#127 |
Thumper
Drives: 2013 FRS
I got mine in from straight Axle Exchange today.. about to go out to the coldass garage and install. Got a great deal through them.
Car is gone - parts for sale
#128 |
Thumper
Drives: 2013 FRS
Did anyone else notice the new u-joint flange is thicker where it bolts to the diff? I'm pretty sure it wont be an issue but the oem bolts are 1/8th inch shy of coming through to the edge of the nuts whereas with the oem setup they are flush.
#129 |
Add lightness!
Drives: 17' WRX
Yup, I definitely noticed that. I just ditched the washers and used loctite. I check them everytime I have the car on a lift...so at least twice a year. No issues thus far.
#130 |
Thumper
Drives: 2013 FRS
Ok. I left the washers on but used loctite. Torqued to 50 ft/lbs. Hope it holds.
#131 |
Drives: BRZ m/t
#132 |
Just curious if anyone with this installed is running the Borla cat-back? I plan to go that route down the road and it has the muffler located in the tunnel (not sure the clearance with the OEM driveshaft).
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread) ![]() |
#133 |
Drives: Pavement MT GR86
Is your exhaust within a 1/4 inch of the oem shaft? It's only a half inch larger if i remember right.
GR86 MT premium
#134 | |
Drives: 2013 WRB BRZ Sport Tech
#135 |
Drives: 2015 WRX
Your welcome! I was concerned about it myself but I figured someone had to be the guinea pig. I made sure to contact Perrin and let them know so they could answer that very question if someone called and asked them.
| The Following User Says Thank You to Malt For This Useful Post: | DAN_BRZ (01-22-2014) |
#136 |
Drives: UltraMarine 6 Spd MT
Any Price matching? The other guys are 427..
So $425 like at initial offering sounds good..
'13 Ultra Marine 6MT:AVO Stg 1.5 T, Berk Tech Cat'd FP, Perrin OP & 2.5" cat back, WinMax W3F/W2R, 18x8.5et44 Rota, 245/35R18's, Drift-Office EcuTek Tune, Cusco Strt Twr & Rear brace and Grimspeed hood struts.
#137 |
Just the tip
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
Just a word of warning to everyone. The aluminum drive shaft is not compatible with the TRD Quick Shifter. It lowers the bottom of the shifter which just barely hits the the shaft. Found out the hard way. Fortunately nothing broke. TRD quick shifter's throws are much shorter even vs the Kartboy so I'm keeping it and selling the drive shaft (a guy is buying it today).
Current: 2013 Lightning Red Subaru BRZ Limited
Past (sold): Click here to see previous cars and bikes ![]() |
| The Following User Says Thank You to stockysnail For This Useful Post: | ProjectD (05-11-2014) |
#138 |
Stig's dark passenger
Its compatable with a Tomei Type 80 though
#139 | |
What part are you rotating? 90deg? The u-joint to the diff or the whole thing into the transmission? 2nd question, Any shaft maker filling them yet to keep harmonics down?
#140 | |
Drives: '22 BRZ
| DIY: Driveshaft Shop (DSS) Carbon Fibre Driveshaft | F1point4 | DIY (Do-It-Yourself) Guides | 67 | 04-17-2021 06:21 PM |
| PST vs Driveshaft Shop CF Driveshaft? | RehabJeff86 | Engine, Exhaust, Transmission | 4 | 08-26-2013 01:39 AM |
| DriveShaft's and Axle's | Driveshaft Shop | Engine, Exhaust, Transmission | 34 | 08-21-2013 06:17 PM |
| Driveshaft Shop CF Driveshaft installed. | Hawaiian | Engine, Exhaust, Transmission | 5 | 08-13-2013 03:04 PM |
| GFB 3-Piece lightweight aluminum pulley kit | Touge Factory | Engine, Exhaust, Transmission | 60 | 06-03-2013 02:52 PM |
