Old 04-29-2017, 06:32 PM   #113
SpectreRT
SpectreRT's Avatar
Drives: Subaru BRZ
Originally Posted by fika84 View Post
The type of cut is the same as OEM. Look at them side by side, exact same cut, different number of teeth to create different ratio.
Its very close, but not 100% the same I imagine. I'll get my OEM 4.1 out of storage later and measure for pictures. I measured the Weir before installation; but was too lazy to cross compare.
Videos to come later; ended up drinking the last few days. My bad for the delay.
SpectreRT is offline   Reply With Quote
The Following User Says Thank You to SpectreRT For This Useful Post:
Teseo (04-29-2017)
Old 04-29-2017, 06:33 PM   #114
SpectreRT
SpectreRT's Avatar
Drives: Subaru BRZ
Originally Posted by Icecreamtruk View Post
Weir 4.88 also has a small sound to it. 18 months of street driving and 13 track days (2h to 3h of track time per track day) tells me that the sound is normal, since oil doesnt come out with metal pieces and the sound hasnt changed at all during this time.
For the most part, if your noises are consistent; you're good to go. If new noises appear or randomly go away -- something isnt right.
Old 05-01-2017, 03:04 PM   #115
fika84
fika84's Avatar
Also have to remember that the measurements can't be far off since they both use the same bearings and shims. Not much room for design modifications.
fika84 is offline   Reply With Quote
Old 07-07-2017, 01:44 PM   #116
modbus
Drives: '14 BRZ | '95 Range Rover
Help! I want to order a FD but can't decide.
I've got a MT that I want to keep NA. I will not be doing E85 in the foreseeable future. I've got stock wheels and Michelin Pilot Super Sports in stock tire size and plan on staying this way as well.
The car is my DD, and I have a different car I can use for road trips. Should I go 4.88 or is 4.56 much safer? I do about an even three-way of city-highway-freeway driving, and usually I never cruise above 75mph, more typically 65, which I calculate will be ~4000rpm on the 4.88. Is this bad? The 4.56 would be ~3700RPM.
Any input is appreciated.
modbus is offline   Reply With Quote
Old 07-07-2017, 01:52 PM   #117
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
On your final drive question, 4.55 or 4.88 will only drop the whole range of gears, so your top gear will be shorter, so the fuel cosumption will decrease. It will only feel livelier but not in all gears since we are just dropping the shipt points lower...but not increasing the power to the output. So it's a choice. I would leave it alone if I was you since it really doesn't make the car any faster in all places. Just in someplaces, and in other places, slower.
Old 07-07-2017, 05:13 PM   #118
churchx
churchx's Avatar
Drives: 2014 GT86
Pitty close-ratio gearsets are nowhere near as cheap as FD. Though even better would be such gearset (with longer 1st & 2nd) AND different FD.
The Following User Says Thank You to churchx For This Useful Post:
nikitopo (07-07-2017)
Old 08-07-2017, 11:18 PM   #119
Imranman
Drives: 1991 Acura NSX
Originally Posted by #my86build View Post
I just had my Cusco 4.556 installed a couple of weeks ago. Here are the parts my local shop used in the installation. No new noises to report on mine. That could be the due to fact that it is a Toyota part, it could be the shop that installed it or it could be both. I would also recommend shopping around. I believe FT-86 Speedfactory has theirs marked up $200 USD more than where my shop ordered mine from.
1) Toyota Diff Washer Plate $13 CAD #90201-35518
2) Toyota Diff Case Seal x2 $15.40/per CAD #90311-38070
3) Toyota Diff Shims x2 $18.92/per CAD #90564-46043
So is this all that's needed to install an mfactory 4.67? I'm kind of a noob with FD and my mechanic told me to get everything required.
Imranman is offline   Reply With Quote
Search this Thread:
Advanced Search
CUSCO 4.55 FINAL DRIVE installed. Racecomp Engineering Engine, Exhaust, Transmission 489 06-17-2018 01:14 AM
Mfactory Final Drive Ring and Pinion Crossover Auto Engine, Exhaust, Transmission 87 05-26-2017 03:21 AM
Final Drive Calculations wootwoot Engine, Exhaust, Transmission 34 12-19-2014 05:06 AM
Anyone w/ 3.727/3.909 Final Drive Post Boost? Staf00 Engine, Exhaust, Transmission 12 05-02-2013 09:38 PM
