Old 08-24-2013, 10:30 PM   #225
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Smile
Originally Posted by thill View Post
Agreed. The twins are so light.. Maybe 260hp and 250ft lps of torque? That would still be a monster.
Yea, a minimum of 30 hp more if NA would be a good, but 45+ hp if its forced induction. It would absolutely awesome. Also maybe by 2015 there will be advancements in better and cheaper sound deadening so the car will be that much more livable.
Old 08-24-2013, 10:35 PM   #226
FRSBRZGT86FAN
Smile
Originally Posted by Saber_TRD View Post
Ok, not as good as the other guy made it sound, but still delicious none-the-less. Thank you for that. Seriously been waiting for this day, called it so long ago when they started with Scion. People didn't believe us, but there it is.
I finally get to say, "I told you so.".
Yup, there sales have been steadily dropping, but I heard it was going to be dealer choice whether or not they want to run the Scion brand after the half of the dealers get shutdown. After the FR-S sales taper off they are going a real money issue at scion and it won't be financially viable anymore, but at least if that happens they will probably bring the FR-S over to toyota. .
Old 08-24-2013, 11:32 PM   #227
Gaiakai
Gaiakai's Avatar
Drives: '21 Civic Type R
And then we will finally have the 86 that we all want. This cannot happen soon enough...
"Give a man a match and he'll be warm for a minute. Light a man on fire and he'll be warm for the rest of his life."
Follow me on Instagram!
Gaiakai is offline   Reply With Quote
Old 08-24-2013, 11:45 PM   #228
guysmyley
Drives: lexus
what he said
seriously. take me to the future!
guysmyley is offline   Reply With Quote
Old 08-25-2013, 02:01 AM   #229
FRSBRZGT86FAN
Smile
Its really just a guess, we know scion is going to close up shop soon, but whether or not the cars will make a move over brands is another issue, I have no idea the way they would think, but my logic tells me they would save the best selling cars that succeeded in the scion brand and toyotify them
Old 08-25-2013, 02:44 AM   #230
cfusionpm
Drives: Firestorm 6MT Scion FR-S
You called it 10 years ago when Scion started?
2013 Firestorm 6MT Scion FR-S
cfusionpm is offline   Reply With Quote
Old 08-25-2013, 09:46 AM   #231
Deslock
Deslock's Avatar
Drives: 2013 DZE/01 (sold for MX5 ND1)
Just found this thread due to being on the front page. Perhaps it could be combined with the BRZ doomed thread? As I mentioned in my post over there, the Drive article is sensationalistic.
Originally Posted by Skyllz View Post
The current FA20 is a bulletproof motor(other than the DI issue solved with a tune).
Hope you're right, but at this point it's presumptuous to call the FA20 bulletproof.
Originally Posted by jcX4ever View Post
Are you asking more under the curve? It is already better than others.
Even with the abnormalTorque dip at 4000rpm, the FA20 has fatter "LOW END TORQUE" compared to a comparable 2.0L engine (even the k20 of your DC5).
Here's an example:
Hey, that's my graph
Pros of 2.5L NA
--It will not likely to add any weight.
--NA response time is always better.
--Have the option to FI it later. I know people here are power hungry.
Why don't you think using a 2.5 is likely to result in a heavier vehicle?
This is obviously speculative, but based on Subaru's 2L vs 2.5L H4s (and weight differences between the Impreza, Forester, and Legacy), I'd expect a ~12-18% drop in fuel efficiency with a 2.5L engine in a 6MT FT86.
For purposes of comparison, my 6MT BRZ is rated for 22/30 MPG, but actually gets 25-28 MPG in town and 32-38 MPG highway.
Deslock is offline   Reply With Quote
Old 08-25-2013, 09:36 PM   #232
FT_Monk
Drives: Over the hill WRX
They should just install the V6 in the Camry or the IS 3.5 V6 into the twin, problem solved.
FT_Monk is offline   Reply With Quote
Old 08-25-2013, 09:48 PM   #233
ZDan
ZDan's Avatar
Drives: '23 BRZ
Way way WAY back when, when Chevy took its big-block V8 from 427 to 454 cubic inches, the engineers were able to justify it as weight-savings (more material removed from the bores in the block => lighter weight)!
When I went from 2.4 L6 to a 3.1 L6 in my 240Z, weight gain was essentially zero.
If the engine can be bored/stroked to 2.5 liters without becoming physically bigger, and if there's enough margin in the existing drivetrain, there shouldn't be much if any weight gain.
Increase displacement/torque/power by 25% would allow them to gear it, say, 12.5% taller and still have better off-the-line acceleration while at the same time minimizing the impact on fuel mileage.
Old 08-25-2013, 10:52 PM   #234
Deslock
Deslock's Avatar
The 427 to 454 represented only a 6% increase in displacement (vs a 25% increase from a 2L to a 2.5L) and the FA20 has less material to bore out.
Yep, but that's a couple big ifs.
Right, that's one of the reasons why I put in a range for my guestimate.
The Following User Says Thank You to Deslock For This Useful Post:
strat61caster (08-26-2013)
Old 08-26-2013, 04:05 AM   #235
g0lden
Drives: 2013 Scion FR-S Argento
so if 147kw is equal too 200hp, then 197kw should equal 258hp. They have to be thinking turbo/SC or V6 option...I can only imaging how much they will try and charge for that.
g0lden is offline   Reply With Quote
Old 08-26-2013, 10:45 AM   #236
cfusionpm
That was my big concern. If I wanted to pay for an S2000 I would have bought an S2000. This was 10 grand cheaper (new for new). A power boost is definitely going to push it into a higher price bracket.
Old 08-26-2013, 07:28 PM   #237
jcX4ever
X-Lurker
Drives: 2zz MRS
I don't know how thick the cylinder walls of the FA20 but if they can still bore it then you are shaving some metal thus reducing weight while increasing displacement.. this results in a lighter engine but more displacement.. Also, you can add more displacement in stroking .. this should not add weight.
Another, if they want to make a new block for the 2.5L then the weight difference should still be significantly lighter comparing to adding turbo, pipes, intercooler etc.
jcX4ever is offline   Reply With Quote
Old 08-26-2013, 07:54 PM   #238
strat61caster
strat61caster's Avatar
Not much room to bore out. Maintaining square bore/stroke means adding another 6mm diameter to each cylinder (~93mm) or very nearly 1/4".
I guess it boils down to what you think a "noticeable" weight gain is, I typed out a long paragraph and ballparked 50+ lb. increase and realized that meant nothing to many people if it resulted in another 20 hp.
Edit: and that doesn't factor in the bloat as the model ages, heated seats, nicer plastics or satellite radio or knob gobblers or whatever they do to milk the everyman.
ineedyourdiddly
Search this Thread:
Advanced Search
Toyota Supra Alleged Revival: 2015. 2jz-gte4life Other Vehicles & General Automotive Discussions 939 08-03-2019 11:43 PM
Vortech Supercharging System Update - More boost, more POWER! Brian@Vortech Forced Induction 337 03-12-2016 04:42 PM
Will the 2015 get this power boost? Sport-Tech BRZ First-Gen (2012+) -- General Topics 101 05-21-2014 11:43 PM
Toyota confirmed to be exploring forced induction for GT86 mid-cycle refresh AZOOZ_95 Scion FR-S / Toyota 86 GT86 General Forum 79 03-12-2013 11:40 PM
