#1849 | |
2. Yes. - Andy
Website
https://www.racecompengineering.com/ Instagram: https://www.instagram.com/racecompengineering https://www.instagram.com/theapexfiles <- tech articles |
#1850 |
Drives: 2013 Cayenne turbo
Revised Question 2 because that's what I'm thinking of right now.
Chris
Track, Autocross & Daily Driver build thread - SOLD Another A&DD for my VW GTI - SOLD And finally, my YouTube channel |
#1851 |
That Guy
Drives: 2013 asphalt FRS MT
Recently put on MPSSs and now when I'm approaching the new found limits I find the car bouncy/floating mid corner when going over even mildly uneven pavement. Is it possible to keep it predictable and steady going over bumps while the bump stops are well compressed? Without either spending a shit ton of money, or turning the limit into a knife edge that I wont feel comfortable with either?
Set up is stock unless otherwise stated: RCE Yellows Whiteline: diff inserts, subframe inserts (I doubt these would have much to do with it, but it's possible, camber bolts, and front control arm bushings. And of course, the 215-45-17 pilot super sports. |
#1852 |
Drives: FR-S Whiteout
I think u can try to keep off the bump stops by adding roll stiffness via anti sway bar or stiffer spring rates, but you might have other problems to worry about if u go that route. You probably have to source out different bump stops or live with it otherwise.
#1853 |
Drives: Strangely.
Um. When staying to the adjustment recommendations on the spl parts camber arms, the most negative I could get the camber (on a stock car) is positive 44 minutes left, and positive 4 minutes right. Can't get the toe anywhere close to acceptable. Is it safe to just thread the thing out beyond their nominal limits?
#1854 | ||
When I had the Swift sport spring and cut bumpstops I had similar issues riding on 245/45/17 Goodyear F1's. I just figured that it's something I'd have to learn to drive around until I upgrade. You really cant ask for perfection with a set of lowering springs on factory dampers. Didnt really think it was that big of a deal, the bounciness, to be honest. I still like it much better than all stock FR-S suspension. Quote:
#1855 | |
Serial Cone Killer
Drives: '14 BRZ - WRB Premium 6MT
#1856 | |
#1857 | |
- Andy
Website
#1858 |
That Guy
#1859 |
Wow did not expect that from these spl arms with only a fraction of a degree of adjustment toward negative. Extending them beyond recommended length is going cause problems. he should really call spl up or consider a different brand.
Heh... I thought you were trying to avoid spending that kind of money. |
#1860 |
Unfortunately it doesn't look like we'll be able to do custom Bilsteins for this platform.
![]() Might have something else up our sleeves, but too early for a timeline. - Andy
Website
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | Calum (08-20-2014) |
#1861 |
Seņor Member
So still nothing on the TRD springs as to whether they positively or negatively affect the handling of the FRS?
![]() Really just looking to keep the cars ride quality and handling as close to stock as possible. |
#1862 | |
That Guy
It's things like the Ohlins coilover kit at ~$3100 plus paying someone to corner balance the car afterward that I'm looking to avoid. |
| Air Suspension Discussion Thread - Let's Get Nerdy | Andrew@ORT | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 174 | 02-13-2016 04:17 PM |
| RallySport Directs Everything Suspension thread!! | RallySport Direct | Brakes, Suspension, Chassis | 21 | 07-02-2014 06:31 PM |
| The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 09:15 AM |
| 2012 Team USA vs the 1992 Dream Team | ERZperformance | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 09-14-2012 07:19 PM |
| Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 11:13 AM |
