#1303 | |
Drives: None (yet)
If I end up with the skirts on and the front/rear doesn't match, I'll grab the real versions of those too.
#1304 | |
Drives: WRB LMTD '13
#1305 | |
Drives: None (yet)
As for front and rear, they are pretty much the same, except the front lip obviously doesn't have the STi badge. I'm not interested in sticking a badge on my replica lip, just saying that I would buy the real front lip if the paint didn't match the sides. Here's hoping they come quick!
| The Following User Says Thank You to inc3pt For This Useful Post: | hanabie (08-08-2014) |
#1306 |
Snow Don't Hurt!
So explain this. Does it mess with your mileage display? Any special modifications? Sorry if you explained it elsewhere. I tried scanning real quick and didn't see anything. Been busy. Thanks!
#1307 | |
Drives: Brz WRB - Europe LHD
If the job is DIY: a) unplug battery! MANDATORY b) remove meter cover (1 nut) and the two upon meter, remove meter unit. c) connect the harness on back d) repeat on reverse step. - Now press START button once without start engine with keyless fob near antenna 's receiver (beside front USB plug). - press Start again to go OFF. - NOW START ENGINE, you will see unlock signal on meter becomes green. This means that unit has been paired. About mileage, you loose your records (tS meter starts up at 0 Kms) so the only way is to align it with SSMIII by official Subaru network. Otherwise..you gain the mileage you done. You need to set up limiter signal (i.g. my at 7.400 rpm) on meter and all warning personalization you made (i.g. seat belts warning) with TIS. Mileage is recorded both on ECM and Meter too.
| The Following 2 Users Say Thank You to Trap63 For This Useful Post: | chanomatik (08-08-2014), krayzie (08-08-2014) |
#1308 |
Drives: 2014 BRZ - 2004 GLI
Uh... might have some good updates
I believe I have found the tS armrests, STI steering wheel and the air bag module/cover! (numbers still need to be verified) Please check out the website brzpartspage.com for the part numbers. I don't sell anything and it is just privately funded so there's no ads.New updates on the front page have: tS Front strut (F, RH) tS Front strut (F, LH) tS Rear shock absorber tS Coil spring front tS Coil spring rear tS Private sports meter tS Private steering wheel tS Dedicated airbag module tS Door armrest right tS Door armrest left |
#1310 |
No, you can't. Japan runs in metric, therefore tS (only JDM) hasn't mpg display.
#1311 | |
Drive From Home
Drives: BRZ STI Performance
| The Following User Says Thank You to krayzie For This Useful Post: | Trap63 (08-08-2014) |
#1312 | |
Yes, but they need to specify in latest page of owner's maintenance book . Here in Europe is illegal modify (selling) mileage so any variation must be recorded.
| The Following User Says Thank You to Trap63 For This Useful Post: | krayzie (08-08-2014) |
#1313 |
New goodies from Australia in Ebay as suggested some posts ago....
| The Following User Says Thank You to Trap63 For This Useful Post: | chanomatik (08-08-2014) |
#1314 |
Drive From Home
I spent the entire afternoon installing the STI short shifter.
The hardest part that almost made me cry was the damn dust boot on the shifter fork, as I was struggling with it for almost an hour. It is impossible to reinstall the dust boot and retaining clip the OEM way without a pair of forceps (best 5 bucks ever spent). I also adjusted the lockout plate with a feeler gauge @ 1.0mm (Subaru recommends 1.0mm gap or 0.8mm if there is trouble getting into 1st and 2nd) and got it bang on the first time. You won't be able to feel a difference in shift feel until driving the car, the difference compared to stock is that minimal (4mm shorter in throw). Paring it with the aluminum weighed leather STI shift knob and every gear now feels like a toggle switch, tighter less sloppy feeling. This is how it should have came stock. |
| The Following 3 Users Say Thank You to krayzie For This Useful Post: |
#1315 |
Drive From Home
Updates on the STI Performance catalog:
Recaro Seats: http://www.sti.jp/parts/catalogue/br...4010AS020.html GT Wing: http://www.sti.jp/parts/catalogue/br...6050AS220.html The Brembo brake kit isn't listed yet. |
#1316 | |
About short shifter I bought the kartboy one (very satisfied) as I tried the TRD shifter (same of STI) of a friend of mine . I feel that the differences aren't so wide. I think that all genuine parts are a plus but not all parts are real performance parts. You need to observe a strictly non-emotional approach and care for benefits/cost ratio. About shifter if you complete it with whiteline or powerflex gear mount bush, Mtech shift spring (or Cusco shift spring), rear shifter stay bush you will feel "another" gear.
| The Following 2 Users Say Thank You to Trap63 For This Useful Post: | chanomatik (08-11-2014), krayzie (08-09-2014) |
| Tags |
| it sucks to be broke, sti omg! |
| WTB: Parts for my FR-S | hyperpunx | Interior Parts (Incl. Lighting) | 1 | 03-05-2013 06:28 PM |
| [Group Deals] SoCal Subaru BRZ parts or Any Parts | Giccin | Southern California | 25 | 08-26-2012 11:30 AM |
