#29 | |
- Andy
Website
https://www.racecompengineering.com/ Instagram: https://www.instagram.com/racecompengineering https://www.instagram.com/theapexfiles <- tech articles |
#30 | ||||
Drives: FR-S Whiteout
#31 |
Drives: AE86, 2x GT86, TE27
Is there a safe way of doing this?
I already have the whiteline camber bolts, do they for example, make a smaller bolt to use in the bottom? Cheers |
#32 |
I have no idea what brand bolts we have (they were given to us by West End Alignment), but they haven't slipped.
#33 |
You can use the bolts on the bottom according to instructions BUT again you have to use great caution as the bottom bolt is considered more critical to load bearing. If you do it, check often and also thread lock bolts before install.
#34 | |
I wasn't the one who put my bolts in, I was putting something else in, but that's what my buddy said who was working on the front. |
#35 |
I've been driving my car pretty hard around some bumpy bends and the SPC bolts with supplied locking nuts have not shifted either. I've also done 3 track days with the upper bolts only and the bolts have stayed in the same exact position. No thread lock/ loctite used. Time will tell how it will hold up when doubled up. Pretty content with the $50-60 spent for more than -2* of camber tho. Will post photos and vid later.
#36 |
Read the earlier posts. Top bolt 16mm, bottom 14mm.
#37 | |
#39 |
#40 | |
Drives: Subaru BRZ Limited
#41 | |
#42 |
![]() Clearance of the 245's with 5mm spacers installed. Note the upper SPC camber bolt is zinc coated and silver in color. ![]() Spacers, hubcentric: ![]() This is the type of road I typically run on when not commuting. http://s174.photobucket.com/user/sol...43611.mp4.html this is with the stock tires and both camber bolts installed. TC on. A lot of intervention as the tires were breaking away easily with the swift springs installed. Kicked up a pice of asphalt bigger than my fist at about 0:19 into the "lap". |
| camber adjustment | SMOKETREES | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 05-26-2013 05:39 PM |
| regarding camber adjustment | aruxe | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 05-10-2013 02:02 AM |
| BRZ front camber adjustment confirmed | sparks | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 21 | 03-28-2013 11:17 PM |
| KW V3 camber adjustment | olorin | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 01-28-2013 05:46 PM |
