally Posted by Lawnik View Post
@CSG Mike
Your thoughts on roll center and bump steer correction kits? At what ride height do they become nessesary if any?
Thanks for the help
It's impossible to make a blanket statement, due to different setups having right height ranges and different damper stroke range needs...
Old 09-13-2014, 06:23 PM   #2018
Turkish
Serial Cone Killer
Turkish's Avatar
Drives: '14 BRZ - WRB Premium 6MT
I'd recommend sticking to 215; the car will feel sloppy on 225 with stock wheels.
What do you mean by feeling sloppy?
Yes, but that is with 17x8 wheels, not 17x7.
225mm is about 8.86 inches. Do you really want to mount a tire that wide on a 7 inch width rim?
10mm is less than a half inch, 215mm is 8.46" and 225mm is 8.86". I am just curious how much "negative" there will be in the feel of the tire vs "positive" in the increase in grip.
I am also looking at putting michelin pilot super sport tires on my stock wheels.
For those who hear him call...
... his name is...
C'THULHU
Turkish is offline   Reply With Quote
Old 09-13-2014, 06:50 PM   #2019
The steering wheel won't be as responsive, because the sidewalls have to deflect more under a lot of force.
Old 09-13-2014, 06:59 PM   #2020
Turkish
Serial Cone Killer
Turkish's Avatar
Ah, gotcha. Thanks!
... his name is...
C'THULHU
The Following User Says Thank You to Turkish For This Useful Post:
CSG Mike (09-13-2014)
Old 09-13-2014, 08:03 PM   #2021
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
On the SPL rear LCAs, what is the relative stiffness between the three shock mount holes?
Sleepless is offline   Reply With Quote
Old 09-13-2014, 08:49 PM   #2022
What exactly do you mean?
Old 09-13-2014, 09:06 PM   #2023
troek
troek's Avatar
Drives: 2012 Toyota 86
@CSG Mike
Thanks for the help
i just put on the whiteline roll center kit, with my rsr super down springs, its a very noticeable difference in steering response, and the front end dosnt dip down under sharp cornering like it did before. very worth it in my opinion. i didnt think i would notice anything but i did. ill be writing a review when i get a little more time.
The Following 2 Users Say Thank You to troek For This Useful Post:
Lawnik (09-14-2014), lbejosano (09-14-2014)
Old 09-13-2014, 09:16 PM   #2024
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
My understanding is that the effective spring stiffness is altered by choosing one of the three shock mounting holes. In other applications this is usually expressed as a percentage relative to stock which I presume is the center hole. I can't find this spec for the SPL LCAs
Old 09-13-2014, 09:43 PM   #2025
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
That's why I'm asking. I expect making a one off at my work wouldn't cost near as much as contracting it out. But I'm not an engineer. However having the only aluminum subframe would be pretty darn cool. What thickness tube do you think I'd need too use for the same strength?
You will probably shed more weight just getting a muffler delete. It's not just how much material in being used. It's also how the piece is shaped and braced for different loads at the mounting points. If you are even asking these questions, IMO, you should not attempt it unless you are willing to learn how to not only design a piece like this but also fabricate it correctly. You're in the wrong forum for these question. Go ask the same questions in an engineering forum and see what they say. good luck
The Following User Says Thank You to solidONE For This Useful Post:
Dimman (09-20-2014)
Old 09-13-2014, 10:13 PM   #2026
Ashikabi
Ashikabi's Avatar
Fair enough. What about a retrofit of the Z frame?
Old 09-14-2014, 09:44 AM   #2027
solidONE
solidONE's Avatar
Do what you please. lol
Dimman (09-20-2014)
Old 09-14-2014, 09:07 PM   #2028
Turkish
Serial Cone Killer
Turkish's Avatar
So I will soon be pulling the trigger on rear lower control arms. I find myself in a bit of a dilemma though. Do I back order the Whiteline LCAs ($500) and hope I get a pair by July 2015 or purchase the currently available SPC LCAs ($210). I am currently running my car in the STX class of autocross which means I cannot change the type of bearings or bushings in the control arms.
My question really is: is there any good reason for me to save some more $$ and back-order the Whiteline control arms or just go forward with the SPC control arms?
... his name is...
C'THULHU
Old 09-14-2014, 09:36 PM   #2029
troek
troek's Avatar
if your not allowed to swap bushings, im surprised swaping an entire control arm that comes with a pillow ball is not a violation....
Old 09-14-2014, 09:37 PM   #2030
Turkish
Serial Cone Killer
Turkish's Avatar
Whiteline isn't pillow ball, its one of the few that isn't.
... his name is...
C'THULHU
Search this Thread:
Advanced Search
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 04:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 06:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 09:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 07:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 11:13 AM
