#939 |
Drives: 2015 Series.Blue
Read up on driveshaft critical speeds if you want to know more. They use 2 piece driveshafts to get this speed much higher, it's not for NVH reasons.
#940 | ||
Drives: 1998 Audi A4 Quattro Sport 30v
Apparently you don't "know all about drivetrain weight loss". A lighter driveshaft, flywheel, lighter wheel/tire package, lighter brake rotors... These will ALL directly affect acceleration and braking and can make the car feel a LOT more responsive. It's not always about strength or reliability. http://www.ebay.com/itm/2012-Scion-F...675552&vxp=mtr Quote:
#941 |
So elite I'm 1338
Drives: WRB Subaru BRZ
So by increasing the critical speed of the drive shaft (larger diameter, w/o increasing weight).
The drive shaft can spin at a higher RPM w/o risk of failure. With that information, a larger diameter drive shaft would allow you to increase engine/transmission RPM safely in terms of the drive shaft. I don't believe they have increased the RPM limit in the BRZ tS, but the TS driveshaft is a lighter, larger, and single piece drive shaft. So if they haven't increased the RPM range in the tS, then the benefit of a larger diameter drive shaft is kind of lost. |
#942 |
Drives: 2014 BRZ - 2004 GLI
#943 | |
Drives: 1993 Impreza w/ WRX Swap + FWD!
You will get more results for your money from a flywheel, lighter wheels/tires, etc. This STI driveshaft sounds like.a great OEM option to the carbon fiber aftermarket options, but spend your money elsewhere first. |
#944 | |
So elite I'm 1338
I think its a bit naive to say a flywheel is a better use of money than the drive shaft. Do you have any experience with your car mutually exclusive of the two? Impreza w/ drive shaft only Impreza w/ flywheel only Impreza w/ drive shaft + flywheel. Then we have the brz. is the rotational mass saved from the OEM flywheel compared to an aftermarket flywheel a greater savings compared to the OEM 2 piece drive shaft, to a light weight one piece drive shaft? |
#945 | |
Snow Don't Hurt!
Same reason why the tS gets Brembo brakes. Bigger brakes have less brake fade over the course of a track day. Subaru/STI felt the 4-pot/2-pot Brembos were adequate and significant enough of an improvement over the stock floating calipers. |
#946 | |
So elite I'm 1338
If the RPM limit has not changed, then the stock drive shaft should not reach critical speed. Even at any length of time at RPM, if the drive shaft doesn't reach critical speed it will not fail due to critical speed. I am not saying that the one piece driveshaft isn't performance intended, I'm just saying if the larger diameter only modifies critical speed, then the larger diameter drive shaft is not needed. Not saying a lighter one piece drive shat isn't needed. Just a larger diameter isn't needed. |
#947 |
Drives: BRZ Subaru
on japanparts webside i only found the STI Brake Set for the Front
![]() is there a STI Brake Set for Rear also availible ? |
#948 | |
Snow Don't Hurt!
#949 |
A larger diameter shaft probably wont work with the TRD quickshift either... That has clearance issues with the stock driveshaft.
I wish they would have thrown more effort into improving the CV's, those are more of an issue than the driveshaft ever will be... |
#950 | |
Snow Don't Hurt!
Also the front of the BRZ is a bit unique, so having the tS front Brembos makes sense. For the rears just get the GV/GR STI rear ones. http://www.japanparts.com/db/parts_d...=&SEARCH_page= Looks like the 6-pot fronts are actually cheaper anyways by $500. http://www.japanparts.com/db/parts_d...=&SEARCH_page= |
#951 | |
Drive From Home
Drives: BRZ STI Performance
This apparently doesn't sit too well with the Internet generation that are too hung up on numbers. |
| The Following 4 Users Say Thank You to krayzie For This Useful Post: |
#952 | |
@dsomegax.cars
2013 Subaru BRZ Limited | WRB | STI tS Build Thread [SOLD] 2019 BMW M2 Competition | LBB | ///M Performance Build Thread 2020 Toyota GR Supra | Turbulence | TRD | Build Thread |
| The Following User Says Thank You to DSOmegaX For This Useful Post: | chanomatik (06-04-2014) |
| Tags |
| it sucks to be broke, sti omg! |
| WTB: Parts for my FR-S | hyperpunx | Interior Parts (Incl. Lighting) | 1 | 03-05-2013 06:28 PM |
| [Group Deals] SoCal Subaru BRZ parts or Any Parts | Giccin | Southern California | 25 | 08-26-2012 11:30 AM |
