#2339 |
Drives: '14 981CS, '99 NB1
STi front lip and LED DRLs. Car is still on jack stands, hence the 4x4 look.
Was able to buy the front lip through my local dealer, they had it in their warehouse so I got it the next day after ordering. LED DRLs I got through FT86 Speed Factory. No instructions available for installing either of these. Had to wing it. I took a lot of pictures of the STi lip install and hope to put together a DIY on it. |
| The Following 3 Users Say Thank You to johan For This Useful Post: |
#2340 | |
Drives: Black 17 BRZ LT MT PP
#2341 |
#2342 |
Drives: '15 BRZ RA
#2343 | |
Drives: Harrop TVS86 STi BRZ tS
#2344 | |
How did you wire them? I tapped the existing DRL wires on the driver side headlight. I used a standard T-style wire tap on the red and black wires. The colors likely won't help you though as the wiring to the headlights is slightly different on the '17s. I just used a multi-meter to figure out which wire got power when I wanted power. On the '17s the boomerang is always on, so I tapped into the boomerang wiring. Pictures? I haven't taken a lot of pix yet, but here's a functional one from last week - before I added the STi lip. The weather has been shit on the days that I've had the car running. Somehow I'm always working on it on the days where it's nice outside. |
#2345 | |
#2346 | |
This is the connector I used: ![]() For the tapping, I de-pinned the connector on the wiring harness they give you, and then cut off the pins and put the flat end connector on the ends of the wires. This gives me an easily reversible install if I ever wanted to remove them. They give you a bunch of zip ties / square adhesive blocks for the zip ties, that made it easy to run the harness along the radiator support. I just pulled off the top of the plastic radiator shroud and front of the intake to make it easy to access. I then zip tied the harness on either side to the fog light wiring to keep it localized to where I wanted it. |
| The Following User Says Thank You to johan For This Useful Post: | kuczynskika (11-21-2016) |
#2347 |
Drive From Home
Drives: BRZ STI Performance
#2348 | |
Drives: '20 Hakone 86
| The Following 4 Users Say Thank You to TylerLieberman For This Useful Post: |
#2349 | |
http://sp.subaru.jp/tas2017/lineup/detail_6.php Nothing new in terms of parts. Just some of the already available items adapted to the 2017.
@dsomegax.cars
2013 Subaru BRZ Limited | WRB | STI tS Build Thread [SOLD] 2019 BMW M2 Competition | LBB | ///M Performance Build Thread 2020 Toyota GR Supra | Turbulence | TRD | Build Thread |
#2350 | |
#2351 |
Drive From Home
I think their new direction now is to make STI Sport into a new Subaru standard trim level for all of their cars just as I suspected all along. Another step closer to worldwide export.
#2352 |
Drives: '15 BRZ RA
Not impressed on the updates.
| Tags |
| it sucks to be broke, sti omg! |
| WTB: Parts for my FR-S | hyperpunx | Interior Parts (Incl. Lighting) | 1 | 03-05-2013 06:28 PM |
| [Group Deals] SoCal Subaru BRZ parts or Any Parts | Giccin | Southern California | 25 | 08-26-2012 11:30 AM |
