#15 |
You guys need to lawyer up and go after them. It is on them to prove you abused the car and from everything I have read, it seems like you have a good case.
#16 | ||
Grip>Slip
From the EPA: http://www.epa.gov/obd/pubs/420f09048.pdf
then again, the same document has this disclaimer, which I suspect is Subaru's reasoning for changing their reasoning from "racing" to "abuse" Quote:
#17 | |
We've allowed, and even ASKED them to investigate, but they will not do so. |
#18 | |
Proud of BOXER
Drives: Subaru Boxer
Before the DI failure, was there any sign that the primary CAT had failed? Like strange sounds, rattling, backfires?
Just attempting to figure out if there's any signs other owners can look for to determine if theirs has also failed.
#19 | |
There are no sensors for the secondary cat... it may have been damaged for a while. |
#20 | |
Proud of BOXER
Sorry my mistake, I thought it was the primary cat inside the manifold that had failed, not the secondary cat.
#21 |
#22 | |
Proud of BOXER
Interesting, thanks for the clarification.
Disclaimer, pure speculation ahead: Maybe it's something to do with these high compression motors and the cam overlap timing/high idle used when cold starting the vehicle. I know when I had my headerback exhaust on (no secondary cat), on cold starts the exhaust gas would shoot out forcefully a good 6 feet behind the car. Never seen such forceful exhaust blast from a car like that before.
#24 |
Rather than going through a costly and timely legal situation, why not just purchase an aftermarket exhaust? I understand the principle, but the reality is that winning this battle over Subaru would be exceptionally challenging as they have a full legal department to handle any and all of these situations.
Be like me and have no cats at all lol! Nick C.
| The Following User Says Thank You to Diode Dynamics For This Useful Post: | Marchy (08-07-2013) |
#25 | |
Grip>Slip
#26 | |
Drives: Subaru BRZ / Toyota 86 Experts
#27 |
Specifically, unless the cat has approved by CARB, it is not legal.
California™ |
#28 | |
Buying a whole new engine would still be cheaper than legal fees, that really sucks though. Sorry OP Nick C.
| FS: OEM downpipe / Secondary catalytic converter | cb7tuner | Engine, Exhaust, Bolt-Ons | 2 | 06-07-2016 02:17 PM |
| Explain catless header/catalytic converter/O2/losed Loop | regal | Engine, Exhaust, Transmission | 9 | 07-14-2015 12:34 AM |
| MOTIV Concepts Scion FR-S High Flow Catalytic Converter | Akired86 | Engine, Exhaust, Transmission | 20 | 01-16-2015 04:38 PM |
| Help with disputing a warranty denial? | Sc0ob_do0D | Other Vehicles & General Automotive Discussions | 13 | 12-18-2013 12:32 PM |
| FS/FT: Motiv Concepts Front Pipe w/ High Flow Catalytic Converter | TyperRspec789 | Engine, Exhaust, Bolt-Ons | 4 | 02-27-2013 01:16 AM |
