| DIY (Do-It-Yourself) Guides For all DIYs. |
#15 |
Drives: Scion FR-S 2013 Raven
No problem, the problem never come back for me after months... Don't worry.
o= FR-S =o |
#16 |
Drives: 2013 frs
What cracking noise are you referring too? I never heard of this before
Sent from my SM-N900W8 using Tapatalk |
#17 |
Drives: 2013 frs
#18 | |
From Québec!
o= FR-S =o |
#19 | |
Are you 20/20?
Drives: Hopes and dreams
#20 |
Drives: 2013 Subaru BRZ Limited (CBS)
So wait, are you guys saying that you need to actually crack the spot welds? As in separate the panels so they aren't welded together anymore? Because that's what it reads like.
| The Following User Says Thank You to akiranakayama For This Useful Post: | Mikepage (03-15-2014) |
#21 |
Noooo you just need to crack it but a little bit and take care to do not broke it. Slowly, you will not broke anything, don't worry and thrust me.
o= FR-S =o |
#22 | |
Drives: 2013 frs
Just pry it enough so you can spray some lube inside I believe that's what he meant Sent from my SM-N900W8 using Tapatalk |
#23 | |
Drives: Scion FR-S
Read the other thread, the one you already posted in, completely. I suspect you are just reading the first page or something, because it's pretty well spelled out on what to do. |
| The Following User Says Thank You to kodyo For This Useful Post: | Mikepage (03-15-2014) |
#24 |
I will add a special note concerning cracking in the first post
o= FR-S =o |
#25 | |
DIY - Fix your Rear Deck "popping/clicking/tapping/ticking" noise.
Thanks for your comment, I have modified the first post to be really clear. Does it better now? See the important note I have added.
o= FR-S =o Last edited by Mikepage; 03-15-2014 at 07:59 PM. |
#26 | |
OK, thanks for the point in the right direction. I appreciate it! |
#27 |
PROUD OF BOXER
Drives: Raven FR-S
For safe measure I cracked every spot weld in the rear area and lubed the hell out of it. No more pops and squeaks! I sprayed lube in the latch receiver on the rear seat to kill those noises. My car has never been this quiet
| The Following User Says Thank You to supramkivtt2jz For This Useful Post: | Mikepage (03-16-2014) |
#28 |
Drives: Scion FR-S
| Rear Deck "popping/clicking/tapping/ticking" noise. | Sigh-on-Rice | Issues | Warranty | Recalls / TSB | 637 | 04-28-2020 05:55 AM |
| Subaru TSB 12-140-12 for Rear Deck Popping | sparks | Issues | Warranty | Recalls / TSB | 31 | 07-17-2013 12:11 PM |
| GTS rear left popping/clicking sound and fix. | sigmaoctantis | AUSTRALIA | 11 | 05-19-2013 07:58 AM |
| Ticking/Clicking Noise front - passenger side | PoRco | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 05-06-2013 06:55 PM |
| Rear deck popping/clicking | DriftEightSix | AUSTRALIA | 6 | 02-01-2013 02:59 AM |
