Old 08-15-2013, 04:15 PM   #141
strat61caster
strat61caster's Avatar
Originally Posted by WolfpackS2k View Post
Come on man, give me a break with comments like that. Using your logic it's a miracle that teenagers and kids in their 20s weren't killing themselves left and right during the muscle car days of the 60s
Wait they weren't? Kind of sounds like it from the way I hear people talk, MG's and Triumphs crumpled around trees like tin cans, Mustangs being slammed into the sides of mountains and Challengers being rolled over. Hell James Dean got killed in his Porsche, who was the last young star to DIE in a car crash on the road? I had to look up Ryan Dunn but he's the only one out of the last decade that I could find.
There was the added benefit that you KNEW you were driving a 2 ton missile capable of taking someones life unlike the isolated toaster clouds that most people get thrown into today.
ineedyourdiddly
Old 08-15-2013, 04:19 PM   #142
CAMBAM_6
CAMBAM
CAMBAM_6's Avatar
Drives: '13 Whiteout FRS
I think @driftfan is just as tired as the rest of us hear people cry about the car being underpowered.....besides you probably couldnt kill yourself if you wanted to in those 60's steel boats of cars and the roads were waaaayyy less crowded
If you think the FRS/BRZ isn't fast enough, the roads you're driving on are too straight.
CAMBAM_6 is offline   Reply With Quote
Old 08-16-2013, 12:28 AM   #143
DRACHENV6
Drives: tata nano
Hybrid drive + 2.0 turbo + preserved handling balance = my idea of win
If i had to choose one I would say that the hybrid drive would be more fun than a sc or turbo. I can see myself utilizing that system dozens of times a day ,at every stop and go and at the apex of a turn.
DRACHENV6 is offline   Reply With Quote
Old 08-17-2013, 06:31 PM   #144
ghdana
Drives: 2000 Civic EX Coupe
As someone who can't afford one until like 2020, if there isn't a BRZ, I'm not sure if I want one unless all Scions are as well equipped.
ghdana is offline   Reply With Quote
Old 08-17-2013, 09:19 PM   #145
skye67
skye67's Avatar
Drives: 2013 black AT, OFT, 4.65
Could you PM me documentation of this? Or post a link to it in this thread? Could save my ass (and others') in the future.
Ah, wolfpackS2k if i only could. This was many, many dead computers ago. This back in 2002 when got my WRX. When some dealer where trying to voiding warranties for CAI and catbacks.
skye67 is offline   Reply With Quote
Old 08-17-2013, 10:13 PM   #146
czar07
czar07's Avatar
Drives: '97 RSP JZZ30 GT-T
James Dean wasnt the at fault driver from what I remember
Germans>Japanese>Italians>Americans. Unless its a Corvette.
czar07 is offline   Reply With Quote
Old 08-17-2013, 10:17 PM   #147
Conn
Conn's Avatar
Drives: g37
So. Off. Topic.
Conn is offline   Reply With Quote
The Following User Says Thank You to Conn For This Useful Post:
czar07 (08-18-2013)
Old 08-17-2013, 11:15 PM   #148
Brzetto
Drives: 4 wheels
James Dean died in that Porsche because the prick in the large car coming from the opposite direction fucked up and ended up smashing Dean head on.
Brzetto is offline   Reply With Quote
The Following 2 Users Say Thank You to Brzetto For This Useful Post:
czar07 (08-18-2013), WolfpackS2k (08-21-2013)
Old 08-17-2013, 11:39 PM   #149
Enraged21
#RememberTheBuster
Enraged21's Avatar
Drives: Firestorm FRS MT
With more hp they will need wider/grippier tires. With more cylinders would mean a decrease in mpg. With everything that majority of consumers want, will inevitably add more weight.
I don't see them making a change without it upsetting the balance of the car somehow. The extensive R&D to make this car so well balanced, they wouldn't drastically change something(s) and upset the balance of this car.
Enraged21 is offline   Reply With Quote
Old 08-18-2013, 12:03 AM   #150
Kilika
Drives: 1992 Toyota MR2
Going to a 2.5 will not upset the balance of the car, the weight change is marginal since the motor will have the same exterior dimensions but a hybrid or turbo will increase weight. And tires are a non-issue, the current tires aren't even that good.
Sent from my Galaxy Nexus using Tapatalk 4
Kilika is offline   Reply With Quote
Old 08-18-2013, 02:56 AM   #151
gt8613
I dream of BRZ
Drives: Prospective BRZ owner.
Hi, thanks for your reply to this thread. I was actually wondering something along the lines you said and had created another thread regarding it. So I hope you can make this more clear for me...so would boring the cylinders to 2.5 cause the potential tuned output of the engine to go down as it could withstand lesser levels of pressure and stress?
Essentially making the 2.5 ideal for more stock output but the 2.0 the better configuration for more potential tuned output?
Thanks.
Originally Posted by DarkSunrise View Post
Yeah I was just basing off the indication that the most likely route (as stated by the article at least) was increased displacement. I'm a bit wary of adding FI on a theoretical FA25. If I remember correctly, the EJ207 lost a lot of knock resistance when bored out to 2.5L. One of the downsides of thinner cylinder walls.
gt8613 is offline   Reply With Quote
Old 08-18-2013, 10:52 PM   #152
DarkSunrise
DarkSunrise's Avatar
Thanks.
I'm not an expert on this by any means, but there are really two issues to consider with thin cylinder walls -- the strength of the cylinder wall itself and the cooling capacity of the block. The former is mostly self-explanatory. Here's a good thread to read on the latter (effect of thin cylinder walls on cooling capacity):
http://forums.nasioc.com/forums/show....php?t=1455775
The bolded statement in your post is probably correct with respect to the EJ207 vs. EJ257, but difficult to predict for an FA20 vs. theoretical FA25 since this is all speculative at this stage. History has a way of repeating itself though which is what worries me.
2022 BRZ Build
2013 FR-S Build
The Following User Says Thank You to DarkSunrise For This Useful Post:
gt8613 (08-19-2013)
Old 08-19-2013, 12:49 AM   #153
Superhatch
AIM4APX
Superhatch's Avatar
Drives: 2013 WRB BRZ Limited
Originally Posted by FRSBRZGT86FAN View Post
A 2.5 means it will be lighter because they are keeping the same block just boring it out, and yes a minimum of 40 more hp thats a huge bump for this car
So larger motor = less weight? Ok.
.5 L = 40hp? Ok.
If they move to a 2.5 it's not going to just be a bored FA20. Also, w/o any improvements to the head/header/exhaust I don't see a 40hp gain from just boring .5L. And even then they won't have a high flow aftermarket type exhaust system. I don't think they have a high revving 2.5L on the market currently (everything is 6.5K or below).
Revving another 1K will take some testing and a larger piston will mean a redesigned piston, rod, maybe crank? If this thing ever comes to fruition (which I don't see happening) it's going to cost more money, have less mpg, and I think you would maybe see 20hp max w/o a significant exhaust redesign, which also means more cost.
I don't think that moving to a 2.5L would be enough for me to sell my car and hop in a newer model.
"It's very difficult to present technology as an overtly positive sales device to people who want an emotional car" -Chris Harris
Superhatch is offline   Reply With Quote
Old 08-19-2013, 02:27 AM   #154
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Ryan Dunn-Lived in near my area, and died near my area, was sadly as mean and gruesome a thought, was drunk more than legal.
James Dean- He was going 85 mph in his porsche 550 and was rammed by a young kid in a Ford Tudor
All of these people were being irresponsible and your point stands, but age has nothing to do with the responsibility
Search this Thread:
Advanced Search
Toyota Supra Alleged Revival: 2015. 2jz-gte4life Other Vehicles & General Automotive Discussions 939 08-03-2019 11:43 PM
Vortech Supercharging System Update - More boost, more POWER! Brian@Vortech Forced Induction 337 03-12-2016 04:42 PM
Will the 2015 get this power boost? Sport-Tech BRZ First-Gen (2012+) -- General Topics 101 05-21-2014 11:43 PM
Toyota confirmed to be exploring forced induction for GT86 mid-cycle refresh AZOOZ_95 Scion FR-S / Toyota 86 GT86 General Forum 79 03-12-2013 11:40 PM
