Old 01-08-2014, 06:52 PM   #71
Dipstik-sportech
Dipstik-sportech's Avatar
Cool now how do I get one in Canada.........
Sent from, The Frozen North
Old 01-08-2014, 11:51 PM   #72
DR 86
DR 86's Avatar
Please forgive my noobishness on this topic, but I see some people wanting shorter FD ratios (the majority) and some wanting longer ones (?FI people). I have an AT and want to have shorter gears for quicker acceleration, but I am also planning on going turbo (270-300whp) in the near future. Should I be looking for a shorter or taller FD? Mostly DD (50/50 city highway) with 5-6 track days per season. Thanks!
Perrin CAI|Perrin MCB|P&L header|Motiv OP/FP|MXP catback|Tein Type Flex coilovers|Eibach F/R sway bars|GS front strut brace|Street:PM HC+800/Track:Carbotech XP10|StopTech slotted rotors/SS lines|SBC RPF1s|Street:FK453/Winter:Pirelli SottoZero3/Track:Toyo R888s|Leg Sport rear spoiler|EcuTek Tuned|OEM oil cooler|4th/F1 brake lights
DR 86 is offline   Reply With Quote
Old 01-09-2014, 12:37 AM   #73
pche
Guy on internet
Drives: Slowly
You just answer your own question. Shorter gears for NA to "shift" your power band to a lower rpm. Taller gears for FI to "prolong" the power band.
I paraphrased for ease of understanding.
pche is offline   Reply With Quote
The Following User Says Thank You to pche For This Useful Post:
funwheeldrive (04-27-2016)
Old 10-09-2015, 04:28 PM   #74
Toyota86.ir
Mike Tune HKS E85 FD 4.88
Drives: Toyota GT86 AT NA Stage 2
Pinion bearing part number is :
90366-35133
This bearing is not in my city toyota service stock.
Does any body knows more information about it?
Koyo make it or other company?
I need more info for shopping this part from another source
Toyota86.ir is offline   Reply With Quote
Old 10-10-2015, 12:00 PM   #75
Toyota86.ir
Originally Posted by Dustin View Post
Just got my Weir Performance 4.56 final drive and solid pinion spacer. He supplied shims for both. I'm going to buy a few more things before installing it but we've purchased from Weir before and his products are top notch!! We have his axles, final drive, and solid pinion spacer in my brother's AE86. Anyone wanting to do this mod should definitely get in touch with him. Everything for well under $400 shipped and I received it in 2 days!!!
Originally Posted by 37 View Post
90179-20018 ... Pinion nut
90311-38070 ... Pinion seal
41231-24010 ... Pinion spacer
90366-35133 ... Pinion bearing*
90311-43009 ... Side seals (x 2)
41222-22010 ... Ring gear lock tabs (x 5)
12157-10010 ... Drain bolt gasket
SU003-00122 ... Fill bolt gasket
(listed above) ... Pinion bearing shims
(listed below) ... Diff washers**
*Note 1: Pinion bearing can potentially be reused if you or your shop has the removal tool and your bearing is still in serviceable condition. Replacement is recommended but not mandatory depending on these conditions.
**Note 2: Side washers might be needed depending on the new ring/pinion tolerances. If anyone has any input on this, please add to the discussion.
I ordered FD 4.88 to Weir Performance, Weir has very good customer service and fast delivery before 2 days. I should thank Robert. http://weirperformance.com/
Weir package includes :
4.88 final GT86 (includes depth shim kit)
Solid spacer
pinion seal
Axle seals
pinion nut
I ordered Pinion Bearing from Toyota Dealer in dubai and before starting the swap i like to know is there more needed parts before swap?
The Following User Says Thank You to Toyota86.ir For This Useful Post:
DAEMANO (02-11-2016)
Old 02-07-2016, 04:48 PM   #76
Carlitoz3
Carlitoz3's Avatar
Drives: 2013 MT Asphalt FRS
NA, full bolt ons on e85
4.56 or 4.88 FD I can't make up my mind!
Carlitoz3 is offline   Reply With Quote
Old 02-07-2016, 06:19 PM   #77
Hawk77FT
Drives: GTS 86
Depends what you're after. I am doing 4.55 with supra mk3 internals , shot peened and micro polished. 4.88 will be crazy
Sent from my HTC_0P6B using Tapatalk
Hawk77FT is offline   Reply With Quote
Old 02-11-2016, 12:19 PM   #78
Carlitoz3
Carlitoz3's Avatar
Crazy good or crazy bad? Lol
The Following User Says Thank You to Carlitoz3 For This Useful Post:
Hawk77FT (02-11-2016)
Old 02-11-2016, 12:20 PM   #79
Carlitoz3
Carlitoz3's Avatar
Solid spacer
pinion seal
Axle seals
pinion nut
How are you liking your 4.88 FD?
Old 02-11-2016, 12:27 PM   #80
mrk1
Drives: Sterling BRZ Ltd
Originally Posted by Dipstik-sportech View Post
Does anyone know if there's a 3.73 or a 3.55 available aftermarket yet?
Lexus IS300 M86 and M82 differentials came with 3.73 ring and pinion, these diffs are harder to come across compared to the 3.91 versions
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
The Following User Says Thank You to mrk1 For This Useful Post:
NyC Zn6 (02-11-2016)
Old 02-11-2016, 12:28 PM   #81
mrk1
Originally Posted by ultra View Post
Thanks for the info.
Curious whether either MFactory or Cusco include the shims, let alone all these little extras, in their gear kits.
If not, plenty of pumpkin-noobs like myself are going to be in real pain when we order these gears and run down to our installers, then end up bouncing back and forth between them and the dealer a few times.
MFactory just sells the ring and pinion, Ive never seen whats in the box with Cusco but wouldnt be surprised if its the same
The Build Thread
Old 02-11-2016, 04:20 PM   #82
Toyota86.ir
Awesome
For AT the FD is the best mod , i highly recommend it
Bobster (04-18-2017)
Old 02-11-2016, 04:41 PM   #83
bem75
Round 3 Racing
bem75's Avatar
Drives: Scion FR-S race car
We took a 3.727 from a Lexus IS250 or IS300 in a junk yard. Testing it in 2 weeks at NOLA. Supercharged application...race car.
bem75 is offline   Reply With Quote
Old 02-11-2016, 06:41 PM   #84
Hawk77FT
Drives: GTS 86
Crazy good...too good!
The Following User Says Thank You to Hawk77FT For This Useful Post:
Carlitoz3 (02-11-2016)
CUSCO 4.55 FINAL DRIVE installed. Racecomp Engineering Engine, Exhaust, Transmission 489 06-17-2018 01:14 AM
Mfactory Final Drive Ring and Pinion Crossover Auto Engine, Exhaust, Transmission 87 05-26-2017 03:21 AM
Final Drive Calculations wootwoot Engine, Exhaust, Transmission 34 12-19-2014 05:06 AM
Anyone w/ 3.727/3.909 Final Drive Post Boost? Staf00 Engine, Exhaust, Transmission 12 05-02-2013 09:38 PM
