86WORX
Old 09-01-2013, 08:35 AM   #127
midnight23
dying bird under the hood
Drives: 2013 SWP Limited BRZ
My rear toe appears out now after the Cusco LCA install, I am on Tein Flex and already have an alignment scheduled on Friday but it is pulling left and right while driving and I can smell the rubber from the toe out, anyone have suggestions on a fix for now until I take it in?
TL;DR
How to fix rear toe?
Thanks in advance.
Build Thread
Instagram
Old 09-01-2013, 11:40 AM   #128
ZDan
ZDan's Avatar
Drives: '23 BRZ
Originally Posted by solidONE View Post
Since you brought up pyrometers, are those IR meters no good for taking tire temps?
Throwing in my .02:
Problem with IR pyrometers is that they only get the temp of the surface of the tire, which cools quickly. Probe pyrometers get down into the tread a little, where the temperature stays hotter longer. IR is OK for monitoring tire temps real-time, but not so much after you've brought the car into the pits/paddock.
Regarding setting pressures according to pyrometer, unless you're at the level where you can actually measure the difference in lap times with small changes in tire pressure, I wouldn't (and don't) bother. Particularly on a car that's likely to be camber-challenged anyway. Find out what hot pressures the truly fast guys are running with the tires you are running and run that hot pressure, adding ~2psi to be conservative (higher pressures are generally going to be "better" for less than optimal suspension setups, and will make the tires last longer, and worst case won't cost you much in terms of lap time).
Also, if you do use a pyrometer, be aware that "even temps across the tread" is not the ideal, and will have you running less-than-optimal camber. Optimally set up, the insides will typically run a bit hotter, as they're supporting the car's weight more of the time, including down the straights, where speeds are highest.
Optimal temperature profile and optimal tire pressure can only really be validated with lap times. If you're like me and don't get enough track time to be able to tell the *real* lap-time difference between 36psi hot and 38psi hot, you're most likely better off just running pressures a little on the high side vs. the experienced fast guys in similar cars on the same make/model tires.
The Following 2 Users Say Thank You to ZDan For This Useful Post:
RehabJeff86 (09-05-2013), solidONE (09-02-2013)
Old 09-01-2013, 01:27 PM   #129
Wepeel
Drives: '13 BRZ Ltd
Have you ever quantified how turns of the tie rod relate to toe change (i.e. one facet = x deg of toe change)?
Wepeel is offline   Reply With Quote
Old 09-01-2013, 04:17 PM   #130
TL;DR
Thanks in advance.
You have toe adjustment from the factory. Just minimize your driving until you get it aligned.
Old 09-01-2013, 04:17 PM   #131
They only read surface temps. You need to know the temperature under the surface, the rubber itself.
Old 09-01-2013, 04:18 PM   #132
No, I leave it to our alignment guys.
Shameless plug for West End Alignment for those of you in SoCal. If you make an appointment, DO NOT DO NOT DO NOT miss it. They do not overbook, and they are booked weeks in advance for a reason.
http://www.yelp.com/biz/west-end-alignment-gardena
Old 09-01-2013, 04:19 PM   #133
Dimman
Kuruma Otaku
Dimman's Avatar
Originally Posted by Racecomp Engineering View Post
I would like to do an article on suspension frequencies.
Soon.
- Andy
Originally Posted by ZDan View Post
Regarding frequencies, for each corner, you can use:
fn = [sqrt(wheel rate/sprung mass)]/2pi
Easiest if you just use metric units: wheel rate in Newtons/meter, mass in kilograms
Wheel rate is the spring rate divided by the *square* of the motion ratio.
On my FD, one corner = ~3000lb/4 = 750 lb
Unsprung mass per corner ~50 lb.
sprung mass per corner ~750-50 = 700 lb, divide by 2.205 lb/kg = 317 kg
11kgf/mm springs, multiply by 9.81N/kgf = 108 N/mm = 108,000 N/m
motion ratio ~1.6 front, so wheel rate = 108,000 N/m / 1.6^2 = 42,188 N/m
motion ratio ~1.4 rear, wheel rate = 108,000 N/m / 1.4^2 = 55,102 N/m
fn front = sqrt(42,188N/m / 317kg)/2pi = 1.8 Hz
fn rear = sqrt(55,102N/m / 317kg)/2pi = 2.1 Hz
~2Hz is a pretty damn stiff street ride, pretty damn soft track ride, a decent-enough compromise...
The difficulty will be not terrifying people with the math...
ZDan could you do this again with a stock early WRX (strut/strut so we don't need to go hunting for motion ratios) so we can compare the difference in spring rate to frequency from different weight and motion ratios.
It may be a good start for explaining that big coil rate numbers don't automatically mean super stiff rides, depending on the car's design. ie comparing spring rates between different can be useless at times.
Because titanium.
Old 09-01-2013, 07:10 PM   #134
eckoflyte
Drives: Toyota 86 GTS
Question regarding Ground Control camber plates. We know that these allow the strut to be mounted higher, in effect lowering the car without sacrificing bump travel. From a geometry point of view, what would be the difference in lowering the car using the threaded shock bodies or using the GC plates? They both allow the car to be lowered without reducing shock bump travel.
eckoflyte is offline   Reply With Quote
Old 09-01-2013, 07:22 PM   #135
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
I'm hoping rce and CSG mike will make a thread like this for alignments and what's safe and workable. I realize people say use what works thing is there are people far more experienced with multiple setups ie: wheels sizes, tires,etc...
Old 09-01-2013, 09:56 PM   #136
ZDan
ZDan's Avatar
Drives: '23 BRZ
Fortunately, it isn't advanced math at all! The concepts involved are subtle, but easily understandable.
Struts have motion ratios, it shouldn't be 1:1. On my 240Z it was ~1.14 wheel/spring. Even if the strut axis intersects the ground right in the middle of the contact patch, there is kingpin inclination angle (KAI) front and rear, and also caster up front. Even when the ratio is close to 1 it's important to get it close to right because it gets squared.
Absolutely true. Spring rate says nothing without knowing the motion ratio!
CSG Mike (09-02-2013)
Old 09-01-2013, 10:17 PM   #137
Dimman
Kuruma Otaku
Dimman's Avatar
Any math beyond quoting some numbers they read will terrify people. Heh...
I put together a spread sheet for my own use, but my unsprung weight figures are estimates, as are the motion ratios I use. But it still gives me a better idea of how different spring rates can affect different cars.
About the struts, I've been using 1:1, what are the actual points we need to use?
Because titanium.
Old 09-02-2013, 05:25 AM   #138
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Originally Posted by 448hpsti View Post
Thanks in advance:
So what's a good entry level pyrometer for the guy jot newvto cars but new to stuff like tire temp monitoring
... I know my IR temp gun is crap when it comes to tires, we don't want surface temp ...
Check this one out: http://www.soloperformance.com/Joes-...FUfZQgodFzoAfA Joe's Racing is a pretty highly regarded brand. Little cheaper than the Longacre dual function unit, but should work just as well.
Throwing in my .02:
Any hard numbers in terms of temp differential between the inside, center and outer portions of the tires tread? What would be ideal when trying to determining camber?
Old 09-02-2013, 10:23 AM   #139
ZDan
ZDan's Avatar
Drives: '23 BRZ
I don't know, quick search didn't yield anything concrete, either. You might just assume 0.9:1 for the front struts, should be a much better estimate than 1:1. 1:1 says a 500 lb/in spring gives a 500 lb/in wheel rate, 0.9:1 => 500*0.9^2 = 405 lb/in wheel rate, so it makes a big difference.
Dimman (09-02-2013)
Old 09-02-2013, 10:32 AM   #140
ZDan
ZDan's Avatar
Drives: '23 BRZ
There are no hard numbers on optimal tread temperature profile, it's going to depend heavily on the car and the setup. ~15F hotter on the inside than the outside *might* be an OK rule of thumb.
solidONE (09-03-2013)
Search this Thread:
Advanced Search
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 04:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 06:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 09:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 07:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 11:13 AM
