#15 | |
Drives: '13 BRZ Ltd
).I've run aftermarket SPC cammed camber bolts in my WRX and STI - they were very strong, despite the thinner diameter and lower torque spec. I got in an accident where the top of the front passenger wheel was impacted inward badly - the strut bent, but the camber bolt didnt' slip .
#16 | |
Drives: FR-S Whiteout
Talk about "bang for the buck" camber!
| The Following User Says Thank You to solidONE For This Useful Post: | wparsons (09-10-2013) |
#17 | |
Drives: Some rust bucket
Wheels use the same concept. The lug nuts provide the clamping force to hold the wheel in place. |
#18 | |
Lug nuts, with their taper, do not have any slop after tightening. Crash bolts still have space for them shift into after tightening. |
#19 | |
Drives: Vortech Supercharged FR-S
Did the problem solved?
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me. Your car is your story, so don't let someone else write the book. ( White Tiger ) - FiGo's 車誌. |
#20 |
There is only about 3-4mm of clearance with the 245's. I've switched to my stock wheels for now and there is no clearance issue without using specers. I could get some 8mm spacers for the 245's, or just deal with it. I will post pictures of the amount of clearance later.
#21 | |
Seem like these bolts work better than top mounts. lol.
Cuz top mounts always have problems. Quote:
#22 | |
However, if you've got lateral impacts on the wheel, you've got bigger problems to worry about. |
#23 | |
I'm sure if you use some quality camber plates that have been proven to be problem free you will avoid the common issues with aftermarket camber plates. But then, there is a price to pay for this quality. That's where the beauty of these camber bolts begin to show. Bang...., for yo buck, yo! When I say "a small impact" I'm talking about hitting berms, pot holes or divots on the road during hard cornering. This is a common occurrence in socal roads and tracks. |
#24 | |
I am thinking to get Hotchkis camber plates and swift lowing spring. lol. And maybe a set of Cusco LCA.
#25 | |
Drives: '13 BRZ Ltd
Moving the strut tops inward does have the effect of raising the roll center, which could be desirable or not, depending. If you're lowered a lot it might be preferable to raise the roll center back up. |
| The Following User Says Thank You to Wepeel For This Useful Post: | Racecomp Engineering (09-10-2013) |
#26 |
I am with Mike @CSG Mike on this. I ran the crash bolt on the top of the strut, difficult to align and had to re-align after several autox. The Whitle bolt (re-packaged SPC) was more of the same, had to re-align 4x since install. Mind you this was from harder driving.
Using these bolts on both top and bottom is not something I would ever consider, and if you did you absolutely want to use thread lock on both bolts and check TQ monthly. Lastly those SPC bolts IMO are low quality hardware. There is no excuse for $30 bolts completely turning to rust after 6 months. Here is a picture of stock bolt compared. Whenever I see an SPC suspension piece I think wow that's affordable, but chances are this is the fine print.
#27 | |
Damn, it's like I'm back in high school agian. Ironically, its a class that I slept through, and had a teacher that always threw markers at me. He also was the teacher for 3 other classes I had... and now codes for Blizzard. /randomblurb |
#28 | |
Drives: '13 BRZ Ltd
| camber adjustment | SMOKETREES | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 05-26-2013 05:39 PM |
| regarding camber adjustment | aruxe | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 05-10-2013 02:02 AM |
| BRZ front camber adjustment confirmed | sparks | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 21 | 03-28-2013 11:17 PM |
| KW V3 camber adjustment | olorin | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 01-28-2013 05:46 PM |
